Old 11-15-2013, 09:39 PM   #71
Ndgreely
Ndgreely's Avatar
Drives: 2013 FR-S 2003 SRT-4 1964 Impala SS
Anyone got any mounting advice for the ht auto lip on the frs ?? I purchased from koru and was told there was a DIY on their blog but it's for the brz .. Any help much appreciated !!
Ndgreely is offline   Reply With Quote
Old 11-16-2013, 05:39 AM   #72
chriscross_tnt
chriscross_tnt's Avatar
Drives: 02 maxima 6spd sold 2013 frs daily
It's pretty much the same diy as the brs. Install it with the clips and take a sharpie to make a mark where you gotta drill remove the clips and lip and then drill. Also remove the black splash shield . Couple 10mms. And some more clips . There's also a black plastic piece under the shield remove that . And you'll have all the roo. You need to nut and bolt
Sent from my HTC6500LVW using Tapatalk
chriscross_tnt is offline   Reply With Quote
The Following User Says Thank You to chriscross_tnt For This Useful Post:
Ndgreely (11-16-2013)
Old 11-16-2013, 05:11 PM   #73
sirsol66
Drives: 2013 FRS- Hot Lava
Are there any side skirts that do not require drilling into the metal on the car? I really would like to get the TRD or STI ones, but can't find anywhere to confirm if drilling into the sheet metal is necessary.
sirsol66 is offline   Reply With Quote
Old 11-16-2013, 08:42 PM   #74
akrazor
Drives: WRB 2013 BRZ Limited
I have the STI Lip and Side Skirts. you don;t have to drill into the sheet metal for the side skits but you will have to drill into the black wheel well plastic and it has pop clips that hold it to the underside along with 3M tape. i installed them myself looking at the Japanese instructions and only really ran into a slight issue with the template they provided. I did have to drill into the bottom of the bumper to install the front lip but just into the plastic. if you have any questions or want to see some pics send me a message i'll post them for you. hope this helps
akrazor is offline   Reply With Quote
Old 11-17-2013, 04:00 PM   #75
sirsol66
Would you minding sending me some photos of the side skirt install? I already have the HT auto lip, and have been eyeballing the STI or TRD sie skirt next.
Old 11-21-2013, 07:06 PM   #76
Ndgreely
Ndgreely's Avatar
Size:  95.0 KB here's my ht auto lip I got .. Plasti dipped and installed .. Fitment to me is pretty spot on
The Following User Says Thank You to Ndgreely For This Useful Post:
chriscross_tnt (11-21-2013)
Old 11-21-2013, 08:55 PM   #77
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
for side skirts, where did you guys drill into? Any pictures of it being installed?
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 11-22-2013, 03:44 PM   #78
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
For those of you that used loctite on the side skirt self-tapping screws; which kind did you use specifically?
Thinking about doing this as well, just wanted to make sure to have it properly sealed as I'm driving through winter.
Thanks!
1Cor10:23 is offline   Reply With Quote
Old 04-06-2015, 05:08 PM   #79
JS + BRZ
Drives: 2010 MS3
For Bayson R STI style side skirts, which 3M tape do we have to purchase? How long do we need? I bought it used and it doesn't have the tapes. Thank you!
Side skirts for BRZ cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 23 04-27-2017 12:27 AM
BRZ Polyurethane CS Side Skirts JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 102 10-02-2014 07:02 PM
TRD side skirts only, opinions? JoeBoxer Cosmetic Modification (Interior/Exterior/Lighting) 17 04-24-2014 12:36 AM
evasive CF lip/ side skirts installed bacon_cheese_beer Cosmetic Modification (Interior/Exterior/Lighting) 29 08-09-2013 01:26 PM
Size of STI Side Skirts Front lip Box ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 1 11-30-2012 08:38 PM
