Old 11-28-2013, 12:53 PM   #1289
tbox
tbox's Avatar
Drives: GT86
Originally Posted by Vten View Post
they cleared those Sti Brembo brakes
17x8.25 +25 with stock Michelins 215/45/17s
Looks great! What's your suspension setup?
tbox is offline   Reply With Quote
Old 11-28-2013, 12:55 PM   #1290
Vten
Drives: Too heavy
thanks man . the setup im using is bc racing coils with the swift springs upgrade, SPC rear LCA and SPC toe arms.
Vten is offline   Reply With Quote
Old 11-28-2013, 02:37 PM   #1291
jedichimp
OG <FR-S'less> Member
jedichimp's Avatar
Drives: yes
Brembos looks awesome! Dig the color also. Where did you source them from?
I love that they are a direct bolt-on. Definitely they brake upgrade I'd go for.
Flickr // SarapBuhay
merrill.joes@gmail.com
panda cheez
Old 11-28-2013, 03:49 PM   #1292
juanam0909
Drives: scion fr-s
Very nice set up bro clean
Sent from my LGMS769 using Tapatalk
juanam0909 is offline   Reply With Quote
The Following User Says Thank You to juanam0909 For This Useful Post:
Vten (11-28-2013)
Old 11-28-2013, 06:29 PM   #1293
Vten
Drives: Too heavy
Thx man. I got the brembo from a local Craigslist in a great condition, but I just wanted to fully rebuild them prior the install. Brand new Brembo oem seals, pins and retainer powdercoated in flat black , brand new dba 4000 t3 rotors , fastwrx rear adapter , stoptech ss lines and hawk hps pads and 2nd stage powdercoated calipers in ice white with the stardust clear coats . They're feel great , but they're squeal pretty loud in the morning due to the cold weather .
Old 11-28-2013, 07:26 PM   #1294
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
So im a bit of a noob when it comes to this stuff. Do the rims come in different bolt/stud diameters? I know our cars have 12mm studs. However my xxr look like they would fit 14mm. Does that matter?
My understanding was that the hub rings keep the wheel centered and so the gap around the lugs doesnt matter. I guess I'm looking for conformation.
headlikeahole is offline   Reply With Quote
Old 11-28-2013, 11:37 PM   #1295
juanam0909
Drives: scion fr-s
My understanding was that the hub rings keep the wheel centered and so the gap around the hubs doesnt matter. I guess I'm looking for conformation.
What bolt pattern did you get they had to be 5x100 and xxr 527, 530 use 12x1.25 lugs
Old 11-29-2013, 07:33 AM   #1296
headlikeahole
Yeah I got the right bolt pattern. I'm talking about the stud diameter. Our stock wheels fit 12mm studs where my xxr seem to fit 14mm studs.
Old 11-29-2013, 11:35 AM   #1297
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
As @juanam0909 pointed out, you need Tuner-Style 12x1.25 lugs for XXR 527/530. This has been stated dozens of times in this thread.
mwjcyber is offline   Reply With Quote
Old 11-29-2013, 02:20 PM   #1298
headlikeahole
Thats great because, just like the last guy, it has nothing to do with the question I asked.
Old 11-29-2013, 04:31 PM   #1299
mwjcyber
mwjcyber's Avatar
My bad, I now understand you question. To answer, I just bought my XXR 530's today, so I haven't had a chance to look at the lug hole diameter. Maybe someone else can chime in on this.
That's concerning if your XXR's have 14mm holes, because our cars have 12mm lugs. Did you put the wheel on your car and notice a gap around your lug?
Old 11-29-2013, 04:52 PM   #1300
ALbadboy
ALbadboy's Avatar
Drives: 2013 Subaru BRZ Limited (WRB MT)
Correct. Just get some hub centric rings with tuner style lugs in the correct size and you will be good to go
ALbadboy is offline   Reply With Quote
Old 11-29-2013, 05:04 PM   #1301
headlikeahole
Perfect. I had a bit of a panic attack when I test fitted my wheels and saw that the bolt holes are much bigger then the studs. I can see how once you have the hub rings on, that wont matter.
Old 11-29-2013, 05:34 PM   #1302
mwjcyber
mwjcyber's Avatar
Makes sense. Between hub-centric rings to center the wheel, and Conical Tuner Style lugs, the wheels will be perfectly centered and secured.
17 wheels
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 03:55 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
