Old 10-20-2013, 01:05 AM   #421
MeFryRice
Drives: '13 SWP BRZ
I'm glad I found this thread. I originally had my heart set on T2's but may just run the T0's with the 350 spring rate. This should be sufficient for the 2-3 track days, and mountain runs I participate in yearly. This is also my daily driver and don't really need jaw chattering firmness. lol.
@Racecomp Engineering, are the T0's readily available?
MeFryRice is offline   Reply With Quote
Old 10-20-2013, 07:33 PM   #422
At home on a Sunday, but I believe the answer is yes we have some in stock or on their way. Call or PM us tomorrow.
- Andy
Old 10-24-2013, 08:39 PM   #423
mfbmike
Drives: 2013 FRS, 2008 R32
mfbmike is offline   Reply With Quote
The Following User Says Thank You to mfbmike For This Useful Post:
Racecomp Engineering (10-25-2013)
Old 10-29-2013, 05:40 AM   #424
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
Am I the only one that has the helper springs fully compressed even when the car is up on jack stands?
Overland'n'5thGEN is offline   Reply With Quote
Old 10-29-2013, 08:03 AM   #425
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
*Racecomp Engineering BRZ/FR-S Tarmac lowering springs. (5kg/5kg spring rates, 20mm drop, intended for Konis or possibly an upcoming Bilstein fixed perch option.)
Any update on when we can expect the Bilstein fixed perch option to be released? Or has that option been shelved?
Fizz is offline   Reply With Quote
Old 10-29-2013, 11:25 AM   #426
That will depend on your ride height.
- Andy
Old 10-29-2013, 11:26 AM   #427
Checking with Myles but I think the standard Bilsteins will be out pretty soon, our own revalved version not too long after.
- Andy
Old 11-02-2013, 04:11 PM   #428
jack43
jack43's Avatar
Drives: Sterling Silver BRZ Limited MT
Thanks for all your help Myles! The car drives great.
specs:
RCE Tarmac 0 coilovers 350/350
SPC '2nd gen' rear control arms, toe kit
Subaru 'Group N' top mounts
Subaru conical washers
Whiteline front crontrol arm inner bushings
stock camber bolts
front - 2.5deg/ 0 toe
rear - 2deg/ 1/16" toe in
height: 25.7"/ 25.9" to top of fender arch
jack43 is offline   Reply With Quote
The Following User Says Thank You to jack43 For This Useful Post:
Racecomp Engineering (11-03-2013)
Old 11-02-2013, 05:54 PM   #429
jack43
jack43's Avatar
another pic:
Old 11-03-2013, 03:25 AM   #430
mfbmike
Specs on wheels and tires @jack43?
Old 11-03-2013, 09:40 AM   #431
jack43
jack43's Avatar
wheels:
WedsSport TC105N 18" gunmetal 8.5 +43, 9.5 +35
Hankook Ventus RS3 235-40, 255-35
custom @kask2_6.0 hub rings/caps
Muteki steel open ended lugnuts
actual weights: 16.8/18.2lb, complete with tire 42.1/43.7lb (171.6lb/set)
Old 11-06-2013, 09:44 AM   #432
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I've read somewhere that the V1/ST/T0 uses damper cartridges inside the threaded body whereas the V3 uses cartridge-less twin tube design? Is that true?
Is anyone using the T0 experiencing knocks or sounds from their coilovers? I ask because there seems to be a number of other forums where guys using the V1 have complaints about weird sounds apparently due to the cartridges moving inside?
Please enlighten me...?
Old 11-06-2013, 10:00 AM   #433
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
I have about 2000 miles on mine so far with the 350 springs, and no noise at all.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 11-06-2013, 12:59 PM   #434
mfbmike
RCE Tarmac 0's
Maxed out the fronts. Matched the rears.
265/35/18 Michelin PSS on 18x9.5 +40 SBC Enkei NT03's
FR-S Matt (11-06-2013)
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-16-2013 11:02 PM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-13-2013 11:26 PM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 08:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 12:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 01:44 AM
