Old 10-26-2013, 06:56 AM   #43
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Originally Posted by Rampage View Post
I will post this picture from an old thread here:
Yup, same exact place as mine.
Well I will REALLY raise my car next summer. -_-
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 11-06-2013, 03:24 PM   #44
frsvr4
Drives: '13 FRS
So my FRS is stock with less than 2k miles. I've got some 225 BFG drag radials sitting around. I was hoping to get some quick base line 1/4 mile numbers. I've never raced a RWD car, so I was hoping to practice warming up the tires and launching as hard as possible. The car is going to squat. What are my chances of surviving one drag night? Ha.
Where is the best place to find replacement (spare) axles? Swapping axles at the track is easier than a tow truck.
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135
frsvr4 is offline   Reply With Quote
Old 11-07-2013, 11:44 AM   #45
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I have yet to see an 86 with completely stock suspension breaking an axle on this forum, if you look every post in this thread has been from a lowered car. With the stickier tires you'll be adding stress, but not as much as different geometry and adding power.
ineedyourdiddly
Old 11-07-2013, 11:46 AM   #46
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Wrong. There are multiple stock setups with messed up axles.
husker741 is offline   Reply With Quote
Old 11-07-2013, 11:50 AM   #47
strat61caster
Links?
ineedyourdiddly
Old 11-09-2013, 01:49 PM   #48
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Is this related to being able to rotate the driveshaft while in neutral about 20-30 degrees with the parking brake on? I also pushed the car with the E-Brake up and while in neutral and I can hear the clicking sound coming right from the left rear axle area.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 11-09-2013, 07:31 PM   #49
nelsmar
Possibly.
Has anyone broken as passenger axle yet? I haven't heard of anyone damaging the left side.
My flickr - Canibeat
Local magazine scout
Old 11-11-2013, 02:51 AM   #50
PoWn3d_0704
PoWn3d_0704's Avatar
Drives: 1990 BNR32 GTR
Yeah, links on that would be great. If the stock axles break anyways, we can get a TSB on them. Maybe ones that will even handle lowering the car. If not, then just axles when you lower your car. Spendy, but that's why we do things right in the first place.
Picked up my BRZ on 6/11/13.
Build Album:
PoWn3d's BRZ Pictures
Build Thread: PoWn3d's BRZ
PoWn3d_0704 is offline   Reply With Quote
Old 11-13-2013, 10:55 AM   #51
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Car: FR-S '13
Miles: 36K (at time of axle break) 45K now.
Use: Daily Driver and AutoX
Lowered: Yes, about 2"
Power: STOCK (or close enough that it's "stock")
Forced Induction: No
Axle broke story: Tons and tons of hard autoX launches with wide sticky tires on grippy surfaces.
Old 11-13-2013, 12:48 PM   #52
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
I'm I correct in assuming the problem with the axles is because of lowering the car and not adding sticky tires or about 100hp?
kurbkilla is offline   Reply With Quote
Old 11-13-2013, 12:58 PM   #53
nelsmar
We don't know for sure yet. Pretty much everyone with broken axles was lowered and had different tires. I was on Nitto555 when i broke mine. I am "guessing" its due to height. But only time will tell!
Old 11-13-2013, 01:03 PM   #54
Carwhisperer
Drives: A lot of supercars.
Links?
Don't have a link because I don't care to make it a huge deal. I was stock suspension and mine had to be re torqued and lubed. It would have only been a matter of time for it to actually break for me.
Carwhisperer is offline   Reply With Quote
Old 11-14-2013, 04:45 AM   #55
Lachlan
Drives: Toyota 86
My 86 is completely stock, however I have heard clicking from my axel since day one. I can hear this click even when shifting at 3.5K RPM.
Hence, the stock setup is still a culprit.
Lachlan is offline   Reply With Quote
Old 11-14-2013, 01:50 PM   #56
Ozzman
Drives: old
No, what you are dealing with is a separate problem, an improperly torqued axle nut. That won't break the axle, just make noise.
Ozzman is offline   Reply With Quote
more money than brains, stance bro
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
