Old 11-19-2013, 08:34 PM   #15
JM9ISM
Drives: 2014 BRZ WRB LTD
- Use a touch up paint
- then wait until it dry
- sand the area to get a smooth surface
- buff it with compound
- good to go
JM9ISM is offline   Reply With Quote
The Following User Says Thank You to JM9ISM For This Useful Post:
iamdaspoon (11-20-2013)
Old 11-20-2013, 01:00 AM   #16
iamdaspoon
iamdaspoon's Avatar
Drives: 2015 Subaru WRX
Thanks for all the help guys, much appreciated.
iamdaspoon is offline   Reply With Quote
Old 11-20-2013, 01:01 AM   #17
iamdaspoon
iamdaspoon's Avatar
Originally Posted by Kwisak View Post
If you take a pic of it from father back it would help, but if its where i think it is get the rear spats / OEM style mud flaps
I will as soon as I get the chance, thanks.
Old 11-20-2013, 11:40 AM   #18
Kwisak
Kwisak's Avatar
Drives: 2013 BRZ GBS
I know another guy on the forum had a similar problem and got some OEM style rear spats that covered it up nicely, it really looked good and since it was only a 40$ fix with ebay OEM style replicas
Kwisak is offline   Reply With Quote
Old 11-20-2013, 04:00 PM   #19
iamdaspoon
iamdaspoon's Avatar
Here's the scratch from farther away
Old 11-20-2013, 04:41 PM   #20
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
if you feel scratch by your finger nail, you can't fix it with any super duper "Scratch X" type of liquid/paste wax. touch up will make it better but you will see difference between original paint and touch up.
to fix that, you need to paint whole bumper again.
I would get rear spat that covers that area or ignore until get it repainted.
Old 11-20-2013, 07:52 PM   #21
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Any quality shop could easily feather it out and blend WITHIN the panel. So you would only have additional clear on the top edge of the bumper. The scratches are far enough down to where they wouldn't need to blend into the quarter panel at all. If they do suggest it, in this case I'd say they are trying to get more work/money.
If your going to fill the scratches in you will not get a perfect match. The way the flakes in the silver paint will lay (and reflect) differently causing the repair to be noticeable. 2ft back any you won't notice. It's on plastic so you don't have to worry about rust so the quick repair maybe the way to go if it doesn't bother you.
STI styled spats do look like they would cover it though :P Bayson R (ebay) just released their knockoff for under a third of the original STI part cost.
Originally Posted by boxer 2.5 View Post
Sigh. Body panel filler, sand it. Body panel filler, sand it. Primer, sand it. Self etching primer. Base coat paint. Second coat of paint. Third coat of paint, sand it. Base clear coat paint. Second clear coat paint, wet sand it. Third clear coat paint, wet sand it. Buff it. Wax it.
Silver blends easily compared to many other colors. Just go paint color-match sites and order a spray can. This total process should take about 6-7 hours with drying time.
Self-etching primer is to only be applied to bare metal surfaces.
Old 11-21-2013, 02:39 AM   #22
boxer 2.5
Drives: 2007 Impreza, 2013 BRZ
You are correct. +1 to you sir. I mistook it for the quarter panel.
boxer 2.5 is offline   Reply With Quote
Old 11-21-2013, 02:35 PM   #23
MikeW
MikeW's Avatar
Drives: 2013 BRZ | 2013 WRX | 1991 318i
Just stand in front of it when you show the car to Carmax.
MikeW is offline   Reply With Quote
Old 11-22-2013, 11:13 AM   #24
gily25
Drives: Silica BRZ 6MT
After seeing the scratch, definitely start with rubbing compound, it's probably only 1/4 as bas it looks, all the white will probably rub out, leaving just the small black lines which you can touch-up.
gily25 is offline   Reply With Quote
Old 11-22-2013, 11:38 AM   #25
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Like others have said:
[ame="http://www.amazon.com/Meguiars-G10307-Scratch-X-2-0/dp/B0002UNON8"]http://www.amazon.com/Meguiars-G10307-Scratch-X-2-0/dp/B0002UNON8[/ame]
Clean and dry the area, then use something like that on it, then a little water and dry it with a soft cloth. Use touch-up paint, but don't overfill the scratches and let that dry for a day or so. After that, rebuff with Scratch-X, finish filling scratches with touch-up paint, let dry for another day and then buff it out again with the Scratch-X.
That should get it looking pretty good. I've always had pretty good success with touch-up paint and a good quality rubbing compound.
alexand3r is offline   Reply With Quote
Old 11-24-2013, 02:41 AM   #26
iamdaspoon
iamdaspoon's Avatar
I think I'm going to go with getting the spats, I really like the way they look.
Old 11-29-2013, 05:46 AM   #27
Apex-Wolf
Apex-Wolf's Avatar
Drives: Ultramarine Scion FR-S
http://www.ft86club.com/forums/showthread.php?t=17698
That guy had is way worse and look how well it turned out, Try it out on your spare time worst comes to worst you're dad forks over $50 for the materials that you bought to try to repair it yourself. Good Luck!
Apex-Wolf is offline   Reply With Quote
Old 11-30-2013, 12:04 AM   #28
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
^Holy hell!
Kuri is offline   Reply With Quote
damage, fix, paint scratched, scratch
Scratch Removal? feldy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 05-15-2014 10:12 PM
First scratch pituala Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 05-07-2014 03:58 AM
Scratch Right After Opti kaitak98 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 08-16-2013 08:46 AM
Will this little scratch buff out? sho220 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 22 04-05-2013 10:45 AM
Scratch Repair Tdot CANADA 9 01-14-2013 12:02 PM
