Old 10-01-2013, 08:10 PM   #155
Squishy
Drives: 2013 WRB BRZ
No problem.
Squishy is offline   Reply With Quote
Old 10-03-2013, 10:13 PM   #156
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
The Reference System is excellent!
Looks like the back seats will be down for a while, lol!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-20-2013, 03:19 PM   #157
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
Ugh - I received and installed the Reference 400CF but the instructions were for the 400+ series. End result - I didn't hookup the 3.5" dash speakers and umbilical cord. Since I don't have the instructions, can anyone tell me where the umbilical plugs in? I assume its somewhere on the HU, but I want to be sure before I crack it open again.
Can anyone tell me how to hook up this last step?
Thanks.
milhouse is offline   Reply With Quote
Old 10-20-2013, 03:40 PM   #158
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Thanks.
Here you go, looks like someone else had this same issue after the upgrade and wrote a nice little how-to:
http://www.ft86club.com/forums/showt...t=44981&page=3
alexand3r is offline   Reply With Quote
Old 10-20-2013, 08:32 PM   #159
milhouse
Because Racecar
milhouse's Avatar
Thanks - for the price you'd think they'd have better and updated directions.
Old 10-21-2013, 12:36 PM   #160
sparks
sparks's Avatar
milhouse - Did you get it figured out? I can send you the directions if needed.
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
Old 10-21-2013, 01:59 PM   #161
milhouse
Because Racecar
milhouse's Avatar
No need - I got it. Thanks.
Sent from my iPhone using Tapatalk - now Free
Old 11-22-2013, 04:55 PM   #162
Winjr
Drives: 2013 Subaru BRZ Premium
Thought I'd document my experience in the event that anybody has a similar issue.
I installed this system about 4 months ago. Starting several weeks ago, a "noise" issue developed, specifically, a crackling/popping/hissing noise, completely random and intermittent, most audible in the left front tweeter. Strictly confined to the left channel.
The problem was a loose connection. Either: the six pin or ten pin connection to the nav unit, or the 10 pin connection in the rear where the stock amp is bypassed. disconnected all three, reconnected, problem gone.
Winjr is offline   Reply With Quote
The Following User Says Thank You to Winjr For This Useful Post:
kludger (11-24-2013)
Old 04-13-2014, 08:45 PM   #163
BRZ323
BRZ323's Avatar
Drives: '13 BRZ GBS
I installed my OEM Audio Reference system yesterday. Install went well. Loving it.
BRZ323 is offline   Reply With Quote
Old 04-23-2014, 10:15 PM   #164
tiny41
Drives: Subaru BRZ Limited
Same issue here too! Working fine for the past 4 months and all of a sudden today it had no sound. Unplugged and reconnected the amp and it worked again.
tiny41 is offline   Reply With Quote
Old 04-25-2014, 08:29 PM   #165
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
I had this problem. Sandy from OEM audio+ helped me diagnose it and even replaced my tweeters. After a long time I realized that it was the connector to the Headunit that was not fully locked in. The harness has no click locking thing so can come loose if you don't shove it in enough.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
The Following User Says Thank You to l0aded For This Useful Post:
chanomatik (04-25-2014)
Old 04-25-2014, 08:31 PM   #166
l0aded
Addicted
l0aded's Avatar
Just to give my POV, I installed the reference series immediately when it came out and loved it. I swapped to Robust bass profile from the default balanced profile later and felt it was somewhat lacking in fidelity.. It just sounded like a normal sound system with stronger bass. I asked Daniel to swap my profile back to balanced and should be going back on Monday. Does anyone have any experience with switching bass profiles? I'm curious how the "full" profile is but don't want to risk having it be bad and doing a swap again.
Old 05-06-2014, 02:37 AM   #167
l0aded
Addicted
l0aded's Avatar
Bump. Swapped from Balanced to Robust originally, then swapped from Robust to Full just recently. My memory of Balanced has faded so I can't give an accurate comparison but from Robust to Full I think I made the right decision. On Robust I felt the sound felt slightly artificially boosted and I could hear certain sounds coming from certain directions. On the full it feels more immerse (similar to my memory of the balanced). The bass on full feels slightly lacking at higher speeds when the levels are flat but raising it up 2-3 notches (on the BeSpoke) makes it good for freeway driving.
Props to Daniel and the rest of the OEM Audio+ team for their great customer service and dealing with my indecisive swapping around. The service of swapping is supposedly being discontinued soon btw.
The Following 2 Users Say Thank You to l0aded For This Useful Post:
ericmpena (08-04-2014), oemaudioplus (06-18-2014)
Old 05-08-2014, 02:31 AM   #168
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
I just got my BRZ, and the sound system is one of the few things I don't really like about it. I was thinking of getting this kit, but I also want to change out the head unit. Would this kit work with, say, a mid- to high-end Kenwood HU?
SilverlightPony is offline   Reply With Quote
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 04:34 AM
Perrin Pulley review? Invidia Q300 exhaust review? ScionFrsFan Engine, Exhaust, Transmission 4 12-10-2012 08:27 PM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
EVO magazine review of GT86/BRZ review out TheRoadWarrior Scion FR-S / Toyota 86 GT86 General Forum 6 01-05-2012 08:26 PM
AutoExpress BRZ Review - Follow up to the GT86 Review Zgrinch BRZ First-Gen (2012+) — General Topics 3 12-13-2011 08:03 AM
