Old 11-21-2013, 03:39 PM   #1
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
Iphone 5 Charging idea DIY
So if you're like many of us with an Iphone 5, you might find it kind of hard to charge it and/or trying to make the inside look "clean" from wires. This is just how I ran mine; maybe it will help others. I should note that this DIY is for Iphone 5 ONLY because of the side of the connector.
First things first; You need a 2M (6 feet) Apple Iphone 5 charger cable
Next, remove the ebreak boot and unscrew off the shifter knob. You will also need to "pop" off the shifter bezel to access the space under it. I pluged in the USB end of the cable into the USB drive, then "snaked" the cable around the side and up untill I could see/reach it.
Next, Look into the middle console and you will see the 12V popwer port. You will notice that there is a small rectangle opening on the bottom of it. This is where you will reach inside through the shifter opening and guide the small end of the USB cable into that opening. I have quite big hands but I was still able to do this.
Put everything back...
I have a Sutty arm rest and it really helps cover the middle. The OEM armrest would look good, too!
I do use my phone for GPS and I wanted to make sure that if I needed to see the phone, the cable was also long enough to reach the other side of the shifter so it would "stand up" while I drive. This just shows you the reach the cable can go.
This is the passenger side view. I could make a hole and have the cable be tucked away up much higher, but this is just the way I did it.
Thanks for looking!
Hope this helps!
Cheers
AG3NT_5CARFAC3 is offline   Reply With Quote
Old 11-21-2013, 03:47 PM   #2
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
You can also run the wire from the glove box underneath the molding on the passenger side without ripping up anything or making the armrest power plug un-useable.
hyper4mance is offline   Reply With Quote
Old 11-21-2013, 03:51 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Plastidip it black for the stealth
Old 11-21-2013, 03:51 PM   #4
AG3NT_5CARFAC3
Drives: Toyota GT86
This is true but how would you play music? via blue tooth? Blue tooth has awful sound quality...pls you can scroll on the head unit in the way I instructed!
Old 11-21-2013, 03:52 PM   #5
AG3NT_5CARFAC3
Drives: Toyota GT86
I agree; I will down the road
Old 11-21-2013, 04:12 PM   #6
WRXGuy1
WRXGuy1's Avatar
Drives: 2013 WRB BRZ Premium 6MT
Bluetooth has been great for me, but I have the crappy stock speakers lol
2013 BRZ Premium WRB MT - Picked up 5/31/12
WRXGuy1 is offline   Reply With Quote
Old 11-21-2013, 04:23 PM   #7
AG3NT_5CARFAC3
Drives: Toyota GT86
Can you find a song/album/artist on the stock head unit via blue tooth?
Old 11-21-2013, 04:38 PM   #8
utekineir
blowhard
Drives: frs, project forester
Yes
I use a 6ft amazon lightning cable with another usb extension run from a pillar to a pillar between the dash and window hidden across the car down to the glovebox 12v. With a bit more length I'd guess someone could even run to the head unit usb fully hidden. I prefer the faster charging from the 12v plug though.
Drivers side suction cup ram mount easy reach from left hand in sight of road.
[ame="http://www.amazon.com/gp/aw/d/B00B3OA7R8?vs=1"]AmazonBasics USB A to Lightning Cable (6 Feet/1.8 Meter):Amazon:MP3 Players & Accessories[/ame]
It's thick and black. The way I prefer my cables and men.
utekineir is offline   Reply With Quote
Old 11-21-2013, 04:48 PM   #9
hyper4mance
I use the front USB stick with this and the screen (at least on BRZs) can navigate how you setup your folders.
[ame="http://www.amazon.com/gp/product/B00812F7O8/ref=oh_details_o05_s01_i00?ie=UTF8&psc=1"]Amazon.com: SanDisk Cruzer Fit CZ33 32GB USB Flash Drive (SDCZ33-032G-B35): Computers & Accessories[/ame]
TBH I dont have an iphone, but this applies the same for a micro usb wire for droids or any other phone. I use the cig plug pretty frequently for my tire pump during autox/trackdays so I'd rather not block that port.
Idea for 10 Series Owner, but have no idea how to accomplish. IgnitionGundam Cosmetic Modification (Interior/Exterior/Lighting) 9 10-01-2013 12:29 AM
Charging Phone Turns On Air-Bag onepremiere Issues | Warranty | Recalls / TSB 19 09-27-2013 02:23 AM
Twin charging EmeraldMalta Forced Induction 23 06-12-2013 10:09 AM
adding a second usb port for charging? Reason Electronics | Audio | NAV | Infotainment 5 07-11-2012 07:47 AM
Dealers Charging Markup - List Spd229 Southeast 1 05-08-2012 01:22 PM
