Old 11-18-2013, 05:23 PM   #99
jeebus
Originally Posted by shiv@vishnu View Post
If you run your gasoline down to E (so at least the low fuel light comes on) and then fill up with E85, you will be golden. Over the next few days I'm going to test how sensitive/tolerant the tune is to e85/gasoline mixes. I suspect it will be happy with running a few gallons of gasoline in there because straight E86 is overkill as far as octane/cooling go. I will report my findings.
Shiv
When my tank hits the E mark and low fuel light comes on, it only takes around 10, sometimes 10.5 gallons to fill to the top. The tank is 13.2 gallons, so there could be 3 full gallons of gasoline in the tank at that time. Assuming the corn juice you fill up with is 100% e85, that would net you something more like e68. If the corn juice is e70 you'd be down to e56. I did this based on using gasoline with 10% alcohol content already.
jeebus is offline   Reply With Quote
The Following User Says Thank You to jeebus For This Useful Post:
Cross (11-18-2013)
Old 11-18-2013, 05:44 PM   #100
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
That's totally fine. Doesn't need to be e85. I've gone as low as e65 without any issue. I'm going to test even lower this week.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Cross (11-18-2013)
Old 11-18-2013, 06:16 PM   #101
jeebus
Good to know. Do you put the e85 in and then drive slowly and do some mini slaloms to mix the fuel up?
Can't wait to try it.
Old 11-18-2013, 10:33 PM   #102
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
New e85 maps available: E85 Thread
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Shiv@Openflash (11-18-2013)
Old 11-26-2013, 12:45 PM   #103
Robert@Openflash
Robert@Openflash's Avatar
Drives: C6 Z06
Enjoy your drive back down to SD. Its too bad I wasn't able to meet you in person. Next time!!!!
Originally Posted by Sojhinn View Post
If it's any conciliation you guys are making my drive from sf to San Diego awesome.
Robert@Openflash is offline   Reply With Quote
Old 11-26-2013, 12:49 PM   #104
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Definately! Shiv pretty much convinced me for that header. I want!
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Robert@Openflash (11-26-2013)
Old 11-26-2013, 01:04 PM   #105
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Yes. Changes rpm breakpoints and set last row equal to 0 deg. I suppose to the uninformed that could look like an error in table address. Perhaps this is the reason behind Visconti's comment?
Bingo. I've compared the addresses to the rom, nothing's out of place.
Td-d is offline   Reply With Quote
The Following 4 Users Say Thank You to Td-d For This Useful Post:
DAEMANO (11-26-2013), Robert@Openflash (11-26-2013), s2d4 (11-26-2013), Shiv@Openflash (11-26-2013)
Old 11-26-2013, 01:09 PM   #106
mid_life_crisis
Drives: FR-S 10 #103 AT
Oh, you are good.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
Old 11-26-2013, 01:10 PM   #107
Shiv@Openflash
Drives: 2013 FRS
Thanks for the confirmation Td-d. When putting together these XDFs I do everything visually/manually through string searches and pattern finding. So I'm always open to the possibility of there being errors. But I do test the maps out quite thoroughly so I found it surprising that Visconti would uncover something unexpected. But I'd like to thank him and the Ecutek community for bringing what *he thought* was a error to the attention of the community (if not myself)
Best Regards,
Shiv
The Following 4 Users Say Thank You to Shiv@Openflash For This Useful Post:
Cross (11-26-2013), DAEMANO (11-26-2013), WRB5titch (11-26-2013), YMAA (11-26-2013)
Old 11-26-2013, 01:22 PM   #108
Td-d
So, storm in a teacup aside , I find it interesting that you've opted for an ignition cut based approach, as opposed to a requested torque tapering (the other method I've seen in action). Any advantage, or just coming at the problem from a different angle?
Old 11-26-2013, 01:29 PM   #109
Shiv@Openflash
Drives: 2013 FRS
Just a different angle. With this approach I can induce what appears to be a soft limit that slowly transitions to a hard fuel cut if you stay on the throttle for another 2-3 seconds. I do like to keep throttle open as much as possible (hence the ignition only cut). Perhaps this a personal bias from all the turbo tuning we have done (don't want to dump that precious boost!)
The Following 6 Users Say Thank You to Shiv@Openflash For This Useful Post:
bakerr6 (11-27-2013), DAEMANO (11-26-2013), s2d4 (11-26-2013), Td-d (11-26-2013), WRB5titch (11-26-2013), yuicebox (11-26-2013)
Old 11-26-2013, 01:33 PM   #110
yuicebox
Drives: Asphalt FRS
@Visconti is this what you were referring to? Seems like a misunderstanding
Sent from my SAMSUNG-SM-N900A using Tapatalk
yuicebox is offline   Reply With Quote
The Following User Says Thank You to yuicebox For This Useful Post:
Visconti (11-26-2013)
Old 11-26-2013, 01:53 PM   #111
Sojhinn
Sojhinn's Avatar
Btw- esc 223hp / 200 tq on e85. Muhahahaha!
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
1086 (11-26-2013), Robert@Openflash (11-26-2013)
Old 11-26-2013, 04:39 PM   #112
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Hooray!!!!!!
Have you hit 200whp NA? empower-auto Engine, Exhaust, Transmission 323 11-26-2015 07:49 PM
2013 for $1200 off msrp AllStar0419 Scion FR-S / Toyota 86 GT86 General Forum 21 08-26-2013 05:00 PM
Dyno take 2, 200whp on 92Octane ?! AJ PwR Engine, Exhaust, Transmission 76 07-31-2013 02:14 AM
Bespoke upgrade = $1200? madpcsupreme Electronics | Audio | NAV | Infotainment 4 06-13-2013 10:19 AM
