Old 11-10-2013, 02:30 PM   #71
kuhlka
Drives: 2013 BRZ Limited AT
So I will ask this question again: When the engineers were trying to squeeze every last hp out of this engine to reach the rated "200hp" mark why didnt THEY just change the size of the pulleys?
Seems simple right?
If you want a drag car why not just bypass the alternator & AC entirely with a belt that only drives the water pump?
ON TOPIC enough?
Heavy stock bits = Smooth and reliable. Easier to balance.
Lightweight aftermarket bits = Fast revs, but easier to stall.
The stock parts are really just a matter of cost-savings and keeping daily driver reliability as a high priority. I'd be willing to bet even the next (rumored) Toyota Supra will have a fairly heavy pulley setup and flywheel because the vast majority of buyers won't spend a single minute on a track or autocross circuit.
I generally weigh my mods in terms of $/lb or $/whp. When you take that into account, a pulley set is pretty pricey in the grand scheme of things.
kuhlka is offline   Reply With Quote
The Following User Says Thank You to kuhlka For This Useful Post:
Simply_the_best (11-11-2013)
Old 11-11-2013, 11:43 AM   #72
Team STILLEN
Mark @ STILLEN
Team STILLEN's Avatar
Drives: 2015 Subaru BRZ
Just to make sure people don't get concerned about engine balance when talking about lightweight pulleys, here is what we have found at STILLEN and from my personal experiences. Most, if not all modern motors (especially Japanese Imports) are internally balanced. The crank pulley is rarely used for balancing purposes on most motors and is generally just used to drive the accessories and in some cases reduce NVH. We have found no issues with using lightweight pulleys on any of the cars we have developed them for and have even had customers say their engine runs a little smother.
Seems simple right?
Yes, engineers at Subaru and Toyota are always trying to squeeze every last HP out of the engine (with in reason). They have budgets, acceptable rate of failure, safety, and other regulations to consider that keep them from getting absolutely everything out of a motor. A CNC machined lightweight pulley will cost more for them to make and will generally not be an acceptable part to use. Also, if the crank pulley is being used as a dampener then they would not be able to mess with it much. Cost is always a huge factor that limits vehicles from the factory. Also I'm sure there are internal or external regulations on power allocated to accessories.
ON TOPIC enough?
Pure drag cars often bypass anything possible. Even running electric water pumps. Does not apply to anything you would drive more than a 1/4 mile at a time.
Originally Posted by kuhlka View Post
The flywheel would make a big difference for revs, though.
I have always seen and felt great results from Lightweight Flywheels. Always a worth while upgrade IMO.
You're pretty much right now the money. Though in this case I'd say its more about cost as pulleys are flywheels generally don't affect reliability very much (on these types of cars at least), but who am I to question Toyota and Subaru.
| Mark Dorman | Performance Specialist | markd@stillen.com| IG @Mark_STILLEN | www.STILLEN.com
Team STILLEN is offline   Reply With Quote
The Following 2 Users Say Thank You to Team STILLEN For This Useful Post:
jdubious (11-11-2013), stugray (11-11-2013)
Old 11-11-2013, 12:10 PM   #73
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by Team STILLEN View Post
The crank pulley is rarely used for balancing purposes on most motors and is generally just used to drive the accessories and in some cases reduce NVH..
Mark,
excellent post! I agree almost 100%
There are definitely holes drilled in my stock pulley, so I assume that the rotating assembly is balanced at the factory.
I question "slightly" that these engines are 100% Internally balanced or that would call into question why most of the mass of the pulley is dead weight.
You can see by looking at the stock pulley that the internal part is cast while the "mass" is machined and attached to the pulley.
Why would they pay extra for the additional assembly cost of a two part pulley if they did not need to?
So I believe that the pulley is there for balancing purposes.
Would I replace the pulley if building a race engine from the ground up? Absolutely! Along with the rods, pistons, flywheel, clutch, etc.
Would I change the pulley from a previously balanced rotating assembly without rebalancing? - No.
You guys have been doing this long enough that I dont believe you would tell a customer that is having a custom engine built that they should change any rotating part without a rebalance either.
The arguement here comes down to "Can you replace the pulley to get a fraction of a hp difference?" or "Should you?"
I am on the side of "you shouldnt" UNLESS you do a few other things first.
The Following User Says Thank You to stugray For This Useful Post:
Team STILLEN (11-11-2013)
Old 11-11-2013, 12:22 PM   #74
Team STILLEN
Mark @ STILLEN
Thanks Stugray.
I agree that the motors aren't necessarily 100% balanced from the factory (as 4 cylinders are inherently imbalanced), but I doubt the pulley contributes much to that but I can't say for sure (safe bet would be not to touch it). The two piece design is generally used as a dampener for NVH (which we have found in the past to make very little difference). We have not tested this particular car's pulleys so I'm not sure. I agree that on this engine there is less gains to be seen with a pulley but I haven't seen any solid dyno sheet indicating either way (though the math indicates very little gain).
