Old 09-01-2013, 12:01 PM   #57
Dezoris
Dezoris's Avatar
thanks for posting it looks much better than the previous arm. I know SPC is cheaper but all.of their hardware, nuts have turned into a rusty flaky mess on my car in less than a year. I don't know how much I would trust them using it in midwest or coastal areas.
Dezoris is offline
The Following User Says Thank You to Dezoris For This Useful Post:
Calum (09-01-2013)
Old 09-01-2013, 03:26 PM   #58
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by BRZ NA View Post
Thx,but do I really need the arm if want -2 camber? even if I lowered the car by 2" it won't give me -2 camber right?
You need the arms if you want any adjustment.
So let's say you lower it two inches and end up with - 3 or - 2.6 you got no way to fix it. Two inches lower will give you over - 2 camber.
FT-86 SpeedFactory is offline
Old 09-02-2013, 02:52 PM   #59
BRZ NA
Drives: WR blue
Got it thx
BRZ NA is offline
Old 09-02-2013, 03:15 PM   #60
Captain Insano
I am on the old arms. Ft86 speedfactory are there any reliability reasons to switch? I currently only run -1.8 in the rear so could use old or new (or something else for that matter).
Captain Insano is offline
Old 09-02-2013, 04:25 PM   #61
FR-S Matt
Just bought some Goodridge SS brake lines, Hawks ceramic brake pads, and SPC LCA's from FT-86 Speedfactory. Thanks again! Going to get a great alignment and improve my braking even further.
FR-S Matt is offline
The Following User Says Thank You to FR-S Matt For This Useful Post:
FT-86 SpeedFactory (09-07-2013)
Old 09-07-2013, 09:09 PM   #62
FT-86 SpeedFactory
No reason to switch. The old arms actually have more adjustment like the video says. New arms + or - 2 degrees. Old arms are + or - 3 degrees. Really the only main functional difference.
New ones have lower MFG cost so that's the main price difference as well.
Old 09-07-2013, 09:14 PM   #63
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Just got mine on and aligned. NEW LCASs with STOCK toe bushings. Maxed the toe link all the way and managed to get camber down to -1.2 with VERY VERY MINOR toe in on the rear
Definitely worth the money. Ordered through ft86speedfsctory too
TylerLieberman is offline
The Following 2 Users Say Thank You to TylerLieberman For This Useful Post:
FT-86 SpeedFactory (09-09-2013), HATED1 (09-07-2013)
Old 11-11-2013, 11:58 PM   #64
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm interested in getting these as well....but a little unclear how you'd actually adjust the camber? Do you simply move the hubs inwards/outwards as shown in the red arrows on the picture?
And are the items in the yellow box the toe bushings?
Fizz is offline
Old 11-12-2013, 12:01 AM   #65
cnk
Drives: '13 DGM BRZ Limited
The part in the upper right is the toe bushing. It has to be pressed into the toe link after you press out the stock bushing.
The other parts are the eccentric washers and bolt that go into the hub side. When you rotate the bolt, it is locked into the eccentric washers, and that moves the hub mounting point in/out to adjust camber.
cnk is offline
The Following User Says Thank You to cnk For This Useful Post:
Fizz (11-12-2013)
Old 11-12-2013, 12:08 AM   #66
mfbmike
Drives: 2013 FRS, 2008 R32
Very happy with my SPC arms. Made for easy camber adjusting in the rear.
mfbmike is offline
Old 11-12-2013, 02:27 AM   #67
troek
troek's Avatar
Drives: 2012 Toyota 86
Originally Posted by kombatlion View Post
Need them can you quote me to Puerto Rico via USPS!!! my tires are being destroy right now!
thats from ur toe being off, not camber.
troek is offline
The Following User Says Thank You to troek For This Useful Post:
kombatlion (11-12-2013)
Old 11-29-2013, 04:26 PM   #68
ShoGun
ShoGun's Avatar
Drives: 2013 Subaru BRZ SWP 6MT
Do you recommend these LCAs or the Whiteline rear adj bushing kit for a daily driver looking for stock alignment specs on a BRZ with Eibach prokit springs?
(if it makes a diff, wheel specs are: 18x9.5+39 tires 255-35-18)
2013 Subaru BRZ - SWP - 6MT
ShoGun is offline
Old 11-29-2013, 04:37 PM   #69
FT-86 SpeedFactory
These LCA's. Install is easier and you get more adjustment for not much more money. The labor savings alone is worth it over the whiteline bushings.
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
ShoGun (11-29-2013)
Old 11-29-2013, 06:53 PM   #70
Calum
That Guy
Drives: 2013 asphalt FRS MT
http://www.whiteline.com.au/product_..._number=KCA436
Whiteline also sells these.
They're cheaper and you keep your factory control arms and the engineering that went into them.
Calum is offline
The Following User Says Thank You to Calum For This Useful Post:
ShoGun (11-30-2013)
~~CUSCO Rear Lower Control Arms!!~~ nemesisdrift Brakes, Suspension, Chassis 2 05-20-2013 02:35 PM
DIY Request: Rear Lower Control Arms Ryaquinn DIY (Do-It-Yourself) Guides 2 05-08-2013 06:25 PM
FS: SPC Adjustable Lower Control Arms kenward Brakes, Suspension, Chassis 2 04-29-2013 08:58 AM
SPC rear lower control arms, Fix your camber! JoeBoxer Brakes, Suspension, Chassis 12 03-31-2013 07:02 PM
Delete driver01 Brakes, Suspension, Chassis 11 02-06-2013 01:56 PM
