Old 11-20-2013, 09:27 AM   #15
DarkSunrise
DarkSunrise's Avatar
Burnt clutch in 4800 miles would seem to indicate some kind of mechanical failure, especially if you've got a lot of experience driving manuals (and assuming you're not abusing the clutch). I'd escalate this as far up the chain as possible.
2022 BRZ Build
2013 FR-S Build
Old 11-20-2013, 09:41 AM   #16
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by fistpoint View Post
No they didn't. The software was found to be riddled with inefficiencies and bad/lazy programming. Do some more reading into it.
The software issue had nothing to do with "unintended acceleration".
The reason unintended acceleration is ALWAYS a driver error is you should just select neutral and, if necessary switch off the engine.
This is why neutral can be selected without pressing the brake pedal in all automatics.
The same dufous who doesn't know this also can't tell the brake pedal from the accelerator. Misapplication of pedals is a well known phenomenon especially among driving instructors. Software does not cause throttles to open, the systems are redundantly fail safe. The same technology as fly by wire airliners use and military aircraft and trains etc etc.
In olden days throttles used to stick open, return springs broke or fell off, throttle plates iced up or linkages broke. To be competent to drive safely you needed to know what to do if this happened to you: select neutral (or push in the clutch) and switch off. In those days the engine would explode if you didn't switch off, nowadays the rev limiter just cuts in so you have lots of time to switch off.
Bottom line: the speed of the car is ALWAYS up to the driver.
This post may save your life someday.
Suberman is offline   Reply With Quote
The Following 3 Users Say Thank You to Suberman For This Useful Post:
choi0706 (06-29-2014), clayrush (11-24-2013), SoCal909 (11-24-2013)
Old 11-20-2013, 10:33 AM   #17
pche
Guy on internet
Drives: Slowly
Agree, however, shutting off the engine you also lose power steering and power brakes, just something to keep in mind. Turn off the engine once you have slow down and steer clear of danger.
pche is offline   Reply With Quote
Old 11-20-2013, 10:36 AM   #18
FastOnFastOff
Drives: FR-S Asphalt/ CBR 1K
Thanks for the feedback guys. To shed some light, I do drive harder than merely commuting. I do not drift the car (purposely). It's gone to the canyons 15+ times and WSIR once. Over the phone, I was told that the clutch was "fried". That being said, I think the proper moral thing to do is to pay the bill.
I was under the impressions that these cars could be driven hard - not abused - but at least driven hard.
FastOnFastOff is offline   Reply With Quote
The Following User Says Thank You to FastOnFastOff For This Useful Post:
tdog227 (11-21-2013)
Old 11-20-2013, 10:40 AM   #19
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
But what you described was a broken clutch (pedal on the floor).
Ralph Spoilsport is offline   Reply With Quote
The Following User Says Thank You to Ralph Spoilsport For This Useful Post:
Panman (11-24-2013)
Old 11-20-2013, 10:43 AM   #20
nate89
nate89's Avatar
Drives: MR2
A proper break-in for the clutch will also help extend the service life. So take it easy for the first 500 miles on your new clutch.
nate89 is offline   Reply With Quote
The Following User Says Thank You to nate89 For This Useful Post:
FastOnFastOff (11-20-2013)
Old 11-20-2013, 11:11 AM   #21
hmmm.......a "fried" clutch, to me, is one that has been warn down to almost nothing or "overheated" ..... usually caused by the clutch being out of adjustment or riding the clutch or pulling a trailer or it was just plain old. Also, intentially slipping a clutch can take a toll.
Your canyon carving or a day at the track shouldn't wear out a clutch on the FR-S (non-boosted).
The Following 6 Users Say Thank You to humfrz For This Useful Post:
Carwhisperer (11-20-2013), CSG Mike (11-20-2013), FastOnFastOff (11-20-2013), GT 86 Brah (11-24-2013), Marchy (11-20-2013), strat61caster (11-20-2013)
Old 11-20-2013, 12:23 PM   #22
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
They have been, like humfrz said unless there's something wrong with the system (not fully engaging or something) there's no reason for it to have failed this early (unless you know you've been abusing it).
I think I've seen a grand total of 4 threads about premature clutch failure (admittedly not in the track section), it's hard to tell if it's from abuse or not but your case is abnormal. I'd be looking into it more aggressively, but if $1600 is a small price to pay to get the monkey off your back and get back to things that matter it's understandable. Most of the people who bought this car were not expecting $1,000+ repair bills within the first two or three years of ownership (hell I'm looking at spending less than $200/year plus tires and gas), you're going to see a lot of resistance for shelling out the money.
If it was my car, I'd be doing the repair myself, but I'm insane.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
FastOnFastOff (11-20-2013), Tgionet (11-20-2013)
Old 11-20-2013, 01:09 PM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Tell them you want to see the "fried" clutch. If it didn't fail due to wear, then in my mind it should be covered under warranty.
sierra (11-22-2013)
Old 11-20-2013, 01:34 PM   #24
jeebus
That all sounds bogus to me. I drive my car plenty hard, done a number of Autoxes, my commute is through canyons, etc, etc...25k miles clutch feels fine.
jeebus is offline   Reply With Quote
The Following User Says Thank You to jeebus For This Useful Post:
Old 11-20-2013, 03:29 PM   #25
FastOnFastOff
Yea, it felt broken because what I described is exactly how it went down with the clutch sticking to the floor. If it was fried, shouldn't I have at least smelled something?
Old 11-20-2013, 03:31 PM   #26
FastOnFastOff
For sure I'll ask. They already offered to show it to me.
Old 11-20-2013, 03:37 PM   #27
FastOnFastOff
For me it's primarily a time-issue. If I had the time (the ability to live without a car), I'd be much more aggressive. $1600 is not small for me, but just at the point where I think waving the white-flag is the better option. I should be getting the car back tomorrow or Friday at the latest.
Old 11-20-2013, 03:41 PM   #28
mike the snake
They can tell if the clutch is "fried", usually the plate shows signs of slipping/heat, as well as the flywheel, which will show signs of being abused or being burnt up.
Sounds to me like your clutch hydraulic line may have lost pressure. This would cause the pedal to go to the floor, and with subsequent pumping, might get you half of it back.
It might be as simple as tightening a loose fitting and rebleeding the system.
Did they tell you what failed on your clutch? I would think, that even with abuse, it would be pretty hard to burn up or break a clutch in 4800 miles.
I would stand your ground, go higher up the food chain, and get them to replace whatever's broken.
Good luck!
The Following 2 Users Say Thank You to mike the snake For This Useful Post:
FastOnFastOff (11-21-2013), strat61caster (11-20-2013)
exploding clutch
Brz just broke 1k miles, clutch begins to feel grindy rourich Northern California 14 10-11-2013 04:16 PM
Burnt Tips Reggaeboyz Cosmetic Modification (Interior/Exterior/Lighting) 11 09-15-2013 10:58 PM
Faint Clutch Smell - 6,000 Miles FnFast Issues | Warranty | Recalls / TSB 8 08-16-2013 04:17 PM
700 Miles Blown Clutch Bonburner Issues | Warranty | Recalls / TSB 76 09-23-2012 09:32 PM
5k~ Miles - Clutch with extreme broken glass noise Pscylo Issues | Warranty | Recalls / TSB 11 08-30-2012 01:12 AM
