Old 11-26-2013, 11:31 AM   #15
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by SmsAlSuwaidi View Post
Why won't you consider a precision turbo ?
I've never been able to understand precisions numbering system
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 11-26-2013, 12:15 PM   #16
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Neither have I, but after reading I think it's inducer and exducer for example a 62 62 is 62mm 62mm.. I think
Old 11-29-2013, 02:19 PM   #17
Scoobyrs25
Drives: 01 RS, STI V6 RA Limited, BRZ
Originally Posted by chiefshayan View Post
What was your reasoning for getting the gtx28 and not the gtx30? JW
Spool time, price and power. 475 is plenty. Now on my twin scroll kit, I'll put the GTX30 on after showing the difference in spool with the GTX28.
Scoobyrs25 is offline   Reply With Quote
Old 11-29-2013, 02:24 PM   #18
Scoobyrs25
Originally Posted by Ross View Post
Scoobyrs25, what efr did you use when setting up your car that spooled slower then a 35r? Also look into other markets and the efr it out producing and spooling better then gt's and gtx's when compared to similar sized turbos.
COBB did the tune and I assume the install. At Garage Tuning, my old shop, we designed the turbo kit for the Garrett. For them, they sent us the Borg and we made the downpipe fit. The Garrett and Borg made the same top end, but the Garrett spooled way faster. Seems pretty apples to apples to me.
The Following User Says Thank You to Scoobyrs25 For This Useful Post:
diss7 (11-29-2013)
Old 11-29-2013, 02:54 PM   #19
Ross
Drives: 85 corolla gts
What efr was used. What exhaust housings were used on both the garret and the efr? What was the power range you were working in?
Ross is offline   Reply With Quote
Old 11-29-2013, 02:59 PM   #20
OrbitalEllipses
Drives: Attitude
EFR is vaporware still, isn't it? Oh, it's been 3-4 years since release and they're not vaporware anymore? Okay.
Sellout (11-29-2013)
Old 11-30-2013, 10:41 AM   #21
Scoobyrs25
I don't remember the specs of the Borg. The Garrett was a GT3582 with a T3 1.06 ar and made 300 whp at 3k, 450 whp at 4k and then made 500+ from around 4500 rpm to 8000 rpm. This was done on CA 91 with meth injection.
Old 12-01-2013, 10:47 AM   #22
DeBiase
Drives: 2005 GMC Canyon
May I ask if the GTX28 was the GTX2867R? I doubt it was the 63R. But I'm actually not sure whether you mean GTX3067, GTX3071(I assume this one) or the GTX3076. I know the three have the same turbine wheel and only vary in compressor size but I'm still curious. Also I was considering the GTX3071R BC the compressor map it seems the turbo is at a good spot to make 400bhp tho I don't need that much....yet. But I know I don't have nearly as much experience or knowledge in the topic as you. Could you shed some light on the situation for me so I can make the right voice when the time comes. (If its on relevance I want to make around ~325-350whp) thank you for any insight you can give me. Lastly, why is the bump in hp always far more than the torque with a turbo. It's something I have always been curious about in most small engine mods.
DeBiase is offline   Reply With Quote
Old 12-01-2013, 06:59 PM   #23
FA20Club.com
Drives: 2013 White Out FR-S
Precision moved to a more understandable platform a few years back. it makes it easier for those who couldnt grasp the Trim size indexes. Their model number are based on the inducer diameter of the wheels. So a 6262 is going to equated to a 62mm compressor and 62mm turbine wheel. The 1st number refers to compressor the 2nd set refers to turbine wheel.
FA20Club.com is offline   Reply With Quote
Old 12-01-2013, 07:16 PM   #24
DeBiase
Do you mean that refers to the compressor exducer or is the compressor massive in that. I know that Garrett turbos are signified by the compressor exducer. And do you prefer Borg Warner or Garrett?
Old 12-01-2013, 09:39 PM   #25
FA20Club.com
Exducer is allot larger than that. 62mm compressor wheel can have up to a 70mm exducer depending on the manufacturer. I prefer Garrett for this particular vehicle. we also build a Focus ST specific turbo kit that we use exclusively BW for a couple of reasons. But it is more of a platform based decision. There will never be a one size fits all approach by us. we use what works best.
The Following User Says Thank You to FA20Club.com For This Useful Post:
DeBiase (12-01-2013)
Old 12-01-2013, 10:15 PM   #26
DeBiase
That's a big turbo. Far bigger than the Garretts I have been looking at compressor wise topping out at 54 inducer 71 exducer!
Garrett GTX2863R turbo, TiAL v-band wastegate Turbowned Engine, Exhaust, Bolt-Ons 10 11-27-2013 02:07 PM
