Old 11-11-2013, 04:50 PM   #155
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by whitefrs View Post
I'm at 400 and 245 are ok but i can fit 265
plenty of space with coil overs only
thanks, guess I'll run a similar size
Old 11-11-2013, 05:13 PM   #156
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Dipstik-sportech View Post
It's the 1000cc injectors. You have to turn them down so much on 91 at low speeds that they aren't efficient. With e85 u need more fuel so the injectors need to be opened a lot more so they're back in their efficiency range hence the better drivability.
Yep. It is all in the tune. Glad you are loving the corn juice.
brzaapi (11-12-2013)
Old 11-12-2013, 09:46 AM   #157
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Originally Posted by SmsAlSuwaidi View Post
I'd need meatier tires if I go 400hp would they clear ? I got my rears rolled
I don't believe I have enough driving time yet to make a good decision, but so far I am pretty happy with my setup of 225 and 255. In fact I don't see any reason to change my 225's in the front at all at this point, they work great and feel good. However, I am always paying attention to how my 255's hook up in case I care to go to 265 or 275. Beyond pure curiousity I don't see a need to do it at this point. Maybe I will just move up to RE11 rubber instead of my Pilot SS's. With @whitefrs saying he is content with 245's and how well my 255's do, going bigger may not be as much of a help. But the tinkerer in me cant help but want to try and see.
I think 245 or 255 may be a perfect compromise with 400hp. Of course a part of me is thinking of doing a hub conversion to 5 x 114.3. Moving up to 275's (or bigger) and getting a BBK. But to do this I will also need coilovers (next on my list). The bad thing is, you could do all that just to find out you didn't really gain anything or worse...you changed the car too much and now it has lost it's fun on the open road. And, right I am loving my car so I am not motivated to take the risk. 245 - 255 I think is the safe and easy answer.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 11-12-2013, 10:02 AM   #158
Frostyman
Drives: 2013 Raven FRS
I noticed a LOT of rolling resistance when I went up to 255. I'm on a square 18 X 9 setup, but I've been considering buying 4 more of the same rim I'm running in a smaller size, maybe 7.5 or 8, run staggered, and have a second set all around for winters.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
The Following User Says Thank You to Frostyman For This Useful Post:
Old 11-12-2013, 10:18 AM   #159
King Tut
NASA SpecE30 Racer
King Tut's Avatar
No need to do a hub conversion to go bigger. That won't get you anymore clearance. I still think 265s are the way to go.
Old 11-12-2013, 10:20 AM   #160
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Hmmm. I didn't really notice to much rolling resistance a little. What I did feel was a heavier steering feel. I am only running 225 in the front (lighter weight than stock rims/tires) and it made a pretty good jump in steering. I have since adjusted to it and I love the steering now. I wouldn't increase my front tire size until I saw reason too, so far I have none. I wonder if your overall rolling resistance is coming from having all 4 corners being 255. I am no expert in such things but with my staggered setup I didn't really notice any real increase. The steering feel was what grabbed my attention.
Also, are you running boosted? if not I definitely don't see any real functional reason to run 255's or even 245's. However wheels and tires are completely subjective from driver to driver, but that's my thinking anyway. FWIW
Daily: Audi TT RS
Old 11-12-2013, 10:22 AM   #161
brzaapi
CAR-AHOLIC
brzaapi's Avatar
<hub conversion> Yeah I know... I wasn't doing it for the clearance. I just hate the 5x 100 bolt pattern...or better yet the lack of wheel options.
Daily: Audi TT RS
Old 11-12-2013, 10:25 AM   #162
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Like I said its just something I would like to play with, its not something I am likely to do.
I would like to see how your 265's run and feel. I wanted 265's but went with 255's knowing that it wouldn't require any rolling or rubbing issues. So far they work pretty good.
Daily: Audi TT RS
Old 11-12-2013, 11:38 AM   #163
Dipstik-sportech
Dipstik-sportech's Avatar
Tire compound can sometimes make more I a difference than just a wide tire. My buddy is running 275 nitto nt01's on a 930+ whp s2000 and he can dead hook third with a full tank of gas, so I think those in a 245 would be near perfect on our cars.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Old 11-12-2013, 12:20 PM   #164
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Okay, not to get into a tire and compound debate...but since I will be sure to burn my pilots off in the next 10000 miles. Does anyone here have anything to say about the Nitto NT01's versus the Bridgestone RE11's.
Interested to hear actual experiences.
Daily: Audi TT RS
Old 11-12-2013, 02:31 PM   #165
Frostyman
I am pretty sure a big part of it is the fronts being so wide. Steering feel is certainly heavy. I don't particularly care for it, to be honest.
Yes, I have the innovate blower, so the rears need a bit of meat to hang onto the earth. Wouldn't want to float off into space or anything.
Old 11-12-2013, 02:34 PM   #166
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Well for one the Nitto NT01 is an R comp tire. I have heard it shares tire compound with the Toyo RA1. The RE11 is a street tire that can perform fairly well on the track.
Old 11-12-2013, 02:46 PM   #167
brzaapi
CAR-AHOLIC
brzaapi's Avatar
On the street do you know or think there would be much of a difference in rear wheel grip between the two.
In the end I may just buy both (no not at the same time) and see for myself. But that will take a couple years, as I am not in the habit of tossing tires that have more than 50% tread left.
Daily: Audi TT RS
Old 11-12-2013, 02:52 PM   #168
King Tut
NASA SpecE30 Racer
King Tut's Avatar
My only real experience is in going from my 205/50/15 Kumho XS street tires to Toyo RA1 R comps on my SpecE30. They felt about the same but the R comps had more overall grip and did not squeel as much near the limit. That is kind of what I would expect from the NT01 and the RE11. They will probably both have similar sidewall characteristics while the compound on the NT01 will provide better grip. I am sure the RE11 will beat it in the rain.
AVO turbo kit for BRZ - initial build thread AVOturboworld Forced Induction 3109 12-01-2019 03:55 PM
FS: Fullblown Motorsports Premium Turbo kit Frs300 Engine, Exhaust, Bolt-Ons 38 05-23-2013 09:28 PM
wr blue premium build thread three3y3wrbbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-09-2013 06:34 PM
Just wanted to show off my turbo build sw20kosh Forced Induction 5 04-01-2013 03:16 PM
Major road trip to pick up my SWP Premium starting Friday 6/15. Critique my course. Mitch BRZ First-Gen (2012+) — General Topics 28 07-12-2012 04:30 PM
