Old 11-27-2013, 01:00 PM   #1
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
RPF1 17x8 +35 on stock suspension?
Hi all,
Wondering if anyone has a setup with 17x8 +35 RPF1s on completely stock suspension?
Leaning toward this direction but open to community suggestions on width and offset...
I have a bias toward performance over aesthetics.
Thanks!
1Cor10:23 is offline   Reply With Quote
Old 11-28-2013, 01:12 PM   #2
xwd
I'd look at the 17x9 +35/+45 RPF1 threads since it will be similar depending on the tire size you plan on using. 17x8 +35 will certainly fit fine. Some say the 17x9 +35 "poke" out a little due to the extra 10mm of offset.
Old 11-28-2013, 02:14 PM   #3
chriscross_tnt
chriscross_tnt's Avatar
Drives: 02 maxima 6spd sold 2013 frs daily
Originally Posted by 1Cor10:23 View Post
Hi all,
Thanks!
I wanna go 17x8 . I'm having trouble deciding what offsett to go aswell. 17x8 with a 245/40/17 tire would be amazing for autocross. Anything wider than 17x8 you starts killing the handling performance
Sent from my HTC6500LVW using Tapatalk
chriscross_tnt is offline   Reply With Quote
Old 11-28-2013, 02:23 PM   #4
fatoni
yeah i dont think theres much truth to what you just said. if a 9 inch rim doesnt hurt a 2100 lb 90 hp miatas handling i dont see how its too much for this car. whats hurting the cars performance might be the 245 tire
Old 11-28-2013, 02:24 PM   #5
1Cor10:23
1Cor10:23's Avatar
I'm open to 9" as well for the better look of the wheel but cognizant of the handling drawbacks as mentioned above...
If going with 17x9 +35, any issue of the fender coming down on the tire at full load given the amount that of poke?
Completely stock setup, of course.
Sent from my SGH-I317M using Tapatalk
Old 11-28-2013, 02:37 PM   #6
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
I have RPF1's in 17x8, +35 configuration on 235/45-17 Continental Extremecontact "DW" tires. With good driving on this setup, the limits of grip are ridiculously high. Naturally, driving with intent to lose grip or not realizing you're driving that way, and the tires will not grip as well, just like every other offering out there. Oh and this setup sits perfectly flush with the fender.
Zach3794 is offline   Reply With Quote
Old 11-28-2013, 02:39 PM   #7
1Cor10:23
1Cor10:23's Avatar
any pics? thanks!
Old 11-28-2013, 02:43 PM   #8
chriscross_tnt
I didn't specifically mean 9 inch rim. But yes as you go bigger it will effect. Put at 10 inch rim and go see how it works out. 245 tire is a great tire for autox . You also don't wanna stretch it too much cause that will affect aswell. That's Why I said a 17x8 and 245 is a good combo. My personal preference beat results I had .
Old 11-28-2013, 02:50 PM   #9
Zach3794
any pics? thanks!
I will post pics later today for you but just as an fyi the car isn't stock suspension wise any longer. These wheels and tires were used on stock suspension for a long time with no issue, but they are now dropped on H&R Super Sports. Still, will post pictures for you
The Following User Says Thank You to Zach3794 For This Useful Post:
1Cor10:23 (11-28-2013)
Old 11-28-2013, 02:56 PM   #10
fatoni
i get the concept. i also understand that 9 inches is 228mm so i dont know how it would be stretching a tire that is 245. rim size isnt as important in autocross because you are likely using a race tire with incredibly strong sidewalls but a wider rim will be beneficial for people who dont want to drive around on r comps. another advantage is that there is more air volume inside the tire keeping tire temps more stable. not too noticeable in a 40 second course but if the op ever plans to see a road course it will be a huge deal. 17x9 wrapped in a 224/45 is probably going to be the sweet spot for this car.
Old 11-28-2013, 02:56 PM   #11
1Cor10:23
1Cor10:23's Avatar
If you had to do over again, would you still go with the 8" width? I think this is my main debate now..8 vs. 9 and the aesthetic differences with the design
Old 11-28-2013, 03:09 PM   #12
fatoni
9s will be faster in almost every instance imo but then you will be married to a wider tire. the 8s will be cheaper and might have more tire choices.
Old 11-28-2013, 03:34 PM   #13
Zach3794
In auto cross id agree that a 9 inch would be faster but the majority of the track guys on here at NA power (and Robi who is supercharged) are in consensus on an 8" wheel and either 225 or 235 wide tire.
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Old 11-28-2013, 03:49 PM   #14
fatoni
i find that odd. what advantage does an 8" rim have over 9" rim at the same tread width. the only differences i see are less sidewall strength, less responsivveness, higher tire pressure, and maybe an insignificant weight loss. im open to opinions
Wheel Directory: Enkei RPF1 17x8.0 +45 track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 163 03-17-2022 02:00 AM
Wheel Directory: Enkei RPF1 17x8.0 +35 Faceless Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 70 10-12-2020 06:16 PM
FS enkei RPF1 17x8 subaruferrucci Wheels and Tires 8 05-13-2013 05:01 PM
FS: 17X8 +45 RPF1'S (TX) track_warrior Wheels and Tires 20 02-26-2013 06:07 PM
Any vendor have in stock rpf1's in black 17x8 +45 offset? track_warrior Wheels and Tires 0 06-25-2012 01:57 PM