We have seen up to 8 whp on the VQ motors with underdrive and lightweight pulleys, but those are bigger motors with almost 5 lb crank pulleys. Also the 350's and 370's have PS pumps to underdrive so there is a little more power to be saved.
I also agree that there are much better upgrades that one should spend money on before looking at pulleys.
The Following User Says Thank You to Team STILLEN For This Useful Post:
Old 11-11-2013, 01:42 PM   #75
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
When I hear about how people can "feel" that the engine is more responsive with a lightened pully, I want to call BS.
If you think about it, it supposedly "reduces" the rotating mass.
However if you consider the alternator, air conditioner, belt, crank, pistons, flywheel, cams, and timing chain, the pulley is a tiny fraction of all of that inertia. (I would bet that the timing chain contributes 10X more than the pulley in rotating inertia).
I seriously doubt it makes any difference at all, much less a difference that you can feel.
Also, when the engineers were trying to shave every single ounce off of this car & engine, WHY would they put a heavy pulley on it? I am guessing it has to do with vibration & dynamic balance.
I would not mess with it UNLESS you are doing a dozen other things that would make a bigger difference.
I noticed a change when I had one on my WRX 4 or 5 years ago. I didn't really notice a power gain though. It was noticeable in winter when I would lose traction. The revs would shoot up way faster than it did with the factory pulley.
Jaylyons1 is offline   Reply With Quote
Old 01-27-2014, 12:58 PM   #76
Mathewgzlz
Mathewgzlz's Avatar
Drives: 2013 SCION FR-S FIRESTORM RED
Originally Posted by JDKane527 View Post
I have GFB lw crank, alternator, and waterpump pulleys, as well as Raceseng idlers. I didn't notice a difference when I installed idlers on, except for rpms dropping faster. Blips are quicker. Regarding acceleration, I didn't notice as big of an improvement as when I got header and tune. I still have stock flywheel and steel drive shaft, so it will be more noticeable after lightening those.
My butt dyno was recently calibrated to Mil Spec.
Edit: seems like some people's sarcasm detectors need recalibration.
i have a question for you, i went with the gfb 3 pulley kit as well when i went turbo but now occasionally itll bog out while fluttering the clutch or slowing down is there a chance tht the reduced mass of the pulleys is causing to rev down to quickly or do you all think i might have a shitty tune/maybe internal damage? besides the occasionally bogging the engine runs great air/fuel is right around where its supposed to be and i never have any hesitation in acceleration.
Mathewgzlz is offline   Reply With Quote
Old 01-27-2014, 02:36 PM   #77
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
I get occasional bogging if there's high ambient temps (80F) and there's some heatsoak from sitting in traffic. On FA20 tune, the idle was lower rpm than V-Tune, and would bog more frequently with the lower idle. The V-Tune bogs less.
You can try changing back to the stock crank pulley and see if it's more stable. I was considering trying the stock crank myself as well.
JDKane527 is offline   Reply With Quote
The Following User Says Thank You to JDKane527 For This Useful Post:
Mathewgzlz (01-27-2014)
Old 01-27-2014, 04:12 PM   #78
Mathewgzlz
Mathewgzlz's Avatar
I'm probably going to swap them all back to stock the gfb pulleys are under a 1lb and I've heard thts a no go for pulleys and see if it helps
Old 01-27-2014, 09:10 PM   #79
jamesm
I don't know if they present any issues on this car (no one does yet), but for what you gain it definitely isn't worth any amount of risk.
Old 01-27-2014, 11:45 PM   #80
Victor Draken
Drives: Toyota Gt86
for the price you have to pay for a full pulley kit is not whort it as well
Victor Draken is offline   Reply With Quote
The Following User Says Thank You to Victor Draken For This Useful Post:
jamesm (01-27-2014)
Old 02-12-2014, 08:14 AM   #81
dj petey
dj petey's Avatar
Lighten your drive train if you want increased throttle response. Be prepared to adjust your shift habits to keep everything smooth. When i went to a lightweight flywheel the difference was very apparent in first and 2nd gear acceleration. Throttle lag is greatly diminished. Pulleys won't have as much of an affect as a FW but will help in the grand scheme. Pulleys also don't usually cost as much as a flywheel and the install doesn't require a clutch and tranny re/re. So if you're short on cash and install time pulleys will get you started in the right direction.
dj petey is offline   Reply With Quote
What is best crank pulley? Mixlplix Engine, Exhaust, Transmission 49 10-28-2017 05:44 PM
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 10:12 AM
Kartboy crank pulley Turn in Concepts Engine, Exhaust, Bolt-Ons 5 05-22-2013 10:51 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
