Old 10-27-2013, 02:07 PM   #169
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
Wouldn't you be better off with 255/35?
Enraged21 is offline   Reply With Quote
Old 10-27-2013, 02:25 PM   #170
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
245/35/18 or 255/35/18 should fit best. 245 will have a slight strech however
Killerbee is offline   Reply With Quote
Old 10-27-2013, 02:49 PM   #171
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
I went with 255/35 on kiwami. Good to hear you are getting proper tires for these wheels.
Sent from my SGH-T999 using Tapatalk
hanabie is offline   Reply With Quote
Old 10-27-2013, 11:52 PM   #172
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
if you go with a 245, go with a 40 sidewall. 35 is too short for that and it will still be stretched unless you get a tire that runs wider like a Zii or MPSS...still might be stretched.
as i said in your PM your best bet would be to run a 255/35 however you will have to raise your car a bit.
Jive Turkey is offline   Reply With Quote
Old 11-08-2013, 08:47 AM   #173
rosgonz
Drives: 13 Asphalt FR-S
Originally Posted by Metabrz View Post
what are the specs on this setup?
rosgonz is offline   Reply With Quote
Old 11-08-2013, 01:03 PM   #174
RavSpec
Drives: Rx7
Should be 18x9.5 +30 or +38 .. Same concave face. +30 sits more flush with lower suspension. +38 will be good if you don't want to slam the car.
RavSpec is offline   Reply With Quote
Old 03-12-2014, 04:49 AM   #175
Stayreal
Drives: 13' Scion FR-S
anyone has a picture of it HotLava with the black one?
Stayreal is offline   Reply With Quote
Old 06-30-2014, 06:34 PM   #176
willharp360
Some shots of the fitment and a close up of Project Kics R40 Neo-Chrome lugs
willharp360 is offline   Reply With Quote
Old 08-13-2014, 11:11 PM   #177
bren5279
Drives: series.blurrr
Anyone got any in hyper silver?
bren5279 is offline   Reply With Quote
Old 10-02-2015, 08:06 PM   #178
In1t
In1t's Avatar
Drives: Black Limited JDM BRZ
Just got a set of Work Kiwami 18" 9.5 +38 MBL (black), 235/40/18. Full stock, no rubbing so far.
In1t is offline   Reply With Quote
The Following 2 Users Say Thank You to In1t For This Useful Post:
Here2rock (11-19-2015), Metabrz (11-21-2015)
Old 11-19-2015, 06:48 PM   #179
Here2rock
Drives: 86 GTS
How does it drive after the change from stock? Car looks amazing! Are you going to lower it?
Here2rock is offline   Reply With Quote
Old 11-20-2015, 12:12 AM   #180
In1t
In1t's Avatar
yep, gonna lower it when I get new coilovers. the car feels like a train now very sticky in corners. it took me a while to get used to how why it is now
cr ultimate, fitment, ultramarine, work wheels
Wheel Directory: Work Emotion CR-Kiwami 18x8.5 +38 Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 03-21-2018 05:18 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +38 kimchangil424 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 01-03-2017 06:00 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x9.5 +38 Killerbee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 03-08-2014 04:49 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x10.5 +32 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 02-25-2014 06:00 AM
WTB: Work Emotion Ultimate Kiwami Wheels Center Caps hanabie Want-To-Buy Requests 0 10-25-2013 06:34 PM
