Old 11-11-2013, 02:13 PM   #29
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Originally Posted by Mech_Engr View Post
did you adjust the suspension at all? or is that the stock ride height with a 19" wheel
Any wheel on the FT86 with little to no gap has a drop.
It's not you, but it gets old seeing post after post of dropped cars where people ask if it's stock suspension. The FT86's are raised significantly to clear parking blocks and to meet pedestrian safety standards.
The OP's setup is probably approximately a 2" drop.
mwjcyber is offline   Reply With Quote
The Following User Says Thank You to mwjcyber For This Useful Post:
Mr. Joshua (11-19-2013)
Old 11-24-2013, 02:49 PM   #30
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
PM me if actual offset specs pop up...
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Old 07-01-2014, 11:37 PM   #31
Nissota
Nissota's Avatar
Drives: Subaru BRZ, Nissan 240sx
They look amazing! Do you have the offset on these CF5V?
Nissota
2013 Subaru BRZ DD
1997 Toyota Supra MKIV
1990 Nissan 240sx
www.revvolution.com
Nissota is offline   Reply With Quote
Old 08-22-2014, 12:17 AM   #32
Beachnuttz
Beachnuttz's Avatar
Drives: '13 Firestorm
did you lower this hot rod? I may have missed, if so sorry.
Beachnuttz is offline   Reply With Quote
Wheel Directory: 2Crave MACH-4 19x8.5 +?? / 19x9.5 +?? DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-25-2015 01:09 PM
Wheel Directory: Forgestar F14 19x8.5 +35 / 19x9.5 +38 exequtor1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 04-06-2015 09:59 PM
Wheel Directory: BBS RI-D 005 19x8.5 +43 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 04-06-2014 04:32 AM
Wheel Directory: BBS LM 19x8.5 +25 SpecPer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 76 05-22-2013 10:43 PM
Wheel Directory: Forgestar CF5 19x8.5 +42 / 19x9.5 +35 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-28-2012 03:08 PM
