#141 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Why no more Exige?
#142 |
Vtec Jesus
I'm glad you are local. Would love to pick you brain about things and compensate you with micro brews.
#143 | |
One trick pony. Rotted in garage 6 months out of the year, hard to work on, parts scarce/expensive, reliability, expensive to insure, and finally attracted too much attention.
#144 |
Truuu
Drives: 2013 FRS, 88 EF Civic, 05 Matrix
How many miles did you get per tank on that insight?
GARRET .60 TRIM-UEL HEADERS-1150cc INJECTORS-DW FUEL PUMP-RACESENG CAM PLATE-PERRIN 3" CATBACK-ULTIMATE RACING 2.75 OP/FP-FBM CATCHCAN-SINGER 275AMP ALTERNATOR-MEGAN TRACK COILS-MEGAN F/R STRUTBARS-AXLE EXCHANGE ALUMINUM DRIVESHAFT-ACT 6 PUCK-ANARCHY MOTIVE SHIFTKNOB-XXR 535-HANKOOK VENTUS EVO V2-CS LIP KIT Build Thread - FA20FAIL Archive |
#145 |
Lifetime was 60MPG until the cars EGR, CAT, O2, Battery packs took a dump for the 3rd time.
#146 |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Might be a dumb question but did you guys ever figure out why?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
#147 |
#148 |
Lean burn, amazing system but byproduct is heavy carbon buildup in EGR system and passages. Secondly it had an esoteric catalyst and wide band O2 sensor. The car was capable of running as high as a 26:1 AFR. The results were extreme heat on the cat. Lost efficiency after 70k miles.
As it lost efficiency the car would pull it out of lean burn faster to purge and cool the cat. Wideband O2 replaced 3x in 120k. Injectors were also replaced twice as there were also a high part of efficiency and being able to basically run in an almost off condition most of the time. Spark plugs were also keyed based on the motor, much like the FRS DI injectors are keyed. And finally the shit IMA system. The NIMH batteries were horrible, Had two packs swapped and mostly according to the hard core guys is because the cells would be out of balance. (140ish batteries all at different states of charge) Its not that the pack was bad it was just performing like shit. So when the batteries were unbalanced the car would be force charging the pack which would constantly drain power from the 55HP motor and kill lean burn. All of these things made for an annoying driving experience. Constant leech charging constant in and out of lean burn, killed MPG, made the car slower than it already was and was constantly surging. After 80k the car went to shit. Before that I loved it and loved the manual trans. Near the end I had direzza Z1 and tracked it just to be an asshole. It's a Subaru I thought it was already AWD, the dealer told me it was need to take it in now.
| The Following 3 Users Say Thank You to Dezoris For This Useful Post: |
#149 | |
Weight Nazi
You're the first person I've ever talked to that has/had one of these things. Was it a hassle dealing with the covered back wheels, or did the cover have some sort of quick release? And what the hell was the point of covering the wheels?! Aero?
#150 | |
The actual track in the rear was closer together than the front so that the car followed the tear drop shape towards the back and the wheel covers allowed air to flow over smoothly. Considering the entire car was aluminum and plastic including frame for some odd reason the wheel covers were steel. And used steel fasteners that rusted. There were held in place by two bolts. This car had a lot of production car firsts as well. The Insight, S2000 and NSX were all made in the same place using many shared technologies, last of the good Hondas. But at the end of the day it turned into a pile of shit after 100k. The 1900lbs curb weight could not save it.
| The Following User Says Thank You to Dezoris For This Useful Post: | Anthony (11-09-2013) |
#151 |
Drives: Some rust bucket
Couldn't you run those Insights on gas engine only?
#152 |
IMA, electric generator sandwiched between motor and trans, also used to start motor (also has a 12v starter) Whole host of other programming things. Some people did custom setups called MIMA (manual integrated motor assist) to over ride how the ECU controls it. The cost and time to get rid of the IMA was not worth it to me.
#153 |
OLD PHOTOS FROM VORTECH AUTOX TEST
| The Following User Says Thank You to Dezoris For This Useful Post: | Anthony (11-13-2013) |
#154 |
Drives: 2011 Honda Fit Sport
| Tags |
| ap racing, daily driver track, dezoris, ohlins, perrin, properly built 86, vortech supercharger |
| TWINCHARGED (Supercharged & Turbocharged) Widebody "WTF-86" 86/FRS *MASSIVE* build :D | WTF | Member's Car Journals | 224 | 08-18-2016 09:39 PM |
| Pneubs HKS Supercharged BRZ Build Thread | Pneub | Member's Car Journals | 62 | 03-30-2016 09:47 AM |
| (Boosted) FRS vs S2000... Dezoris strikes again. | CSG Mike | FR-S / BRZ vs.... | 156 | 09-08-2014 01:16 AM |
| Morpheus, Scion dream Build. Supercharged FR-S by TuneCast | scionsalesjay | Member's Car Journals | 51 | 07-07-2014 12:05 PM |
| Supercharged Rocket Bunny Widebody Conversion Build Thread | RWDRIFT | Member's Car Journals | 278 | 01-06-2014 12:12 AM |
