go_a_way1
Old 12-01-2013, 10:52 PM   #2773
fenton
It's really hard to tell until you try. The raw facts say 50 seconds of wot out of 160 seconds. With dual rechargers I think you could get it done with ESC boost in the straights. Keep in mind that even if you skip a couple of those shorter straights after a couple laps you will still be far far ahead if a stock frs as drag reduction will boost you to normal power levels and not zap as much juice.
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
normancw (12-01-2013)
Old 12-01-2013, 11:31 PM   #2774
mid_life_crisis
Drives: FR-S 10 #103 AT
Actually you guys are all forgetting that with the electrocharger he'll cover those straights in less time than he does now, so he might only need 45 seconds of boost time.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
Old 12-01-2013, 11:36 PM   #2775
TM
TM's Avatar
Drives: DGM BRZ 6MT
Full throttle Electric Supercharger Build Thread
Oops, please ignore this post
TM is offline   Reply With Quote
Old 12-01-2013, 11:44 PM   #2776
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
Question for the guys developing this, will this thing be offered with a tune and also I saw some pics of a black FRS with this ESC and what looks like the Perrin intake...is that their 2.5 or 3.0 CAI? Thanks!
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
Old 12-02-2013, 01:20 AM   #2777
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Dual recharger means two alternators or two of something else?
Old 12-02-2013, 01:23 AM   #2778
fenton
Dual rechargers means two connections from the standard 12v starter battery...which is connected to the alternator.
Basically you go from 25A recharge to 50A recharger. In laymen's terms you go from 8:1 recharge to 4:1
Old 12-02-2013, 01:32 AM   #2779
jamesm
i almost want to buy another car just to put one of these on it.
Old 12-02-2013, 01:35 AM   #2780
fenton
If you have e85 available and open flash tablet you are going to be laughing....that is seriously the bang to buck holy grail.
Old 12-02-2013, 01:44 AM   #2781
s2d4
s2d4's Avatar
You could try to use this to get the low down torque as a compliment to your turbo setup?
Old 12-02-2013, 01:56 AM   #2782
jamesm
i've thought about how this would work in a sequential setup with a larger turbo, but the one i have now is small enough that the benefit probably wouldn't be worth it. if i had a 30r i'd seriously consider trying it.
Old 12-02-2013, 02:00 AM   #2783
fenton
This system is best paired with the vortech supercharger. The vortech has the top end that the ESC doesnt have. It would provably work well with the innovate system as well but the bottom end torque would most likely be more than the stock clutch could deal with.... Mind you this is all here say until someone TRIES it
It should be noted that someone has ran this with a positive displacement supercharger and it did very well. That was on a different platform however.
Old 12-02-2013, 02:15 AM   #2784
s2d4
s2d4's Avatar
Not sure how using the belt driven option by adding parasitic lost to the system is better than the exhaust driven option?
Old 12-02-2013, 02:21 AM   #2785
fenton
Its not really better but the top end addition with the low end lack of torque seems look a good match. Until someone tries it we won't know. Its also worth noting that the vortech adds so much up top that the ECS may be a restriction as well. As I have said before....this is all just message board talk until someone tries it.
Old 12-02-2013, 02:39 AM   #2786
s2d4
s2d4's Avatar
Indeed, compound charging sounds like fun.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
