Old 11-06-2013, 07:12 PM   #1
qqzj
Drives: MDX, Camry
FA20 vs. Cayman engine? Need ur backup.
Today had a heated debate on FA20 vs. the engine of Cayman. I was trying to argue that if FA20 becomes a 6-cylinder engine, it would be equal or better than Cayman's. In the end, I do not think I won, but I do not think I lost either. So need ur guys' support to win the argument.
Simply put,
Cayman,2.7L H6 275HP, 101HP/L, 213lb-ft, 79lb-ft/L
Cayman S, 3.4L 325HP, 96PH/L, 273 lb-ft, 81lb-ft/L
FA20, 2.0L, 200HP, 100HP/L, 151lb-ft, 76lb-ft/L
All engines' torque curves have a dip early and have a flat top from 4500rpm to 6500rpm.
On the HP side, it seems that larger cylinder always loses a little. So we are fine. We lose a little on torque/liter, but that is a minor issue. Anybody can help me win the argument?
qqzj is offline   Reply With Quote
Old 11-06-2013, 07:19 PM   #2
fatoni
i dont think engines provide a linear relationship between power and size. its why any car that ever put out 120ish hp/liter is either a tiny motor or a six figure car. its a hypothetical argument that would be won or lost based on further hypotheticals. if you assume the fa20 would be engineered to be better, you win. if not, you lose.
The Following 2 Users Say Thank You to fatoni For This Useful Post:
Sportsguy83 (11-07-2013), strat61caster (11-07-2013)
Old 11-06-2013, 07:23 PM   #3
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Simply put,
What makes you say that the FA20 is better? It looks to me like all 3 of them are pretty similar in output per liter, with the Cayman engines perhaps slightly ahead in torque...
As for the larger cylinder losing a bit? I suspect a bit of that is simply due to Porsche not wanting to overlap too much with the base 911, which makes 350hp out of a 3.4L (which is probably nearly the same engine as the 325hp one in the Cayman S).
chrisl is offline   Reply With Quote
Old 11-06-2013, 07:51 PM   #4
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
My favorite engines are the FA20 and Fiat's little 1800cc DOHC. Horsepowers and torques are just numbers. I win. The end. :-D
NWFRS is offline   Reply With Quote
Old 11-06-2013, 07:53 PM   #5
OrbitalEllipses
Drives: Attitude
Everybody knows that engine is gimped from the factory because a Cayman S would stomp the 911 if it had a real engine.
BlueDubbinTDI (11-07-2013)
Old 11-06-2013, 09:07 PM   #6
Kostamojen
I'd recommend using the Subaru EZ30 as a benchmark as well. It put out 250hp with a 3.0L WITHOUT direct injection or a high compression ratio!
Some Porsche guys have actually used those Subaru motors in place of expensive Porsche motors...
Old 11-06-2013, 09:41 PM   #7
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Simply put,
You are correct. Porsche needs to sharpen up a little to keep up.
Just BTW, a six will fit easily into the BRZ engine compartment. And Subaru already makes a 3.0 six.....
Suberman is offline   Reply With Quote
Old 11-06-2013, 09:43 PM   #8
Suberman
"Nearly"?
It is exactly the same engine. Porsche won't let the Cayman have equal power because that would illustrate perfectly what everyone already knows: the 911 is an inherently stupid design.
Old 11-06-2013, 10:26 PM   #9
qqzj
Drives: MDX, Camry
yes, but that will make BRZ too nose heavy. how to deal with that?
Old 11-06-2013, 11:26 PM   #10
Tgionet
SPACESHIP
Tgionet's Avatar
Drives: BRZ Ltd 6MT WRB
"Nearly"?
Tgionet is offline   Reply With Quote
Old 11-06-2013, 11:43 PM   #11
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
"Nearly"?
yeah everyone's known that for the 50 years its been in production
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 11-07-2013, 08:40 AM   #12
Suberman
There's a racer's saying: you can't make a race horse out of a pig, but if you spend enough money you can make a very fast pig.....
Takes a while also.
Old 11-07-2013, 08:41 AM   #13
Suberman
Transaxle?
Move the battery to the trunk?
Don't worry about it since the rear tires will be smoking most of the time anyway?
Old 11-07-2013, 12:02 PM   #14
chrisl
"Nearly"?
To be fair, the 911 has a significantly less restrictive intake than the Cayman, but I can't imagine that accounts for more than 5 or 10 horsepower - most of the 25hp difference has got to be in tuning (unless they have different cams, but that would be a lot of effort just to differentiate the 911 and the Cayman).
As for the stupidity of the 911 design? The new ones are quite good - the amount of grip they have coming out of corners due to the weight over the rear is pretty astonishing. Also, I know a fair number of 911 owners to whom the rear seat was an important factor in their purchase decision, and the Cayman would never work for that. I wish they'd bring out a higher end model of the Cayman too though - a Cayman GT3 would have a lot of potential.
epeen battles, who really cares
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
For sale FA20 engine with transmission alien Engine, Exhaust, Bolt-Ons 0 10-15-2013 01:58 AM
4UGSE/FA20 engine or swap? jordydiaz Scion FR-S / Toyota 86 GT86 General Forum 15 04-04-2012 06:00 PM
