Old 11-21-2013, 11:32 AM   #29
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Originally Posted by FRS Johnny View Post
It seems like a lot of people are picking stance. Is there a reason why? Personal experience. better quality, or better customer service? Is one company's product better? Or is it all the same? Help! I'm on the same boat as the OP
I have personal experience with Stance. So do tons and tons and tons of friends of mine. Out of over 5 years of all of us using their products on the street and the track, I have still yet to hear of a single issue/failure from anybody, nor have I experienced one myself.
Their customer service is absolutely fantastic as well. 95% of the people who actually drift their cars on this forum use Stance coils and most also use their LCAs as well. Stance also makes different types of coilover systems. There are normal sport plus' which are like the entry level. Then they have those with swift springs as an upgrade, and then they have 2-way and 3-way systems with external resevoirs.
After a personal experience with BCs and their products/company, which I won't publicly discuss on this forum, I chose not to ever do business with them.
Lots of people have BCs and have no issues. Lots of people here have BCs and do have issues. A personal friend of mine just installed some on his car and had to run over 25mm of spring preload just to keep from the popping noise to keep happening. Seems like a hit or miss kind of thing.
I just prefer Stance. Always have. Always will.
The Following User Says Thank You to TylerLieberman For This Useful Post:
WolfsFang (11-22-2013)
Old 11-22-2013, 12:14 AM   #30
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Im running stance coils lowered around 4-5" and im loving them. Alot of my friends have had bc br fail on them. Ride is not so bad, though i prefer a stiff ride over a soft so dont take my word. I have done a few autox days and after playing around with the damper setting the coils felt really nice around the turns.
Also guys he said his budget is 1500, idk why you keep on saying get the FA500 when they are already past his budget. Also to the OP, I would never spend more then 1800 on coils unless you are going to track your car often (more then just 2 times a year.) For this I would choose Stance > BC BR. Stance SS are also a inverted mono-tube which make them little stronger.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 11-22-2013, 12:20 PM   #31
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
...they're $1200. 1200<1500
With swift springs they're only $25 overbudget (save for shipping)
Propaganda is offline   Reply With Quote
Old 11-23-2013, 02:38 AM   #32
tr1x5tuh
The Original Super Saiyan
tr1x5tuh's Avatar
Drives: 2014 SWP BRZ
Which stance coils are you running?
tr1x5tuh is offline   Reply With Quote
Old 11-23-2013, 03:02 AM   #33
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Oh no!!!! I'm quoting myself!! :/
[rant]
So I've had my struts and coilovers fitted. The brand is immaterial but it wasn't even on the list when I started looking for suspension. My point is after a budget is established how is one suppose to decide on which brand/model to get. One can read reviews about $700 Ebay specials that are "wow!! these made my car handle so good plus they have 80 clicks of adjustment and I now take that corner 100mph faster!!" You can also read that Mr Racer has Uncle Toby's fitted but I am suggesting that Mr Racer would do equally as well on a similar quality shock. I would suggest that 99.999999999% of people don't buy more than one set of coilovers/struts at a time to do back to back comparisons. This is just not feasible. Maybe it just comes down to price. That is, at a similar price point all struts/coilovers are similar in performance/quality.
[/rant]
Old 11-23-2013, 07:14 PM   #34
WolfsFang
Scrape Master
WolfsFang's Avatar
My bad i kept on thinking of the V510
Stance SS
Old 11-24-2013, 08:50 PM   #35
Myblackhatch
Drives: Frs
Swift Springs add on.
I personally would look into BC Racing but opt for the Swift Springs upgrade. The swift springs coils on the BC damper are hard to beat and if i am not mistaken should still be within your budget.
Myblackhatch is offline   Reply With Quote
Old 11-24-2013, 09:27 PM   #36
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
From what I've seen and read people have gone fast with BC and others have done the same Fortune Auto. "Fast" as in winning various local amateur competitions with them. Whether they used off-the-shelf stuff or custom built, I'm not sure. From a spec sheet perspective, the Fortune Auto stands out with the digressive valve and the quality of components used to build them (according to their marketing material at least). From end user feedback I've seen, there seems to be some common complaints about the BC top mounts making weird noises. I've not read anything negative about the fortune auto set.
Stance.... I've worked on a FR-S with them. Not a lot of suspension stroke with these. I think they get the same complaints about top mount noises as the BC.
If I were in your shoes, I'd shell out that extra bit of money for the fortune auto dampers.
Intent > Content
Old 11-26-2013, 04:13 AM   #37
coachzizi
Drives: 2013 scion FRS
so kw v1 or FA? i was also in the same boat as OP, but considering ARK because of it's spring rates.
coachzizi is offline   Reply With Quote
Stance super sport coil overs 1200 miles Jhon19lopez Brakes, Suspension, Chassis 4 11-09-2013 01:38 PM
AutoX coil-overs what should i get? subaruferrucci Tracking / Autocross / HPDE / Drifting 4 02-19-2013 03:03 PM
Coil-overs \ Spring kit ????? v3rgil AFRICA 9 11-16-2012 08:27 AM
XYZ Coil overs??? Juanito08 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-31-2012 09:12 PM
