Old 11-10-2013, 09:54 PM   #1
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
white / fiji green turbo brz!
Here's my build thread. I've had my car since October now.
Current mods.
Exterior:
-seibon vented carbon hood (painted by Toni: Pro Auto & Collisions 232 E Buckingham Rd, Garland, TX ‎ (972) 485-5002 )
-seibon carbon side vents
-seibon csl carbon trunk
-seibon carbon fiber roof replacement ( installed by Khamla: http://www.kustomzunltdinc.com )
-custom painted headlights
-greddy hood dampers
-beatsonic shark fin antenna
Engine:
-avo stage 1 turbo
-misimoto carbon catch can
-Perrin 3" cold air intake
Exhaust:
-Top Speed Auto cat back exhaust with 4" tips (http://www.topspeedauto.com)
http://www.ft86club.com/forums/showthread.php?t=53599
-Top Speed Auto 2.25" over pipe
-Top Speed Auto 2.25" cat-less front pipe
Suspension:
- Ohlins Road & Track Coilovers
- HVT front adjustable camber plates
- Raceseng rear top hat
- cusco rear camber arms
Wheels:
- 19" volk rays gram lights extreme57
- volk rays centercaps
- volk rays formula lugs
Interiors:
- White Led replacement bulbs
Video on exhaust:
[ame]http://youtu.be/WbqC1B-thBY[/ame]
Current exhaust set up with no cats
[ame]http://youtu.be/8EdPjffxch0[/ame]
Previous exhaust
[ame]http://youtu.be/dAngKm1-wdg[/ame]
First exhaust
There's a bunch of pictures so I'll upload them when I can. Here's some current ones:
h4nh is offline   Reply With Quote
Old 11-10-2013, 09:54 PM   #2
h4nh
h4nh's Avatar
Picked it up at the dealership
New volk rays gram lights extreme57 19x9.5 rear 19x8.5 front
Getting some new Falken tires on it. 265/30/19 rear & 225/35/19 front
stock height
Kw v3 coilovers & cusco rear camber arms
Picked up some vorshlag front camber plates since they were in town.
Stock suspension
kw's installed in the rear. It was pretty easy to install. Very straight forward.
lowered! Alignment was pretty bad afterwards and it was eating up the tire. Traction control was going off like crazy.
New set of Tom's led tail lights.
lights installed
lights on
Got it aligned to factory specs for now. It's not too low right now so I can jack it up or put it on the lift easier. Camber is set to zero.
aligned
getting the roof chopped off. Khamla at kustomzunltdinc.com was the only person in town willing to chop my roof off. lol He does amazing work!
new carbon fiber roof replaced
Khamla finishing up the roof.
2x2 weave looks amazing! I'm going to have it cleared later on.
At my buddy Toni's paint shop Pro Auto & Collisions in garland. He's painted all my cars / bikes for the past 7 years or so. Great work at a reasonable price.
Side vent's and hood vents being painted.
painted csl trunk with carbon fiber fade
Carbon hood painted
Pearls matched up nicely
side vents & hood vents finished.
removing the old trunk
This was easy. It took about 10 mins to take off.
New trunk on. It fits pretty good.
Hood is on. I had to widen the holes for the hood hinges to adjust the hood forward. It still bulges up a bit higher than the fender. I'll probably modify the hinges later.
[IMG]http://farm4.staticflickr.com/3750/10604422763_***7518494_c.jpg[/IMG]
close up on the vents
At certain angles you can see the fiji green accents
From a far it looks more subtle.
About to install the turbo.
Pulling everything apart to install the turbo.
parts
Had to weld these fittings in that hold the screws for the intercooler. The instruction says to use a step drill and rivet them in but that didn't work.
Took it to the exhaust shop and they did it for free. I tipped him 10 bucks. Pronto Mufflers in plano.
Everything's pretty much in.
So while the headlights are out...
Lets bake them for dinner
Got it all pulled apart. It was pretty easy. Set oven to 350, preheat, let it sit in for 5-8 mins and it should pull apart.
some sanding..
More sanding to come..
Masking
Sand the chrome as much as possible. Paint doesn't like to stick to it.
Finished. You can do the flat black for the whole headlight and it'll cost only a dollar from home depot!
assembly. I left the chrome piece because it goes in the back of the led strip because I wanted the light to stay bright.
coming together.
finished product. The lens needs to be cleaned. I added some rtv gasket sealant and it sealed up fine.
checking the wiring. Everything's good.
Looks blacked out from a far.
Another shot of the lights.
Got some exhaust from (http://www.topspeedauto.com) They're a local shop here in town that imports these. Retail is around 400 bucks.
Weld quality is nice.
Another shot of the welds
They even sanded out the inside welds for better flow.
resonator
New hardware and gasket.
On the race ramps
Old vs New
Installed in about 10 minutes. It was pretty simple. There's 4 x 14mm bolts holding it on with some 12mm nuts. Very straight forward.
Use some WD-40 to loosen the rubber mounts and it will pop right out.
4.5" burnt tips
Fitment was perfect! Exhaust isn't broken in yet. It was super quiet at first but after a drive it got louder. So far it's pretty mellow and not obnoxious.
I'll upload more later...
Old 11-10-2013, 09:54 PM   #3
h4nh
h4nh's Avatar
My kit was running great for two days then all the sudden it was at zero boost. Felt like it was back at stock. It wasn't a boost leak.
Found the problem to be the cotter pin that holds the acuator lever on was too small. It probably fell off or broke off.
Drilled the hole with a bigger drill bit.
Installed a bigger cotter pin. Hopefully it should hold up better now.
