Drives: 2013 Firestorm red FRS manual
Cold Weather=More power. Why?
Just curious why our cars feel more powerful in colder temps? It seems the torque dip is not as noticeable and just overall better acceleration. No complaints here because I love it, but im just curious what the reason is? My last car was the complete opposite. I also have a few thousand miles on my motor now so maybe its just broken in?
Anyway, would love to hear your thoughts. Thx. |
#2 |
Big Member
Drives: 2014 FR-S
Lol, so many newbie car questions on this site. It's all good tho.
Cold weather means the air is denser, so the engine takes in more air, and more air in engine means more power. |
| The Following 2 Users Say Thank You to dave77 For This Useful Post: | Jaywest717 (12-13-2013), Tgionet (12-05-2013) |
#3 |
Drives: car
because atoms
| The Following 13 Users Say Thank You to radroach For This Useful Post: |
#4 |
Drives: TRD Ultramarine '13
#5 |
Drives: Ultramarine toyobaru
Divert A/C into intake...
Infinite POWEERRRRRR |
| The Following 18 Users Say Thank You to headlikeahole For This Useful Post: | 636 (12-01-2013), Anthonytpt (12-11-2013), Billylammerkins (12-01-2013), Freeman (12-11-2013), kanundrum (12-02-2013), Kimsey47 (12-01-2013), Luis_GT (12-05-2013), Michael (12-02-2013), onefitz (12-11-2013), Panda Grahams (12-12-2013), R.S-HawK (12-01-2013), sal (12-05-2013), SkAsphalt (12-01-2013), Tagera (12-01-2013), Takuro (12-01-2013), Tim_Asphalt_FRS (12-01-2013), VenomRush (12-01-2013), zaptorque (12-05-2013) |
#6 | |
You're getting more comfortable with it may contribute. As mentioned, colder air contains more oxygen per unit volume, which enhances combustion. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | AVodka14 (12-01-2013) |
#7 |
Perfectionist
Drives: 2014 Scion FRS
Cooler air is more dense
#8 |
Drives: Raven FR-S
because u dont have your ac on!
jk jk i miss winter when i had a turbo. +100000000hp heat soak ftl
#9 | |
Drives: FRS
| The Following 15 Users Say Thank You to Nothing For This Useful Post: | Billylammerkins (12-01-2013), Cyrious (12-04-2013), Jaywest717 (12-13-2013), JB86'd (12-01-2013), kidgogeta (12-11-2013), Mister (12-01-2013), Moshpit37 (12-01-2013), P@ul (12-01-2013), racecat (12-01-2013), sal (12-05-2013), Steve201brz (12-01-2013), STV3 (12-11-2013), Tagera (12-01-2013), Tim_Asphalt_FRS (12-01-2013), zaptorque (12-05-2013) |
#10 |
Drives: 2014 FR-S
It's the same reason your car drives better at night.
#11 |
I'll make this fairly simple, if anyone wants a more detailed and scientific based explanation let me know and I'll write something more official up later, but as mentioned before, cold air means more dense air, or, more atoms per unit volume of air. Since air is what's required to ignite the fuel potentially more power as you can combust more fuel. Additionally, cylinder temperatures directly affect when the onset of knocking/pinging occurs. With colder air your cylinder will run slightly cooler allowing the ECU to advance spark timing a little more to gain slightly more power that way too.
#12 |
Drives: 13FR-S
The internal combustion engine is an AIR PUMP.
More air in = more power out. (as long as the fuel delivery system can keep up with the correct mix) Cold air = more air Turbo = more air ![]() As for all the inexperienced want to be gear heads out there there is one book that will answer all your questions about how an internal combustion engine works at a easy to understand teaching level. Even cover clutches throw-out bearings how and when to shift, wheel alignment. [ame="http://www.amazon.com/Keep-Volkswagen-Alive-Step-Step/dp/1566913101"]How to Keep Your Volkswagen Alive: A Manual of Step-by-Step Procedures for the Compleat Idiot: John Muir, Tosh Gregg, Peter Aschwanden: 9781566913102: Amazon.com: Books[/ame] |
| The Following User Says Thank You to Rico415 For This Useful Post: | SirBrass (12-13-2013) |
#13 |
Drives: Raven FR-S
| The Following User Says Thank You to root For This Useful Post: | Billylammerkins (12-01-2013) |
#14 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
| The Following 4 Users Say Thank You to finch1750 For This Useful Post: |
| TPMS IN COLD WEATHER | Scionshaun | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 11-20-2016 06:27 AM |
| Power window fault in cold weather | Suberman | Issues | Warranty | Recalls / TSB | 5 | 01-09-2014 09:24 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
| This car really hates the cold weather | Craig | Issues | Warranty | Recalls / TSB | 55 | 01-28-2013 06:42 PM |
| rattling in cold weather | mezdup | Issues | Warranty | Recalls / TSB | 2 | 01-22-2013 09:32 AM |
