Old 11-27-2013, 07:36 PM   #1
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Delicious Tuning - 200+ whp E85, Stock Headers, EcuTeK ProECU
Hi All,
We had the opportunity to spend some considerable time dialing in an E85 tune for NASA Time Trials TTD class. With a lot of fine tuning on this car we were able to hit 200 wheel horsepower on a DynoJet Dyno.
* DynoJet - Comparison Mode
Vehicle: 2013 Scion FRS - E85 Setup
Engine Management: Delicious Tuning EcuTeK ProECU
Exhaust System: Over Pipe and Straight Pipe Axel Back
Headers: Stock
Intake: K&N Panel Filter
Fuel E85
HP: 200+ dynojet (175whp dyno dynamics)
Vehicle: 2013 Scion FRS -Stock Configuration
Engine Management: Stock
Exhaust System: Stock
Headers: Stock
Intake: Stock
Fuel: 91 Octane
HP: 160 dynojet ( 140whp dyno dynamics)
Not only are you not going to believe it, but even the racers competing NASA Time Trials did not believe it, especially after it just broke the track record in TTD class. Previous record held by a well modified Mazda Miata was 1.53.066 and it is not held by a 2013 Scion FRS with a time of 1.52:741.
For comparison between Dyno Dynamics Dyno and DynJet Dyno's
* DynoDynamics
Stock 2013 Scion FRS produces about
- 140-150 whp on a Dyno Dynamics Dyno
- 170-180 hp on a DynoJet Dyno
- 15% difference in the worst case (150 * 1.15 = 172.50 hp)
E85 2013 Scion FRS produces about
- 175 whp on a Dyno Dynamics Dyno
- 200+ hp on a DynoJet Dyno
- 15% difference in the worst case (175 * 1.15 = 201.25 hp)
As another verification (besides the track record) we have the option to display the dyno chart in "Comparison Mode" which compares the horsepower to a DynoJet Dyno. In "Comparison Mode" we are able surpass the 200 whp mark by quite a margin as seen in the *first image above.
So yes you can make 200+ whp on stock headers with minimal mods. Next test is to see if we can do it with just a panel filter. Spending a LOT of time playing around with Intake and Exhaust overlap along with a few custom maps in the RaceROM custom mapping in with EcuTeK ProECU has allowed us to tweak out every little horsepower from the engine while being reliable and consistent even on the track.
Finally we are bringing the vehicle to a DynoJet in the coming weeks for the final verification as everyone I am sure would like to see.
Cheers,
William Knose
Old 11-27-2013, 07:40 PM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Old 11-27-2013, 07:54 PM   #3
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Interesting...
- The Ancient BRZ Sacrament
by Zaku
Old 11-27-2013, 09:59 PM   #4
jeebus
Not trying to be a tool, but coming in claiming you made 200+whp because in "theory" you would make that on a different dyno that happens to read high is kind of nonsense. If you just came in here to showcase the impressive 35whp gain over stock I would be impressed, as would most others. But expect to get some flack over your virtual inflation factor just to have a catchy thread.
jeebus is offline   Reply With Quote
Old 11-27-2013, 10:24 PM   #5
Malt
Drives: 2015 WRX
Isn't this pretty much the exact same thing that circuit motorsports did with their dyno numbers?
I really wish vendors would just post up their numbers instead of trying to make their gains look more impressive with fuzzy math.
Either way looking at your real numbers it looks like some nice gains.
Malt is offline   Reply With Quote
Old 11-27-2013, 10:25 PM   #6
SmsAlSuwaidi
Boosted
Cant you clearly see the numbers stated ? He posted both the numbers he got and the converted ones, both with graphs and then he overlapped them.
Sent from my IBrick
Old 11-27-2013, 10:29 PM   #7
Malt
Drives: 2015 WRX
Sent from my IBrick
Yes I can, but why post up numbers using fuzzy math trying to equate your dyno results with some arbitrary higher number to look more impressive?
His gains were nice enough on their own without all conversion to hit the "magic" 200 number.
Old 11-27-2013, 10:37 PM   #8
SmsAlSuwaidi
Boosted
All NASA cars should dyno on dynojets or change the numbers to it ( correct me if im wrong Bill )
Also dyno jet is kind off considered the industries norm.
So he needed to do his work in a "dynojet" mode ,because they dyno the cars before races( dont quote me) . If you are wrong and get placed in a wrong category you are screwed
Sent from my IBrick
Old 11-27-2013, 11:00 PM   #9
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Sent from my IBrick
@SmsAlSuwaidi that is correct. That and the Dynojet is considered the industry standard. When developing a car you may not have the ability to tune on a Dynojet and a good tuner takes the time to know his equipment. So crossing the two dyno number and knowing the % difference helps a racer know how far they are off. Being a NASA racer and building motors for racers it helps me know how much more room I have to work the motor should there be a cap of some sort.
DAMotorsports is offline   Reply With Quote
Old 11-27-2013, 11:17 PM   #10
whataboutbob
AutoX-10/10ths every run
I don't think Bill needs to boost his numbers to look good. His track record tuning cars speaks for itself.
Build thread:Here
Old 11-27-2013, 11:47 PM   #11
Malt
Drives: 2015 WRX
That's essentially what I said, a 25 HP gain is nothing to sneeze at on a dyno dynamics dyno.
Old 11-28-2013, 02:29 AM   #12
Dezoris
Dezoris's Avatar
I'd say there is good detail here. More than what most tuners post. Love to see logs of course from track use.
Old 11-28-2013, 12:26 PM   #13
jeebus
Fair enough.
Old 11-28-2013, 02:29 PM   #14
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
I'd be happy to record some logs the next time I'm doing some hard back road runs on Bill's E85 or 91 tunes. What parameters would you like to see recorded?
Zach3794 is offline   Reply With Quote
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
