Old 11-19-2013, 01:24 AM   #1
iamdaspoon
iamdaspoon's Avatar
Drives: 2015 Subaru WRX
What to do about this scratch?
Hello, I'm new to this forum and new to owning a BRZ. Unfortunately I let my father use my car to go to the store, and when he returned, backed into my drive way and scratched my rear driver side bumper/fender. The scratch is right by the tire and looks to be pretty deep.
Hopefully it won't be too difficult/expensive to fix, but I was wondering what you guys think I should do to fix it, I've learned a lot from this forum so any input is appreciated, Thanks.
Edit: Image is sideways and the host site doesn't offer a way to turn it but its supposed to be turned 90 degrees clockwise
iamdaspoon is offline   Reply With Quote
Old 11-19-2013, 01:48 AM   #2
kALMIGHTY
Drives: TRD Ultramarine '13
Car is totalled.
The Following 8 Users Say Thank You to kALMIGHTY For This Useful Post:
Bad Habits (11-26-2013), BRZBlack (11-25-2013), HunterGreene (11-19-2013), infinite012 (11-19-2013), JDM FRS (11-19-2013), mwjcyber (11-22-2013), suaveflooder (11-19-2013), TONYpepperon1 (11-22-2013)
Old 11-19-2013, 01:53 AM   #3
arashishozen
Guest
Posts: n/a
wont be cheap. insurance deductible and body shop is the way to go.
Old 11-19-2013, 01:55 AM   #4
JDM FRS
JDM FRS's Avatar
Drives: Scion FRS(Whiteout)
Id just use touch up paint. But if he we paying for it I'd just get an estimate.
Sent from my HTC One using Tapatalk 2
JDM FRS is offline   Reply With Quote
Old 11-19-2013, 01:56 AM   #5
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
It hasn't yet penetrated the primer. Consistent prayer till morning should patch it right up.
tech4pdx is offline   Reply With Quote
The Following User Says Thank You to tech4pdx For This Useful Post:
DoomsdayJesus (12-30-2013)
Old 11-19-2013, 03:11 AM   #6
boxer 2.5
Drives: 2007 Impreza, 2013 BRZ
Sigh. Body panel filler, sand it. Body panel filler, sand it. Primer, sand it. Self etching primer. Base coat paint. Second coat of paint. Third coat of paint, sand it. Base clear coat paint. Second clear coat paint, wet sand it. Third clear coat paint, wet sand it. Buff it. Wax it.
Silver blends easily compared to many other colors. Just go paint color-match sites and order a spray can. This total process should take about 6-7 hours with drying time.
boxer 2.5 is offline   Reply With Quote
Old 11-19-2013, 04:38 AM   #7
Djratrap
Drives: BRZ CSB Limited
I had a scrape on my lip similar to this one. Sameday will do it for about 200 bucks and it will look as good as new.
Djratrap is offline   Reply With Quote
Old 11-19-2013, 07:28 AM   #8
dehydratedH2O
Drives: 2014 BRZ Limited DGM
That's all the way into the plastic. Gonna want basic touch up if you're going cheap, or a respray/blend from a body shop if you really want it fixed back to new.
dehydratedH2O is offline   Reply With Quote
Old 11-19-2013, 08:47 AM   #9
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
a Sticker.
And you get +5whp.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
The Following 5 Users Say Thank You to Figo For This Useful Post:
akahenry (12-31-2013), ExtremeAutowerks (11-19-2013), iamdaspoon (11-20-2013), JDM FRS (11-19-2013), NWFRS (11-19-2013)
Old 11-19-2013, 10:27 AM   #10
red bread
Drives: Mazda 3
Do not take it to a body shop. The odds of it matching are very low and they'll want to blend into the surrounding area to try to cover that. This makes it extremely easy to use a paint thickness gauge to determine that the area has been resprayed.
You could add touch up paint and lots of clear to build up the area and then color sand the snot out of that area, but that's a lot of work, your best approach is probably to contact a paintless dent guy and see if they are or know a good airbrusher. A good airbrusher should be able to get that back to a state where only you can tell it's there.
Mazda 3 and a BMW X1 35i
Previous - 2008 135i, 2000 M Coupe, 1999 Miata
red bread is offline   Reply With Quote
Old 11-19-2013, 11:07 AM   #11
Kwisak
Kwisak's Avatar
Drives: 2013 BRZ GBS
If you take a pic of it from father back it would help, but if its where i think it is get the rear spats / OEM style mud flaps
Kwisak is offline   Reply With Quote
Old 11-19-2013, 12:25 PM   #12
gily25
Drives: Silica BRZ 6MT
You can always start with rubbing compound and see how deep that scratch actually goes. There is a thread here where a member fixed an FRS bumper with aerosol touch-up paint and it looked good in the pictures. The problem is that this is different from his repair in that you can see the rest of that side of the car, but it's up to you if you want to try to fix it that way.
I would check the body shops for the major dealer chains in your areas. A lot of times they'll have new techs doing these kinds of repairs and they'll out out sandwich board type signs to advertise discount bumper repairs. You'll get a quote and go from there. If it's more than your father wants to pay then you'll go through your collision/insurance. I'd say it'll be worth having professionally repaired.
gily25 is offline   Reply With Quote
The Following User Says Thank You to gily25 For This Useful Post:
Old 11-19-2013, 12:53 PM   #13
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Rocket Bunny kit.
NWFRS is offline   Reply With Quote
The Following User Says Thank You to NWFRS For This Useful Post:
Old 11-19-2013, 05:36 PM   #14
ExtremeAutowerks
ExtremeAutowerks's Avatar
Drives: Scion FRS
Originally Posted by Marchy View Post
have your dad fork over a couple hundred bucks, apply some touch up paint, put a sticker on it, buy case of beer and enjoy with dad while you both laugh over how he can't drive.
I love this reply, good idea.
ExtremeAutowerks is offline   Reply With Quote
The Following User Says Thank You to ExtremeAutowerks For This Useful Post:
Marchy (11-19-2013)
damage, fix, paint scratched, scratch
Scratch Removal? feldy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 05-15-2014 10:12 PM
First scratch pituala Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 05-07-2014 03:58 AM
Scratch Right After Opti kaitak98 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 08-16-2013 08:46 AM
Will this little scratch buff out? sho220 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 22 04-05-2013 10:45 AM
Scratch Repair Tdot CANADA 9 01-14-2013 12:02 PM
