Old 10-07-2013, 09:56 PM   #113
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by Anthony View Post
Has anyone figured out how much this thing weighs, at least within a tenth of a pound? I'm curious to see if it's actually the lightest driveshaft available right now. It needs to clear 12.2lbs.
Axle Exchange wrote "This one piece 3" aluminum shaft saves you almost 17lbs !" on their website.
Does that mean only 7.2 lbs (24.2-17)?
http://www.axle-exchange.com/inc/sdetail/29/399
Thanks.
cslntuee is offline   Reply With Quote
Old 10-07-2013, 10:20 PM   #114
UncleFester
Thanks.
Couldn't find the post, but I think it's on NASIOC. Someone weighed one and it was 12.1 lbs.
UncleFester is offline   Reply With Quote
Old 10-07-2013, 11:11 PM   #115
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Look at my post #86... hehe. 13.2lbs for mine.
JimmyMac is offline   Reply With Quote
The Following User Says Thank You to JimmyMac For This Useful Post:
Anthony (10-09-2013)
Old 10-08-2013, 02:15 AM   #116
Hawk77FT
Drives: GTS 86
Easy installation, it took me about 45 minutes with jack stands. Huge difference. I got mine from Axle-Exchange.
Hawk77FT is offline   Reply With Quote
Old 10-08-2013, 10:41 PM   #117
cslntuee
How everybody make a decision between Axle Exchange and
Driveshaft Shop aluminum driveshaft?
Thanks a lot.
Old 10-20-2013, 04:51 PM   #118
8686
8686's Avatar
Drives: 86
Just installed mine. The car feels much lighter in acceleation. No vibration No un normal noise maybe because of my loud exhaust.
Very happy with the result of this drive shaft.
Sent from my iPhone using Tapatalk - now Free
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 11-03-2013, 01:38 PM   #119
slates74
Drives: 13 SWP BRZ LTD 6MT
Glad you guys are liking these, definitely still one of my favorite mods
slates74 is offline   Reply With Quote
Old 11-19-2013, 10:44 AM   #120
Malt
Drives: 2015 WRX
Originally Posted by Ooops View Post
Ditto
Anyone fit this with the Perrin 3" Catback Exhaust yet?
Bump for any info on this. Any fitment issues with a full 3" Perrin exhaust? Exactly how much clearance is needed to prevent issues with this driveshaft?
Malt is offline   Reply With Quote
Old 11-19-2013, 10:40 PM   #121
Malt
Drives: 2015 WRX
Not to double bump but, it looks like I'll just have to find out if there are fitment issues myself. I ordered one this afternoon. Hopefully it will work with a full perrin resonated 3" exhaust.
EDIT: Yep, it clears a full Perrin 3" exhaust with a little less than 1" to spare.
The Following User Says Thank You to Malt For This Useful Post:
DAN_BRZ (01-21-2014)
Old 11-24-2013, 10:16 PM   #122
BRZ68
Drives: BRZ m/t
Has anybody ran with this shaft over 100mph and experienced any vibration? There is this loud vibration i feel when driving 105mph and over in 6th gear. I'm not sure if this is because of the hollow center of the aluminum shaft making noise..but I've only heard reviews of a whine. Also, what do they mean by this driveshaft being balaced at 5000rpm? Any input will be appreciated. thanks!
BRZ68 is offline   Reply With Quote
Old 11-24-2013, 10:30 PM   #123
Malt
Drives: 2015 WRX
have you tried rotating it 90 degrees to fix the vibration?
Old 11-24-2013, 10:54 PM   #124
Carolina Dyno
Carolina Dyno's Avatar
Drives: 2013
They balanced it up to a drive shaft rotating speed of 5,000 RPM, not your engine speed. Similar to balancing a tire.
Carolina Dyno is offline   Reply With Quote
The Following User Says Thank You to Carolina Dyno For This Useful Post:
BRZ68 (11-30-2013)
Old 11-25-2013, 12:10 AM   #125
8686
8686's Avatar
Drives: 86
I experince the same aboe 180 km/h several times then it disappearsd. not sure why this happened.
Old 11-25-2013, 03:04 AM   #126
BRZ68
Drives: BRZ m/t
I will definitely look into rotating it 90 degrees. Will post up if vibration goes away. thanks
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 05:21 PM
PST vs Driveshaft Shop CF Driveshaft? RehabJeff86 Engine, Exhaust, Transmission 4 08-26-2013 12:39 AM
DriveShaft's and Axle's Driveshaft Shop Engine, Exhaust, Transmission 34 08-21-2013 05:17 PM
Driveshaft Shop CF Driveshaft installed. Hawaiian Engine, Exhaust, Transmission 5 08-13-2013 02:04 PM
GFB 3-Piece lightweight aluminum pulley kit Touge Factory Engine, Exhaust, Transmission 60 06-03-2013 01:52 PM
