Old 11-15-2013, 06:42 PM   #1
MAPerformance
Drives: Asphalt FRS
MAP Aluminum Oil Pan / +1.5qt Capacity / Turbo Oil Return / Available now!
Hey guys! Our sheet metal oil pan is now ready to be installed in your FRS/BRZ. Features a grooved billet plate, two extra bungs (one for an oil return line, and one for an optional oil temp or pressure gauge) and extra 1.5 quart holding capacity, as well as a built in baffle. Price will be $320 shipped in the continental U.S, and will feature our lifetime warranty. Please note, these will NOT fit with the OEM header. We are still interested in finding people to test these on other force inducted kits as well as N/A headers. Please PM me for more info on that.
Detailed specs:
  • 3/8" NPT bung for turbocharger oil return
  • Additional 3/8" NPT bung for oil temperature sensors or secondary return
  • 1.5 quarts of additional oil capacity ensures consistent supply to the pickup and helps reduce oil temperatures
  • Factory style drain tubes to avoid oil aeration and foaming
  • Integrated baffle reduces oil slosh and the potential for oil starvation
  • Each pan is pressure checked and includes a lifetime guarantee against leaks!
  • Includes replacement oil pan to block hardware (Not pictured)
Update 11/18
MAPerformance is offline   Reply With Quote
The Following User Says Thank You to MAPerformance For This Useful Post:
EvilBeaverFace (11-16-2013)
Old 11-15-2013, 06:56 PM   #2
White64Goat
Well, as long as the extra capacity doesn't cost $900 (Cusco rear end cover) you may have some interested people.............
Old 11-15-2013, 06:56 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
Nice.
Are you planning on making a windage tray to go with it?
The Following User Says Thank You to Calum For This Useful Post:
RD1428 (11-18-2013)
Old 11-15-2013, 06:57 PM   #4
MAPerformance
Drives: Asphalt FRS
The plan is for it to not cost $900...
jamesm (11-15-2013)
Old 11-15-2013, 08:21 PM   #5
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Would this be less prone to cracking too ? As I'm lowered and always have the fear of cracking mine not fun....
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
MAPerformance (11-16-2013)
Old 11-16-2013, 06:29 AM   #6
Turdinator
Señor Member
Turdinator's Avatar
By making it square won't you interfere withn most exhaust manifolds currently on the market?
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Old 11-16-2013, 10:15 AM   #7
MAPerformance
Drives: Asphalt FRS
I'll ask my fabricator if this piece will be stronger.
Old 11-16-2013, 10:17 AM   #8
MAPerformance
Drives: Asphalt FRS
That is a very good question. I own the RevWorks header right now, so we will try it with that and my OEM manifold, along with our turbo manifold. But I will bring this topic up to my engineers on Monday.
Turdinator (11-16-2013)
Old 11-17-2013, 11:11 AM   #9
Calum
That Guy
Originally Posted by Calum View Post
Nice.
Would you mind answering this?
Old 11-17-2013, 11:58 AM   #10
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Not gonna crack...
The stock oil pan will take a MASSIVE hit without cracking. It will deform A LOT without cracking. There's also a big metal undertray protecting it. You're worrying about nothing.
The Following User Says Thank You to EAGLE5 For This Useful Post:
MAPerformance (11-17-2013)
Old 11-17-2013, 12:05 PM   #11
EAGLE5
Dismember
EAGLE5's Avatar
Winage tray?
Nice.
Here is a shot from Crawford, I think, of the block with the oil pan removed. You can see that there's already a baffle up here, so I cannot imagine a windage tray doing anything.
https://sphotos-b.xx.fbcdn.net/hphot...34247031_o.jpg
Calum (11-17-2013)
Old 11-17-2013, 04:33 PM   #12
MAPerformance
Drives: Asphalt FRS
Not at all. I just have to talk to them when I get into the office tomorrow.
Calum (11-17-2013)
Old 11-17-2013, 07:06 PM   #13
SmsAlSuwaidi
Boosted
Yeah but is uncovered in the middle, and I'm over 4"s dropped so I have bottomed out pretty bad so couple of times and I would try and check if it's done or not
Sent from my IBrick
Old 11-17-2013, 07:57 PM   #14
Malt
Drives: 2015 WRX
Sent from my IBrick
Ground clearance is 4.9" on a stock BRZ... so you are saying you have less than 1" of ground clearance on your street driven BRZ?
Malt is offline   Reply With Quote
Exedy BRZ specs sheet ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 2 11-07-2012 10:56 PM
build sheet jmaryt Scion FR-S / Toyota 86 GT86 General Forum 0 09-14-2012 10:55 PM
FT86/FRS Data Sheet WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 62 11-27-2011 05:12 AM
The Subieyota Is Under This Sheet ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 42 11-23-2010 09:42 PM
