Old 11-27-2013, 11:18 PM   #1
didinyc
Drives: '13 Whiteout FR-S M/T
I got cel on my way home. HELP
Hi Guys,
I am fairly new to the forum. Please help me out with this issue. I was driving home from work. I was on Grand Central Parkway and took the bqe exit and I was on 2nd gear, I hit the gas a little bit more than I should, and I saw the traction control came on for 1 second and then the car started to slow down, i keep trying to hit the gas, try to switch gears and hit the gas again but it was like braking. Everytime I hit the gas, rpm wouldnt go higher.Then I took the first exit and stop the car. I installed unichip just 2 weeks ago and I was on Map 0. I restart the car and throttle response was fine but CEL light is still on. Do you think this is the unichip, or me still having summer performance tires that had probably no grip on that corner that made the Trac Control go crazy. Please help me guys. Thanks
didinyc is offline   Reply With Quote
Old 11-28-2013, 12:27 AM   #2
Well, the first thing I would do is start & stop the engine a few times to see if the CEL would go away. If it doesn't, you should have the code read (either by a store bought code reader or by the folks at your local auto store or at a dealer).
Since tomorrow is a holiday and stores aren't open, you might consider disconnecting the battery for a minute or so, and see if the code will go away.
Good luck!
About those "summer tires" in the winter ...., well, you already found out.....
Old 11-28-2013, 12:53 AM   #3
zooki
Drives: waiting on a 2021...
My check engine light comes on sometimes when I turn off the traction control thingies and do donuts. It always clears after I turn off & restart the car though.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 11-28-2013, 01:22 AM   #4
didinyc
Thanks guys. But did you ever lose throttle after that happens?
Old 11-28-2013, 01:55 AM   #5
Well, not in my FR-S, but I had Saturn that would "not go" after the TC did its thing. Dang near got me run over a couple of times....
didinyc (11-29-2013)
Old 11-28-2013, 02:14 AM   #6
Struckbylitenin
Struckbylitenin's Avatar
Drives: 10 Series FR-S
More likely due to unichip. These cars for whatever reason appear sensitive to stuff plugged into them. I had a CEL from using the Torque app as it was apparently looking for sensors/data that were unavailable on the vehicle.
Get the code and report back.
Struckbylitenin is offline   Reply With Quote
The Following User Says Thank You to Struckbylitenin For This Useful Post:
Home Baristas? FnFast Off-Topic Lounge [WARNING: NO POLITICS] 22 06-07-2013 01:09 PM
DO NOT TRY THIS AT HOME! 20valvewynn83 Engine, Exhaust, Transmission 20 07-29-2012 11:52 PM
Should Batty get a new home in the FR-S? Nevermore Off-Topic Lounge [WARNING: NO POLITICS] 13 07-25-2012 10:05 PM
WRB-Got it home!!! jaytaurus BRZ First-Gen (2012+) — General Topics 28 05-29-2012 12:33 PM
