Old 11-24-2013, 07:07 AM   #1
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Standard Suspension Bump Travel
Ok I have been trying to work this out...
The OEM front struts have ~150mm of shaft exposed on the shock when removed from the car... You cannot extend them anymore than that off or on the car.
-this tells me the total travel is ~150mm, right?
The bump stops are ~60mm tall.
-the tell me the total usable travel for the car is ~90mm, right?
If you jack the car up, the total droop is ~85mm, front & rear, obviously this doesn't reflect the travel on the rear as the shock is nearer to the middle of the lower control arms.
-on the front though, with a near 1:1 motion ratio, that takes up most of said travel?
In my mind, ~85mm droop taken out of total ~90mm travel leaves 5mm before you are touching the front bump stops, surely this isn't right??
what am I missing with my monkey maths??
86•BRZ is offline   Reply With Quote
Old 11-24-2013, 10:26 AM   #2
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Strut angle. Works the same on a McPherson strut as on a separate shock.
Wheel travel is greater than shock travel even for a McPherson strut. Otherwise you'd get no camber change.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
86•BRZ (11-24-2013)
Old 11-24-2013, 03:20 PM   #3
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Cheers,
I figured there might be a few mm in that, as I said it would be close to 1:1 motion ratio.
The struts are pretty much vertical though and there is little camber increase on compression.
There can't be too much difference though??
how much do you reckon?
Example picture below shows a worst case mcpherson strut.
In my mind there is still next to no bump travel before the bump stop are hit?? especially for car with lowered springs
Old 11-25-2013, 07:08 AM   #4
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
simple question then... how much bump travel does the FR-S have?
Old 11-25-2013, 09:44 AM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
just wanted to add a little bit to this bit
"The bump stops are ~60mm tall.
-the tell me the total usable travel for the car is ~90mm, right?"
the bumpstops are not solid, they are somewhat compliant and will act a spring when compressed.. a spring with an exponential rate that reaches infinity after maybe 25-30mm of compression.
The Following User Says Thank You to 7thgear For This Useful Post:
86•BRZ (11-25-2013)
Old 11-25-2013, 10:15 AM   #6
Wepeel
Drives: '13 BRZ Ltd
-on the from though, with a near 1:1 motion ratio, that takes up most of said travel?
Thanks for taking those measurements. I think the train of thought is correct. For front strut/wheel motion ratio, you can assume around 0.96.
As 7th said, the bumpstop is compressible, and can probably compress down to half or even 1/4 of it's free length before the rates really start to increase to infinity.
If you have those same measurements for the rears you can use 0.78 for the ratio shock motion to wheel motion.
Wepeel is offline   Reply With Quote
The Following User Says Thank You to Wepeel For This Useful Post:
86•BRZ (11-25-2013)
Old 11-25-2013, 10:34 AM   #7
Racecomp Engineering
This car is very bumpstop active....
You're very close to our measurements....about 5mm of bump travel before you start touching the bumpstops.
Drop the car an inch and you're about 20mm into the bumpstop at rest. The spring rate of the bumpstops is progressive and ramps up by that point to be fairly substantial. This is why a lot of cars with big drop springs, OEM bumpstops, and soft-ish front rates lead to understeer. The coil spring rate ratio (soft front / stiff rear) doesn't mean all that much if you are rolling in progressively firmer and firmer bumpstops and quickly overloading your outside front tire.
EDIT: this is for the front, I don't have the rear numbers off the top of my head but yes you need to use the motion ratio to get correct numbers.
- Andy
86•BRZ (11-25-2013)
Old 11-25-2013, 11:31 AM   #8
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
what kind of a theoretical effect would trimming the hard-end of the bumpstop do on an otherwise stock setup?
Calum (11-25-2013)
Old 11-25-2013, 03:09 PM   #9
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
I understand the bump stops are progressive. I just wouldn't have though you would be into them after so little travel. Wow.
Old 11-25-2013, 07:31 PM   #10
mike156
Drives: EVO
Many cars use bumpstops as a second spring now (many put the car on the bumpstop at normal ride height even). It lets them use a soft spring for normal driving then the spring package goes very progressive over larger bumps. Modern springs are wound in a manner to offset the bending load put on the strut. I wouldn't be surprised if the bumpstop approach is a way to keep strut friction down, along with soft ride rates, but then the ability to soak up big stuff.
mike156 is offline   Reply With Quote
The Following User Says Thank You to mike156 For This Useful Post:
86•BRZ (11-25-2013)
Old 11-25-2013, 09:44 PM   #11
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Thank you. I guess I always saw them as a last resort to stop the strut breaking and that they wouldn't hit that much in everyday driving.
Old 11-25-2013, 10:55 PM   #12
Suberman
Not theoretical but real, the shock could bottom out which blows them up eventually.
Old 11-25-2013, 10:56 PM   #13
Suberman
Oh I don't think so. Riding the bump stops in a corner could be very exciting indeed.
You will know when you hit the bump stops on any car. If you hit them in a corner the results will be pretty exhilarating.
Old 11-25-2013, 10:58 PM   #14
Suberman
You're very close to our measurements....something like 5mm of bump travel before you start touching the bumpstops.
- Andy
really? I've got to check this out, it would explain the weird handling quite nicely. Oversteer arrives at ridiculously low cornering loads. I've never experienced a car which hits its bump stops in normal driving.
question about front travel on coilovers uncivilised Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-26-2013 04:33 PM
FS: Standard Suspension R7TA coilovers with extra springs theGonz Brakes, Suspension, Chassis 7 07-18-2013 09:39 AM
STD Standard Suspension R3 Coilovers knocking FutureFT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2013 12:49 PM
