Old 11-17-2013, 07:05 PM   #15
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by Malt View Post
Ground clearance is 4.9" on a stock BRZ... so you are saying you have less than 1" of ground clearance on your street driven BRZ?
Give or take, yes sir
Sent from my IBrick
Old 11-17-2013, 07:08 PM   #16
Malt
Drives: 2015 WRX
wow, that's pretty low. Not my cup of tea but impressive none the less. I bottom out going to my parents house if I'm not careful and I'm not lowered at all. No way I could get away with that.
How's the ride that low. It must be bone shatteringly hard.
Malt is offline   Reply With Quote
Old 11-17-2013, 07:12 PM   #17
SmsAlSuwaidi
Boosted
To be honest this is my first slammed (kinda) car and I love trying new things. It's a love and hate thing. I love how the car looks but I hate harming it ( scraping here and there) the car is drive able and I use it, but I'm raising the car, changing the rims and boosting it soon.
The drive is very very stiff but I like it and you can easily get used to it
Oh and I do get stuck every weekend visiting family
Sent from my IBrick
Old 11-17-2013, 07:30 PM   #18
MAPerformance
Drives: Asphalt FRS
Sent from my IBrick
Looks like we will just have to make a dry sump for you instead.
MAPerformance is offline   Reply With Quote
Old 11-17-2013, 07:34 PM   #19
SmsAlSuwaidi
Boosted
! Hell No I'd rather raise the car
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
MAPerformance (11-17-2013)
Old 11-17-2013, 07:39 PM   #20
mike the snake
Those are VERY cool wheels you have there. Can I ask what they are, make/model/size?
Old 11-17-2013, 08:11 PM   #21
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
It will likely bend, not crack.
Yeah but is uncovered in the middle, and I'm over 4"s dropped so I have bottomed out pretty bad so couple of times and I would try and check if it's done or not
Sent from my IBrick
The Following User Says Thank You to EAGLE5 For This Useful Post:
SmsAlSuwaidi (11-17-2013)
Old 11-17-2013, 08:54 PM   #22
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
This will hold about 1qt more oil, but will not sit any lower than the factory pan.
Nope, I'm lost. I thought the increase in capacity comes from lowering the oem oil pan.
Old 11-17-2013, 08:59 PM   #23
MAPerformance
Drives: Asphalt FRS
You missed the part where I mentioned that the pan is more square rather than tapered like the OEM pan. We have a prototype mold of our pan, and it did fit about a quart more oil. It will hopefully make more sense when we have a better pic of it once it starts coming together.
The Following User Says Thank You to MAPerformance For This Useful Post:
Captain Snooze (11-17-2013)
Old 11-18-2013, 12:13 PM   #24
MAPerformance
Drives: Asphalt FRS
Updated photos
OK, got some more fabrication done today and mocked up in the car. I found out that this WILL NOT work with the OEM header, but should work with most aftermarket N/A header's and turbo manifolds. I don't know yet if we will produce one for the OEM header yet. But if there is a big enough demand, I don't see why it would be a problem. We still have to fabricate the drain plug and oil feed line bungs yet, and for those who asked it will be baffled. I will get pictures of that when its completed. But so far it's coming along nicely.
Calum (11-18-2013)
Old 11-18-2013, 12:34 PM   #25
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
So how do you drain your oil properly if there is no slope for the oil to flow down?
Old 11-18-2013, 12:36 PM   #26
SmsAlSuwaidi
Boosted
Looks slanted to the right or I might be sleep deprived
Sent from my IBrick
Old 11-18-2013, 12:39 PM   #27
MAPerformance
Drives: Asphalt FRS
We are going to taper it in the back slightly for the drain plug. This is just a rough fab to check fitment. Ill get more pics as it develops.
Team STILLEN (11-18-2013)
Old 11-18-2013, 07:21 PM   #28
ciro
Drives: Scion FR-S
looks good, I wonder what the stealership would say if I got an oil change with this pan...
ciro is offline   Reply With Quote
The Following User Says Thank You to ciro For This Useful Post:
MAPerformance (11-18-2013)
Exedy BRZ specs sheet ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 2 11-07-2012 09:56 PM
build sheet jmaryt Scion FR-S / Toyota 86 GT86 General Forum 0 09-14-2012 09:55 PM
FT86/FRS Data Sheet WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 62 11-27-2011 04:12 AM
The Subieyota Is Under This Sheet ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 42 11-23-2010 08:42 PM
