Old 11-20-2013, 07:38 PM   #99
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Porsche View Post
I'll bet @Dave-ROR would not have permitted that. Heh.
It depends. I would have inspected the car for bushing, brake line, tire, clutch and fuel line damage. We never let a seriously damaged car run again the same day, but since we do two day events the second day would have been possible. Often that's not because of the car, but because the driver is generally NOT mentally ready for going back out. They need time to process and think about what happened. Now of course that depends on the damage, this was severe. A slide scraping some tire walls is quite different.
I've put cars into walls racing before, gotten towed out, ripped off the body parts (or banged them out), checked the car out and went back out again. A few laps of 5/10ths, then some 7/10ths, then race speed for another hour. :shrug:
I'm not the smartest person around though.
In his case if I inspected the car (as an event organizer) I would have let it out ONLY if I felt safe enough to drive it myself. And I would have driven it around off track to ensure critical systems functioned as intended and warned the driver to drive slower, moved then down a group if possible, and had corner workers watch him like a hawk for a few sessions. Also, it wouldn't have been the same day with the damage sustained for the reasons above.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Porsche (11-20-2013)
Old 11-20-2013, 07:45 PM   #100
OrbitalEllipses
Drives: Attitude
I've had one slow spin like that. I didn't realize until the car was 10 degrees left that it was rotating, the car felt perfectly normal. 100+MPH slide at Sebring. I reacted quickly enough to straighten the car before driving off into the grass though. There's a ton of room at that spot anyways.
Snapping is more dangerous but at least it's OBVIOUS I've had the BRZ snap on me in T1 at Sebring, still not sure how I pulled that one out without a spin/damage.
Heh, I've seen that video.
Old 11-20-2013, 07:58 PM   #101
Pete156
I like to eat!
The only place those POS Primacy tires should be on a race track is being part of the tire wall. Taking a modified car around a race track on THOSE tires is like marrying a hooker. It's just stupid!
My two cents worth
Pete156 is offline   Reply With Quote
The Following User Says Thank You to Pete156 For This Useful Post:
WolfpackS2k (11-21-2013)
Old 11-20-2013, 11:13 PM   #102
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
Out of curiousity, how did you spin off there? Long slide from the kink? Or rotation under braking? I've seen people go straight off T1 and to the left of T1, but never to the right going into T1 (except in a case of oil on the track right after the kink resulting in a loooong slide).
It was rotation under braking...my instructor said I was too hot coming in...I was braking, down shifted, and was just starting to rotate the steering wheel...rear end came loose and spun quickly clockwise.
I need more time on the track and more coaching!
MightyMeeple is offline   Reply With Quote
Old 11-20-2013, 11:57 PM   #103
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Gotcha. Makes sense now
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-21-2013, 02:08 AM   #104
ImAwesome
Drives: 99' M3, 13' SWP Brz
Sorry to hear man, I was there just the saturday-sunday before
ImAwesome is offline   Reply With Quote
Old 11-21-2013, 02:22 AM   #105
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
I want to see your on board GoPro Video!
Maverick22 is offline   Reply With Quote
Old 11-21-2013, 10:06 AM   #106
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
My two cents worth
I disagree. A good driver works with the level of grip available and the Primacy tires still provide more than enough grip to enjoy yourself during a track day.
Old 11-21-2013, 10:24 AM   #107
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Maybe I'm just a shitty driver, but I found these OEM Primacy tires to be highly unpredictable at the limit; couldn't imagine them at the limit WITH a supercharged BRZ/FRS.
I did one day on the OEM Primacys at Sebring and couldn't get rid of them fast enough.
smbstyle is offline   Reply With Quote
Old 11-21-2013, 12:36 PM   #108
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
I appreciate all the above comments. As to a new car I've been brainstorming about that since last week. To be honest I think I'm going to finally pull the trigger on a Cayman S.
The link to it is posted in this thread, don't recall which page exactly. But if you just go to Youtube and type in the key words "BRZ VIR South Bend" it is the first search result.
Old 11-21-2013, 01:16 PM   #109
DarkSunrise
DarkSunrise's Avatar
Where you were pinching it in at turn exit, i.e. applying more steering lock, you needed to be reducing steering lock, turning the wheel clockwise to the straight ahead position. Had you done that -- on the line you'd chosen when turning in too early -- you may well have dropped two or even four wheels off the right side.
