Old 10-24-2013, 09:42 PM   #211
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
I have an event on Saturday. I'm going to try and replicate it then pull fuze to see the difference.
Ryaquinn is offline   Reply With Quote
Old 10-24-2013, 09:58 PM   #212
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
Originally Posted by TylerLieberman View Post
Yes reverie rake is having the front higher than the rear. Clutch kick works best of initiating in my opinion. It won't scrub your speed like handbrake does. If the first corner is a 90 degree turn or a hairpin and you have a good amoun of run up, I would use handbrake on the straight coming up to the corner to set the angle.
Anything between like 50-75mph, I initiate 3rd. Higher or lower uses different gear. You want mid 3rd for clutch kick. If you're redline in 3rd and you're gonna clutchkick, I would just upshift again and then handbrake in 4th and drop down to 3rd
Thanks for this info. Can't wait for my next event to try this.
JordanWho is offline   Reply With Quote
Old 10-24-2013, 10:08 PM   #213
JordanWho
JordanWho's Avatar
Originally Posted by DarkCard View Post
Question for you guys, I'm fairly new as well. Im getting alot better modulating my throttle control where I can hold a slide in a circle, when I try to make a transition from say a left to right Im snapping the car too hard and ultimately spin out. How can I fix this?
Just get on a skid pan with two cones at either end and try and drift around one then hold the drift until you feel the cars weight transfer and then go the other way around. It's hard to explain but you just need to get on a skid pan and keep at it until you get it. It will happen....
This is a video of me on a skid pan when I was still learning. The day this video was filmed, I didn't know how to link corners in the morning, then this was captured that evening. You'll get it, you just need to practice.
[ame="http://www.youtube.com/watch?v=WFgaq8wsgqM"]Toyota 86 on QR skidpan - YouTube[/ame]
The Following User Says Thank You to JordanWho For This Useful Post:
Freshfrs86 (11-05-2013)
Old 10-31-2013, 02:02 AM   #214
philstar
philstar's Avatar
Drives: Argento FR-S
I usually pull the ABS fuse before doing any serious drifting.
picture from an event the other weekend
philstar is offline   Reply With Quote
The Following User Says Thank You to philstar For This Useful Post:
Old 11-05-2013, 01:45 AM   #215
executivekoala
executivekoala's Avatar
Drives: fr-s
I need some advice, I've found a nice empty lot near my house I have been using to practice and I have been clutch kicking at 2nd gear at 4k rpm or around 45mph and it seems like half way through my drift i lose low end tq and I slow down a lot, any advice?
executivekoala is offline   Reply With Quote
Old 11-05-2013, 09:21 AM   #216
BoostinIX
Gettin SIKKY sideways
BoostinIX's Avatar
Drives: '97 S14.5 / '13 BRZ
Send a message via AIM to BoostinIX Send a message via Yahoo to BoostinIX
Kick again. Multiple kicks is common in lower power.
Instagram: BoostinIX
BoostinIX is offline   Reply With Quote
The Following User Says Thank You to BoostinIX For This Useful Post:
noodles (11-06-2013)
Old 11-14-2013, 12:39 PM   #217
namdoog
Drives: Crystal Black Silica BRZ
Originally Posted by Ryaquinn View Post
Thought I might start in this thread:
I have been using the pedal dance every time I go to the track. I usually do 2-3 all day events a month. I have been having an issue with the gauges at the last two events. Last week event mid day after a run I had the stability light and ABS light come on. Turned the car off and all went away. Didn't have any other issues for the rest of the day. Did an event yesterday and same thing happened mid day, but it turned off on its own after about twenty seconds on the course.
I had the ECU replaced last year after the CEL came on during a track event and put the car in limp mode not letting me adjust TCS or stability.
Has anyone been having issues like this so far? Let me know if I need to explain more.
FWIW I just pull the ABS fuse instead of dealing with the pedal dance. Just put the fuse back in at the end of the day and have not had any issues.
namdoog is offline   Reply With Quote
Old 11-17-2013, 08:35 PM   #218
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Increased my front camber from -1.5 to -4.5. A little extreme but the difference was amazing with transitions. I was able to pull out some third gear bank drifts. [ame]http://youtu.be/cv6J8_BQkKY[/ame]
The Following User Says Thank You to Ryaquinn For This Useful Post:
chris x sway (11-26-2013)
Old 11-17-2013, 08:41 PM   #219
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
^^ Front camber is amazing for drifting. I run -3 up front now. Once I get the new knuckles installed, I'll end up going to probably -4 and increase caster from 5.9 to 7 degrees.
That track looks kind of fun. Nice bank with a tight infield section
Old 11-17-2013, 09:00 PM   #220
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
It's amazing how easy this car is to work on, even coming from a 240. ARP wheel studs, BBK, and race seat are next. Best mods for drifting so far was the trailer hitch setup for tires though 😉
The Following 3 Users Say Thank You to Ryaquinn For This Useful Post:
JordanWho (11-18-2013), Justin91M (12-15-2013), powerj2 (04-07-2014)
Old 11-18-2013, 03:42 PM   #221
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
http://s867.photobucket.com/user/Ala...11f43.mp4.html
Here's the course, really high banked short circle
Mini Cooper S (09-06-2014)
Old 11-19-2013, 09:18 AM   #222
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
@JordanWho are those 17" or 18" regas? I know they made 18 but they're even more rare.
Enraged21 is offline   Reply With Quote
Old 11-19-2013, 01:15 PM   #223
Lanbaldo3
Divine Wind - Dori
Lanbaldo3's Avatar
Drives: RWD
anyone going to the last Fatlace Word up event in norcal?
1990 FC3S T2swapped! "Savannah"
1992 240sx Type X "Nadia"
2013 Scion FRS "Raven"
Drift Specials.....
Lanbaldo3 is offline   Reply With Quote
Old 11-19-2013, 01:26 PM   #224
JordanWho
JordanWho's Avatar
I'm running 17". I wish I could find 18" because my PMU BBK doesn't fit under these 17's unless I'm running 30mm spacers.
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
