Old 11-23-2013, 07:05 PM   #575
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
^^^Windows 8 ?
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 11-23-2013, 07:09 PM   #576
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by elrod View Post
I just received my OFT today. I have OF manager 1.03 installed and I have read my stock ROM. I reconnected the OFT to my PC to load the appropriate tune but OF Manager hangs up in 'Searching for updates...' It has verified latest version, downloaded test protocols, uploaded test protocols ... then hangs while displaying PT0044.prt
What do I do now?
Probably the easiest thing to do is try on another computer. This is assuming you already tried to quit and restart the application (and unplug/plug the OFT) already.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
elrod (11-23-2013)
Old 11-23-2013, 09:34 PM   #577
elrod
elrod's Avatar
Drives: WRB BRZ Limited MT
It works!
Many thanks, @shiv@vishnu. I changed from a desktop with Win7-Pro64 to a laptop with Win-7Pro32. I had installed the Win8 patch on the desktop because of something I read earlier. I did not install the Win8 patch on the laptop. Loaded Stage 1 (1.34) and it seems to run quite well. It's still a little tricky to tell with wet streets.
I'm curious: each time I start OFManager and connect the OFT, it uploads/downloads the test protocol and a configuration file. Is this normal?
elrod is offline   Reply With Quote
Old 11-24-2013, 02:52 AM   #578
brn12345
brn12345's Avatar
I have also noticed that the USB 3.0 on my windows 7 laptop does not work properly. If I plug it into the USB 2.0 port it works fine on the same laptop.
brn12345 is offline   Reply With Quote
Old 11-24-2013, 11:43 AM   #579
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Yes. Normal
FRSFirestorm is offline   Reply With Quote
The Following User Says Thank You to FRSFirestorm For This Useful Post:
elrod (11-24-2013)
Old 11-24-2013, 04:25 PM   #580
elrod
elrod's Avatar
I used nothing except USB2 ports. That's why I never connected to my new laptop which has only USB3 ports.
Old 11-24-2013, 06:43 PM   #581
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
in all fairness, usb has always been a mess. Usb 3 is especially painful to deal with.
Old 11-26-2013, 09:22 AM   #582
Visconti
Drives: 05 STi
FYI- you clearly have some address issues on some of your maps, I would go through your OTS maps..
John
Visconti is offline   Reply With Quote
Old 11-26-2013, 10:53 AM   #583
jeebus
John
do you care to elaborate on that at all?
jeebus is offline   Reply With Quote
Old 11-26-2013, 10:54 AM   #584
Visconti
Drives: 05 STi
Ignition Map on A01C is probably the biggest mistake
Old 11-26-2013, 11:04 AM   #585
bfrank1972
Drives: 2013 FR-S Argento
Nah, ignition maps good, they help car go!
I think people are asking what specifically is wrong - so can you elaborate on what is wrong with the ignition map? Help the uninformed (me) out here so we don't all think it's just a weak shot at the competition.
Old 11-26-2013, 11:07 AM   #586
Visconti
Drives: 05 STi
Trying to make a friendly post about a issue, it's up to them to followup and resolve it.
If you wanna see it for yourself I'd be more than happy to show you at Sherwood
John
Old 11-26-2013, 11:08 AM   #587
s2d4
s2d4's Avatar
Question, why are you going through his tunes? Will you be sharing your maps after that?
The Following 3 Users Say Thank You to s2d4 For This Useful Post:
Cross (11-26-2013), Garrett@Openflash (11-26-2013), RacerDrews (11-27-2013)
Old 11-26-2013, 11:10 AM   #588
bfrank1972
John
Ok fair enough - Sherwood? The diner?
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 04:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 04:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 09:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