Out of curiosity, when you saying "pinching it in at turn exit", are you talking about not unwinding the steering fully on track out? It does look like there was room to track out more fully to the right in that video, which I assume might have prevented a spin.
This is probably the single most common mistake that inexperienced (and even experienced) drivers make. Turn in too early and that means you're going to be running wide at corner exit. Sometimes one may be able to get away with pinching it in at corner exit, but oftentimes not. Do that in Turn 10 on this track and you'll likely visit the left side tire wall.
Again, I cannot overemphasize this, you needed to allow the car to run wide on its "natural line." I urge you to remember to do that next time.
So if you've turned in too early and realize you will run wide at corner exit, I can see you'd want to track out fully to have the best chance of staying on pavement. But if you don't have room to track out anymore and will still run wide, are you saying you shouldn't "pinch in" (assuming I'm understanding that word correctly)? In other words, you shouldn't decrease the amount you unwind the wheel on track out in an effort to keep it on pavement?
I'm asking because I think my natural response in that situation (if by apex I knew I was going to run wide at exit) is to not roll on the throttle on corner exit and to pinch in. And once I got the car positioned correctly, to get back on the throttle. I don't see how this would cause a spin or be dangerous, but I'm probably missing something here.
Sounds like that might be the silver lining to all this. I know you had written about wanting a Cayman S for a while, so this might end up working out for you
2022 BRZ Build
2013 FR-S Build
Old 11-21-2013, 03:22 PM   #110
ja1217
Drives: 2004 Toyota RAV-4 5M
It depends, if you are on the limit going into the corner what you are describing would probably make you more likely to spin, especially if you are easing off the throttle shifting the weight off of the back tires. If you aren't taking the corner at the limit of grip then you can get away with it.
That said, it also depends on the track. For example, if you knew you turned in too early and weren't going to make the corner and you know you're going to end up in a wall on the outside of the turn, I would probably take my chances and turn in harder, possible try and ride out a spin while staying on the track. On this turn at VIR if you go wide there's nothing to hit and you've got a huge grassy area to come to a peaceful stop so it makes sense just to ride it out and avoid spinning. I had to make a similar decision at the bottom of the Esses at this event. Someone had gone off at the top of the Esses and had started a fairly large grass fire. I got distracted by what was going on at the top of the hill and wasn't paying attention to what I was doing and ended up going 2 off and stradling a curb, causing some scraping. That said, some minor scraping is probably better than trying to jerk the car back over that tricky part of the Esses at 100+mph:
ja1217 is offline   Reply With Quote
The Following User Says Thank You to ja1217 For This Useful Post:
Porsche (11-22-2013)
Old 11-21-2013, 04:28 PM   #111
DarkSunrise
Hmm, yeah I can see that. This reminds me, I can remember a similar situation during my last track day. What I ended up doing was staying on maintenance throttle the entire time and slightly "pinching" the corner exit, riding the car out to the very edge of the track curbing nearly to the grass. I think I could have pinched the exit a bit more actually. With just maintenance throttle on track out, the car felt fairly stable, but it's hard to say how close the car was to actually spinning if I had pinched more.
Scary. But agree, minor scraping is much better than spinning at 100+ for sure!
2022 BRZ Build
2013 FR-S Build
Old 11-21-2013, 04:57 PM   #112
WolfpackS2k
Well the thing is, until the rear end started sliding just as I was entering the elevation drop the car was doing just fine, plenty of grip. I wasn't tracking out much to the right during my time on course as I was having a difficult time visually placing that side of the car. I never was concerned about sliding off course to the infield. As I felt the rear sliding I thought thought if I maintained steady inputs it would settle down. Of course, my mind wasn't factoring in the further loss of grip from the elevation drop...so there ya go.
Help with Wrecked SC430 vh_supra26 Other Vehicles & General Automotive Discussions 4 09-27-2013 09:10 PM
Wrecked my FR-S, now can't afford insurance Joetheegyptian Scion FR-S / Toyota 86 GT86 General Forum 272 05-25-2013 06:43 PM
Insurance Estimate Times on Wrecked FR-S's/BRZ's? dale.m Scion FR-S / Toyota 86 GT86 General Forum 16 05-16-2013 09:05 PM
wrecked FRS njccmd2002 Scion FR-S / Toyota 86 GT86 General Forum 16 02-02-2013 01:21 AM
Wrecked FR-S Crash Already - Not Mine ruskymx Scion FR-S / Toyota 86 GT86 General Forum 525 09-07-2012 07:50 PM
