#15 |
Drives: Hot Lava Scion FRS
Also Aquapel or Rain-X on your windows are pretty helpful during winter.
#16 |
Drives: Subaru BRZ Sport Tech Satin White
Good advice lower down this thread about the benefits of switching off the traction control for some winter driving. Loose snow can give more grip if the wheels spin a little. VSC allows some wheelspin but for full throttle control you need traction control fully off.
Be aware that once the traction control is active during any ignition event you can't switch it off, at least on my BRZ. once it is active even once and even only briefly you have to switch off the engine and engage the park brake be fire restarting and then switching off the traction control This is annoying and must be some liability lawyer's idea! |
#17 | |
Drives: TRD Ultramarine '13
If you're going to do it, make sure when you're doing it, spray a few coats, and then roll or car forward or backward so your wheels turn over exactly halfway so any parts of the spokes that were on the bottom are now on the top, so you can get all angles of the wheel. I did 3 coats of black first, then turned wheels halfway, then 2 more coats of black. One light coat of silver metallizer (I didn't turn the wheels for this part, just make sure you get the wheel from all angles just in that one coat), and then 2 coats of glossifier on top (again, just make sure you get all angles, no need to turn wheels again). I used about 2 cans of black in total. But I had 4 cans of black with me just in case. I'd get at least 3 in case you mess up and need to restart. I had 2 sitting in a sink filled with hot water from the tap just to keep the paint inside nice and warm so it sprays out evenly instead of in globs (I plasti dipped while it was snowing lol). Came out pretty nice and it's not matte black, which is what I wanted. You can do any colour you want and it's removable when you get tired of it. ![]() |
#18 |
Drives: 2013 Scion FRS
I picked up my FRS last winter but got my dealership to store it until snow was minimal. This year, I'll be driving it throughout winter, and TBH I'm a bit worried.. but here's what I've got so far:
- Winter tires: Still shopping..to be determined - Installed weathertech digitalfit mats. Love them to death. - using my leafblower to clean snow off roof and hood. I care too much about my paint to take a brush to it - 100lbs of additional weight in the rear - small shovel in the trunk - Thinking about plastidipping my front bumper as well as the lip of my quarters/fenders to protect them from chips - Thinking about rallyarmour mudflaps..but my budget is pretty tight atm. -Telling everybody not to go anywhere near my car with a snow brush. My dad thinks he's doing me a favour every morning when he used to clean the snow off my car with a frikkin floor broom LOL. If anyone else has suggestions, it'd be greatly appreciated!
![]() 2013 Firestorm Scion FRS 2005 Civic SI Sedan- Sold 2004 Impreza WRX - Sold 1992 Civic Hatchback - Parted, RIP |
#19 | |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
I got one similar to this at Canadian Tire on clearance back in September. |
#20 |
Drives: 13 BRZ Limited 6MT GBS
I am. It won't be my first winter in a RWD car, I did two in my Oldsmobile, which was more front-heavy, had all-seasons, and didn't have traction control, so I'm not particularly worried.
BRZ currently has OEM mudguards and ~100 lbs of sound deadening that's all behind the front wheels, so weight distribution is probably a bit more balanced than stock. Don't plan on adding ballast unless I start having problems. I've got 16x6.5" wheels from an '02 WRX with some fairly worn Bridgestone all-seasons in 205/55R16 (10mm narrower than stock, but very close to stock diameter). I've done the winter + RWD + allseason combo twice before, so I'm going to give it a shot. I'll probably go to winter tires (or at least allseasons with good cold/wet performance) once the current all-seasons are done, or earlier if necessary. EDIT - whoops, apologies for posting in the "Canada" section when I live in PA. I always browse with "New Posts" and sometimes I don't notice what section I'm posting in. This isn't the first time I've posted in a regional forum that I don't belong in by accident.
#21 |
Scratching your paint by using a cheap snowbrush is very real. Some are awful.
Always buy a good quality brush if you are going to sweep off your car. Check that the bristle ends have been softened properly. Replace frequently or you'll be polishing scratch marks that look like straight swirls for hours come summer. |
#22 |
Drives: Subaru BRZ Limited
I just make sure to never brush beyond keeping a small layer of snow on the car. Enough that will drift off when I start driving (not too much to be dangerous to other drivers), and the rest I let melt off on it's own.
#23 |
Drives: 2013 GBS BRZ (AT)
During day with no ice or snow on the ground, would it be a bad idea to drive with summer tires? I have Michelin PSSs and I plan to do some highway driving just for the purpose of keeping the car fresh.
#24 |
Thanks
#25 |
No it's not fine. In freezing cold temps PSS's will eventually warm up but the roads are so cold, that traction becomes a HUGE problem even on dry pavement.
I guess it's fine if you don't mind shitting your pants when the car gets extremely skittish.
#26 | |
![]() But I think you've got everything covered. Plastidip the bottom part of the bumper, or at least get a clear bra that'll go over the "fangs" because I'd assume that would get damaged really quickly since that part does tend to act as a snow plow in heavy snow. |
#27 |
Drives: 2013 frs
this is my first winter with a rwd car
i tested an frs last february on some snow, and it had stock tires....it wasn't that bad....i would still like to take the car somewhere where i can learn how to drive it properly.....hopefully soon anyway, i got mine to krown couple of weeks ago, and put 16'' winter tires on but i am thinking i'll keep the frs tucked away when a snowstorm hits, and take the passat out......and that is only if i really have to go somewhere |
#28 |
Thanks for the tips and pics. Tires look great! The removable tempts me to do a crazy color but i dont want to waste money and time if I don't like it. This year ill do red and see how it goes..
| Tags |
| 7thgear rulz, kryptonite allergy, suberman cant drive |
| winter driving | jmaryt | Scion FR-S / Toyota 86 GT86 General Forum | 88 | 11-11-2013 11:15 AM |
| Winter Driving Tip. | NOHOME | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 03-06-2013 05:38 PM |
| Practice winter driving | 4U-GSE | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 01-26-2013 10:29 AM |
| How many are planning on winter driving? | NV Auto | CANADA | 109 | 01-11-2013 09:30 PM |
| winter driving | paraguin | BRZ First-Gen (2012+) — General Topics | 25 | 08-03-2012 05:26 PM |
