| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#169 |
#RememberTheBuster
Drives: Firestorm FRS MT
Wouldn't you be better off with 255/35?
#170 |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
245/35/18 or 255/35/18 should fit best. 245 will have a slight strech however
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
#171 |
Drives: WRB LMTD '13
I went with 255/35 on kiwami. Good to hear you are getting proper tires for these wheels.
Sent from my SGH-T999 using Tapatalk
#172 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
if you go with a 245, go with a 40 sidewall. 35 is too short for that and it will still be stretched unless you get a tire that runs wider like a Zii or MPSS...still might be stretched.
as i said in your PM your best bet would be to run a 255/35 however you will have to raise your car a bit. |
#173 |
Drives: 13 Asphalt FR-S
#174 |
Drives: Rx7
Should be 18x9.5 +30 or +38 .. Same concave face. +30 sits more flush with lower suspension. +38 will be good if you don't want to slam the car.
#175 |
Drives: 13' Scion FR-S
anyone has a picture of it HotLava with the black one?
#176 |
#177 |
Drives: series.blurrr
Anyone got any in hyper silver?
#178 |
Drives: Black Limited JDM BRZ
Just got a set of Work Kiwami 18" 9.5 +38 MBL (black), 235/40/18. Full stock, no rubbing so far.
#179 |
Drives: 86 GTS
#180 |
| Tags |
| cr ultimate, fitment, ultramarine, work wheels |
| Wheel Directory: Work Emotion CR-Kiwami 18x8.5 +38 | Jeff Lange | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 03-21-2018 05:18 PM |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +38 | kimchangil424 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 01-03-2017 06:00 PM |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x9.5 +38 | Killerbee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 03-08-2014 04:49 PM |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x10.5 +32 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 02-25-2014 06:00 AM |
| WTB: Work Emotion Ultimate Kiwami Wheels Center Caps | hanabie | Want-To-Buy Requests | 0 | 10-25-2013 06:34 PM |
