Old 11-12-2013, 05:16 PM   #1
TheBatman
TheBatman's Avatar
Drives: Scion FR-S 10 Series
USB/aux relocation
Just wanted to share what I did this past Saturday. I never liked the stock location of the USB and aux input because the chord(s) had to lay across the center console if you want to put your phone in the cup holder area, or even if you put it in the useless little front cubby I still found the chord(s) to hang in the way. Passengers were always sitting on them yada yada so I moved the ports.
Bought one of these
[ame="http://www.amazon.com/3-5mm-extension-Flush-Motercycle-Xtenzi/dp/B00CNUFGN6/"]Amazon.com: USB & 3.5mm AUX extension Flush Mount 2 Meter Cable , 1/8 AUX Car Bike Boat Motercycle Lead By Xtenzi: Car Electronics[/ame]
and simply plugged into the stock ports and buried the connections in the dash. I then removed the 12 outlet from the center counsel and bored the hole out slightly to accommodate the mount and heres how it looks:
Works nicely with my Carsmo armrest, I can hide my phone under the armrest easily or throw it in a cup holder
For the now empty hole where the stock ports were I used a blank switch hole cover, you can buy/order one from a toyota dealership:
I drilled a hole in the blank and used it as a switch mount for my traction control override
not a huge fan of the switch but its what I had laying around, I'll probably swap it out for something better looking later.
TheBatman is offline   Reply With Quote
Old 11-12-2013, 06:00 PM   #2
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Wink
Good stuff.....i hate having the "chords" in the way also....hehehe
gdrider77 is offline   Reply With Quote
Old 11-13-2013, 10:55 AM   #3
TheBatman
TheBatman's Avatar
Lolwut?
Am I missing some innuendo..?
Old 11-13-2013, 11:29 AM   #4
sklimo
LOL I get it
OP spelled cords, chords, like vocal..................
Edit: Looks good OP
Old 11-13-2013, 12:02 PM   #5
TheBatman
TheBatman's Avatar
Oohh haha I would love to blame auto-correct or something, but I'm honestly just a horrible speller
Old 11-13-2013, 04:51 PM   #6
Rumbaar
Victim's aren't we all
Rumbaar's Avatar
Drives: Toyota GTS 86 - Pegasus White
Nice work. I was going to drill a hole and remount the USB above the current power socket. I had brought a standard USB like the Amazon one.
Which I could get the AUX in to work with my aftermarket head unit and I'd get one of those Amazon ones instead.
Rumbaar is offline   Reply With Quote
Old 11-13-2013, 05:07 PM   #7
TheBatman
TheBatman's Avatar
You can, check this out
http://www.tacomaworld.com/forum/aud...head-unit.html
Old 11-14-2013, 04:09 PM   #8
Rumbaar
Rumbaar's Avatar
Originally Posted by TheBatman View Post
AH, seen that before. I've got the Adapter and the USB works, but my HU doesn't have an AUX input. So that's my problem.
Old 12-15-2013, 05:09 PM   #9
stueck9356
Drives: 2015 VW GTI SE
I want to put mine in the glove box, and just permanently hook up cables and leave everything in the glove box. I never take my ipod out of the car, I bought it a while back specifically for car audio.
Does that amazon adapter fit into the cigarette lighter hole without modification? and does that little aux-cover have a hole/toggle switch in it by default, or is it naturally just a blank cover?
stueck9356 is offline   Reply With Quote
Old 12-22-2013, 11:30 PM   #10
TheBatman
TheBatman's Avatar
I had to bore out the hole a bit to accommodate the amazon port. The cover does not have a switch, its just a blank that I drilled a hole in and used a switch from autozone.
Old 05-27-2014, 01:02 PM   #11
btoast
Where does one find that arm rest?
btoast is offline   Reply With Quote
Old 05-29-2014, 04:43 AM   #12
BC-Boy
BC-Boy's Avatar
Drives: 2013 Brz sport-tech
dam i really like that, im gonna keep my glovebox one and do that . i wonder what i could put in the dash port for the usb which i dont have, leave it blank or NOS BUTTON !!!! carbon fiber aviation inspired toggle switch with color changing led and bass sensing module to follow the beat of blaring katy perry !!!!!
BC-Boy is offline   Reply With Quote
Old 05-29-2014, 06:43 AM   #13
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
Carsmo
http://www.carsmodesign.com/fr-s-brz-armrest.html
FiRStsc10n is offline   Reply With Quote
fs: rho license plate relocation kit imravenit Exterior Parts (Aero, Lighting, Etc.) 2 07-13-2013 03:07 PM
Possible Relocation to Indianapolis 2_slo Off-Topic Lounge [WARNING: NO POLITICS] 5 05-31-2013 07:29 AM
DIY: OBDII plug relocation solma DIY (Do-It-Yourself) Guides 6 05-30-2013 12:11 AM
DIY License Plate Relocation ninjasaurusrex DIY (Do-It-Yourself) Guides 9 12-14-2012 03:23 PM
Badge Relocation danthedirt Cosmetic Modification (Interior/Exterior/Lighting) 11 06-15-2012 11:40 PM
