Old 11-07-2013, 10:58 PM   #141
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Why no more Exige?
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 11-08-2013, 12:23 AM   #142
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
I'm glad you are local. Would love to pick you brain about things and compensate you with micro brews.
TouchMyHonda is offline   Reply With Quote
Old 11-08-2013, 12:29 AM   #143
Dezoris
Dezoris's Avatar
I am here.
Originally Posted by Anthony View Post
Why no more Exige?
One trick pony. Rotted in garage 6 months out of the year, hard to work on, parts scarce/expensive, reliability, expensive to insure, and finally attracted too much attention.
Old 11-08-2013, 12:40 AM   #144
PineappleFriedRice
Truuu
PineappleFriedRice's Avatar
Drives: 2013 FRS, 88 EF Civic, 05 Matrix
How many miles did you get per tank on that insight?
GARRET .60 TRIM-UEL HEADERS-1150cc INJECTORS-DW FUEL PUMP-RACESENG CAM PLATE-PERRIN 3" CATBACK-ULTIMATE RACING 2.75 OP/FP-FBM CATCHCAN-SINGER 275AMP ALTERNATOR-MEGAN TRACK COILS-MEGAN F/R STRUTBARS-AXLE EXCHANGE ALUMINUM DRIVESHAFT-ACT 6 PUCK-ANARCHY MOTIVE SHIFTKNOB-XXR 535-HANKOOK VENTUS EVO V2-CS LIP KIT
Build Thread - FA20FAIL Archive
PineappleFriedRice is offline   Reply With Quote
Old 11-08-2013, 12:53 PM   #145
Dezoris
Dezoris's Avatar
Lifetime was 60MPG until the cars EGR, CAT, O2, Battery packs took a dump for the 3rd time.
Old 11-08-2013, 12:59 PM   #146
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Might be a dumb question but did you guys ever figure out why?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 11-08-2013, 01:05 PM   #147
CSG Mike
CSG Mike's Avatar
Top secret AWD conversion?
Old 11-08-2013, 01:25 PM   #148
Dezoris
Dezoris's Avatar
Lean burn, amazing system but byproduct is heavy carbon buildup in EGR system and passages. Secondly it had an esoteric catalyst and wide band O2 sensor. The car was capable of running as high as a 26:1 AFR. The results were extreme heat on the cat. Lost efficiency after 70k miles.
As it lost efficiency the car would pull it out of lean burn faster to purge and cool the cat. Wideband O2 replaced 3x in 120k.
Injectors were also replaced twice as there were also a high part of efficiency and being able to basically run in an almost off condition most of the time. Spark plugs were also keyed based on the motor, much like the FRS DI injectors are keyed.
And finally the shit IMA system. The NIMH batteries were horrible, Had two packs swapped and mostly according to the hard core guys is because the cells would be out of balance. (140ish batteries all at different states of charge) Its not that the pack was bad it was just performing like shit.
So when the batteries were unbalanced the car would be force charging the pack which would constantly drain power from the 55HP motor and kill lean burn.
All of these things made for an annoying driving experience. Constant leech charging constant in and out of lean burn, killed MPG, made the car slower than it already was and was constantly surging.
After 80k the car went to shit. Before that I loved it and loved the manual trans.
Near the end I had direzza Z1 and tracked it just to be an asshole.
It's a Subaru I thought it was already AWD, the dealer told me it was need to take it in now.
The Following 3 Users Say Thank You to Dezoris For This Useful Post:
Anthony (11-09-2013), PineappleFriedRice (11-08-2013), TouchMyHonda (11-08-2013)
Old 11-09-2013, 12:07 AM   #149
Anthony
Weight Nazi
Anthony's Avatar
Best reason I've ever heard.
You're the first person I've ever talked to that has/had one of these things. Was it a hassle dealing with the covered back wheels, or did the cover have some sort of quick release? And what the hell was the point of covering the wheels?! Aero?
Old 11-09-2013, 01:57 AM   #150
Dezoris
Dezoris's Avatar
The actual track in the rear was closer together than the front so that the car followed the tear drop shape towards the back and the wheel covers allowed air to flow over smoothly. Considering the entire car was aluminum and plastic including frame for some odd reason the wheel covers were steel. And used steel fasteners that rusted. There were held in place by two bolts.
This car had a lot of production car firsts as well. The Insight, S2000 and NSX were all made in the same place using many shared technologies, last of the good Hondas. But at the end of the day it turned into a pile of shit after 100k. The 1900lbs curb weight could not save it.
The Following User Says Thank You to Dezoris For This Useful Post:
Old 11-11-2013, 12:24 AM   #151
ayau
Drives: Some rust bucket
Couldn't you run those Insights on gas engine only?
Old 11-13-2013, 01:17 AM   #152
Dezoris
Dezoris's Avatar
IMA, electric generator sandwiched between motor and trans, also used to start motor (also has a 12v starter) Whole host of other programming things. Some people did custom setups called MIMA (manual integrated motor assist) to over ride how the ECU controls it. The cost and time to get rid of the IMA was not worth it to me.
Old 11-13-2013, 01:18 AM   #153
Dezoris
Dezoris's Avatar
OLD PHOTOS FROM VORTECH AUTOX TEST
Anthony (11-13-2013)
Old 11-13-2013, 01:24 AM   #154
phenoyz
Drives: 2011 Honda Fit Sport
"Exige"
Really...
phenoyz is offline   Reply With Quote
ap racing, daily driver track, dezoris, ohlins, perrin, properly built 86, vortech supercharger
TWINCHARGED (Supercharged & Turbocharged) Widebody "WTF-86" 86/FRS *MASSIVE* build :D WTF Member's Car Journals 224 08-18-2016 09:39 PM
Pneubs HKS Supercharged BRZ Build Thread Pneub Member's Car Journals 62 03-30-2016 09:47 AM
(Boosted) FRS vs S2000... Dezoris strikes again. CSG Mike FR-S / BRZ vs.... 156 09-08-2014 01:16 AM
Morpheus, Scion dream Build. Supercharged FR-S by TuneCast scionsalesjay Member's Car Journals 51 07-07-2014 12:05 PM
Supercharged Rocket Bunny Widebody Conversion Build Thread RWDRIFT Member's Car Journals 278 01-06-2014 12:12 AM
