Old 11-30-2013, 03:59 PM   #1
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
Where to find offset?
Just wondering where on the rims the offset would be stamped? I picked up my frs and dropped it off at the shop for them to fit some wheels for me. I went with 18x9 but I do not know the offset. They are pretty much flush. Maybe poke just a hair.
Triumphrider is offline   Reply With Quote
Old 11-30-2013, 04:01 PM   #2
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Offset, if embossed on the wheel, will generally be on the back of the hub, most likely.
If the wheels are German or Italian they normally have the offset (ET) stamped somewhere on the wheel, often right next to the size.
It isn't required to be though and some wheels just don't have this info.
If the wheel is stripped less using offset is easy. You put a straight edge over the back rim and measure to the hub face where it seats on the car hub. The number in mm is the ET.
You can estimate this even if the tire is mounted by measuring the distance from the inflated sidewall to the hub face and deducting one half of the difference between the section (half of 215 if stock width tire ) and one half of the wheel width (half of 7 inches and 7 inches is 178 mm or half of 8 in your case, 8 in being 203 mm) or, if you can measure the actual sidewall bulge use that. Be aware that specified tire width is approximate so young the 215 number will not yield accurate results.
Suberman is offline   Reply With Quote
Old 11-30-2013, 09:02 PM   #3
Triumphrider
Thanks for the reply... I looked on the back of one of my rims and couldn't see anything. I'll check the others and if nothing measure myself. Thanks again!
Old 11-30-2013, 09:11 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The offset on Japanese wheels are stamped as ET, just like European wheels.
It's often on the back of the center hub.
-alex
Old 11-30-2013, 10:31 PM   #5
Suberman
-alex
Yes, and often isn't there at all. ET is German 'Einpresstiefe' or "insertion depth" and I think but do not know that TUV standards in Germany require this to be on every German made wheel or wheel offered for sale in Germany.
Old 12-01-2013, 12:31 PM   #6
mav1178
mav1178's Avatar
On most of the cast wheels I've dealt with (Gram Lights, 5Zigen, Enkei, SSR, etc) the offset is either etched on the backpad of the wheel, or on a sticker on the inside barrel.
Keep in mind we're talking Japanese wheels. I can't say the same for Taiwanese/Chinese/Filipino/Vietnamese/other "JDM" wheels...
-alex
Where can I find this?... Juan_Ri Cosmetic Modification (Interior/Exterior/Lighting) 14 04-24-2013 10:16 AM
What offset is legal? What offset provides most benefit? bdohazelnuts Tracking / Autocross / HPDE / Drifting 2 02-08-2013 01:32 PM
Still trying to find a BRZ? sparks BRZ First-Gen (2012+) — General Topics 27 01-14-2013 06:46 PM
[GTA] Where can I find... drei CANADA 39 12-05-2012 04:37 AM
Need to find FR-S/BRZ Acidz CANADA 5 09-17-2012 12:45 AM
