Old 11-24-2013, 12:25 AM   #1
VirUzxZ
Drives: Black on Black on Black
Some help please! Problem when swaping from summer to winter set!
So this past warm season i went a head and droppd off my car and had the stock summer tires put on some random 17" rims (have winters on the stock rims which i plan to keep this way). And so now that the warmer months are behind us and i've gone and jacked up the car to swap my tire+rims over. After removing 1 of the summer tires+rim i tried to fit the winter tire+stock rim back on but it won't fit! the bolts don't come out far enough from what i believe to be the center hub is too big for the center of the stock rim(assuming that's the right term)? upon closer inspection of the summer rims the center hole is defenitely larger. was hoping to get some input from you guys as what i should do in this case? Thanks in advance
VirUzxZ is offline   Reply With Quote
Old 11-24-2013, 12:29 AM   #2
Burrcold
Drives: Subaru BRZ Limited
You can't get the stock rim back on? Perhaps you should just concede and bring them to someone who knows what they're doing.
The Following 2 Users Say Thank You to Burrcold For This Useful Post:
ae86stunt (11-24-2013), ZionsWrath (11-24-2013)
Old 11-24-2013, 12:31 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
If the bolt is not long enough, maybe one of the bolts was sheared.
Also, make sure the centering ring from the summer wheel is not stuck to the hub.
Old 11-24-2013, 12:51 AM   #4
........Also, make sure the centering ring from the summer wheel is not stuck to the hub.
If that is NOT the case, maybe (as Burrcold suggested) take the wheels back to who mounted the summer tires and have them make the swap.
Old 11-24-2013, 03:15 AM   #5
VirUzxZ
Originally Posted by ae86stunt View Post
Sigh, look bro.
There is a plastic cap over the hub outer race. (Edge) Its called a centering cap. Its used for aftermarket rims.
pop it off with a flat tip screw driver... Save it.. They go back on the hub when you reinstall the aftermarket rims.
Thank you!
summer and winter tires s2kdrew Canada Classifieds 0 11-09-2013 09:53 AM
summer and winter tires s2kdrew Canada Classifieds 0 11-09-2013 08:17 AM
Why doesn't it come like this from the Factory? (Front Camber Bolts + Spring Swaping) Kostamojen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 10-05-2013 01:20 AM
Yep, these are summer-only tires. FRiSson New England 5 11-09-2012 09:12 AM
Trackforged BIG summer BBQ EVAN&MONICA Northwest 3 04-18-2012 08:43 PM
