| Software Tuning Discuss all software tuning topics. |
ECU table functions and definition of tables
Would be great if we had definitions for the various tables and also what they do. I am still not clear on a lot of functions of this ecu, for example when it come to DI Fueling, there are three maps (Base,Normal,and Safe) what do these mean? I noticed that the data logged values are interpolated between the normal and safe tables. Another I am not sure about is in the speed limiter tables (Speed UNK) which is set at 240km/h. Something else that has me confused is the carious A,B,C,D etc tables and what causes a switch between them.
#2 | |
| The Following User Says Thank You to jamesm For This Useful Post: | mad_sb (11-13-2013) |
#3 |
Romraider is great yet there still isn't much explained in terms of table function and in some cases even the axis are yet to be defined. What would be great is if we have a table by table post with explanation of function. The Bad Noodle guide is great (read it a long time ago) but falls short on a lot of BRZ specific tables.
#4 | |
if you have any specific questions, myself or others on the forum could probably answer them for you. |
#5 | |
Drives: 2013 Asphalt FR-S
I'm supposed to be working on porting the RR def over to ecuflash but have not had time. Most of the tables should not be hard to figure out but in some cases, like when it uses what timing map... if you search around that is still not fully understood on most 32bit subaru ecu's, etc.
~Namaste~ |
#6 |
Okay lets take one in particular that I am curious about. Its the VVT angle Base, Safe, Normal tables. What do you guys know about those and when they are used.
#7 |
Drives: GT86
I heard the two cam tables types depends on iam value... I've not verified that yet, but that's the EcuTek description.
#8 |
I have two data logs of vvt one with .98 IAM and the other with .45 IAM. In both cases the vvt values are nearly the same and seem to be interpolated between the safe and normal maps. Based on that I doubt IAM changes the vvt value much.
| Help posting a Table / Spread sheet | Esoteric | Site Announcements / Questions / Issues | 1 | 07-28-2013 12:48 AM |
| E46 M3 photo/video shoot by Project Definition | DTMAUTOBODY | Other Vehicles & General Automotive Discussions | 0 | 06-18-2013 08:00 PM |
| Coffee table I made from my FRS OEM springs | FR-Shadow | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 12-16-2012 07:05 PM |
| Can DBW tables be changed via Ecutek tune??? | Norkoastal | Engine, Exhaust, Transmission | 1 | 09-11-2012 07:51 PM |
| AS1 Definition? | nixeighty6 | Scion FR-S / Toyota 86 GT86 General Forum | 93 | 01-12-2012 02:56 AM |