Second issue was it was leaking oil behind the oil pump where the camshaft is. RTV sealant was used as directed in the instructions but it didn't hold up well.
Pump removed with old sealant.
All the pieces cleaned up and old sealant removed.
New sealant to be used. This is what toyota uses from the factory. It sets in about 15 minutes so you don't have to wait 24hrs before it can be driven.
The block side was cleaned off and new sealant applied.
Final assembly.
Done for now.
Got these Forester turbo gaskets that will be installed soon. There's a minor leak but not that noticeable now.
Hope this helps in case you guys run into issues. The car feels good now.. dyno tune next week!
12.19.13 Here's an update. I just picked up the race version of this exhaust for some spirited driving on weekends. The quiet version was nice because I can hear the blow off from the turbo better. However, this one is much louder and 2.5" piping made a significant difference for exhaust flow. It now has some backfire so I'll need to get it tuned. Yes, it does drone so I would not recommend if you daily it and have low tolerance to noise.
I know you can pick up any type of similiar exhaust on ebay for about the same price but Top Speed has provided me with amazing service. A lot of the members on here have been asking what kind of hood I have and it is seibon. It fits like crap in real life. There's a huge gap by the fenders which is a manufactering defect. I contacted the vendor I purchased it from (evasive motorsports) and they wouldn't do anything. They even said seibon wouldn't do anything and offered me 5% off my next purchase (what a joke).
Anyways, George at Top Speed took pictures of the hood and contacted Seibon directly. Hopefully they'll get my issue resolved. If not, at least they tried and I'll order a nicer quality hood from Japan.
Here's the link to the race exhaust on ebay: http://www.ebay.com/itm/Scion-FRS-Su...148e18&vxp=mtr
Anyways, I'll try to get a video together soon. Today was pretty windy so I don't think my camera picked up the sound very well. It really brought out the boxer rumble especially with my avo uel headers.
Update for 01.28.14
Top Speed Auto in Addison ordered a new hood from Seibon for me since the previous one purchased from another vendor didn't fit properly. This one turned out nice! I'll be painting the car a different color so it's just exposed carbon for now.
Just got these new Ohlins R&T suspension in today. My kw v3 & vorslag camber plates are for sale if anyone's interested.
Installed Perrin 3" cold air intake last night.
Finally got to fit my Ings bumper that's been sitting for a while.
rear tires for new wheels that are coming
Just placed my order for a set of MORR VS52 1 piece wheels. I'm getting these in 19x10 front & 19x12 rear
Update.
Installing ohlins.
Before shot, with the kw v3's installed.
Front installed. We adjusted it lower after. This was about stock height.
Rear installed.
My buddy doing the alignment.
After alignment. This is the max low it goes.
The ride after was amazing! I have it 7 clicks from firmest and it does not make my head explode. It handles a lot better than the kw v3's. If you're looking for low ride height, I would not recommend these.
Over pipe from Top Speed Auto.
Cat-less front pipe from Top Speed Auto. Both fit 100% spot on. Quality is well worth the price of $179. I will be upgrading to 3" later but I wanted to see how the catless would work out. It smells from the outside but inside it's okay. It opened up the car a bit and I can definitely notice more power.
No cats!
Old 11-10-2013, 09:55 PM   #4
h4nh
h4nh's Avatar
reserve 3
Old 11-10-2013, 09:56 PM   #5
h4nh
h4nh's Avatar
reserve 4
Old 11-10-2013, 09:56 PM   #6
h4nh
h4nh's Avatar
reserve 5
Old 11-10-2013, 10:00 PM   #7
B L U E S L A T E
Drives: BMW E84
Love that carbon hood. Exactly what I've been wanted to do. Now I know what it'll look like and I thank you for it.
B L U E S L A T E is offline   Reply With Quote
Old 11-10-2013, 10:02 PM   #8
h4nh
h4nh's Avatar
fitment kinda sucks.. I think I need to modify the hinges. It bulges up right now.
Old 11-10-2013, 10:03 PM   #9
B L U E S L A T E
Drives: BMW E84
Noted. I will most likely go with Varis hood so I'm hoping to have a little better fitment.
Old 11-10-2013, 10:09 PM   #10
Byebye
Byebye's Avatar
Hood and roof are hot! Car looks good.
Byebye is offline   Reply With Quote
Old 11-10-2013, 10:25 PM   #11
h4nh
h4nh's Avatar
Varis is top notch. You get what you pay for. I like the design of this one though.. maybe I'll switch when they come out with something else I like.
thanks!
Old 11-10-2013, 10:36 PM   #12
TOZER
Drives: 2013 Whiteout FR-S
when i saw the roof cut off I thought 'no way this guy just..."
and then I scrolled down and it looks amazing. Definitely one of my favourite BRZ's on here
TOZER is offline   Reply With Quote
Old 11-10-2013, 11:12 PM   #13
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Subbed for awesome build haha
Old 11-10-2013, 11:28 PM   #14
tr1x5tuh
The Original Super Saiyan
tr1x5tuh's Avatar
Drives: 2014 SWP BRZ
Sick build man keep it up love the accents. Gives me some ideas for my future BRZ
tr1x5tuh is offline   Reply With Quote
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Turbo, white smoke out the exhaust, ideas? Synack Forced Induction 44 09-09-2013 09:57 AM
Green light for Nissan GTR R36 Giccin Other Vehicles & General Automotive Discussions 39 06-05-2013 01:48 PM
Would FB Green or Red fit any existing kit? HighLife Forced Induction 17 01-04-2013 05:18 PM
CBS FRS at Green Toyota Integratedfool Great Lakes 0 06-25-2012 12:24 PM
