Old 06-05-2013, 03:37 PM   #15
OrbitalEllipses
Drives: Attitude
Yep, this ones are destiny for me. Been waiting and waiting to get a suspension. Was set on RCE yellows, then started looking at other brands coilovers, was SET to get them last week and this one come in the radar.
I will order this week the Tarmac 0's. Bart Scott's voice: " CANT WAIT!".
>:[ Pissed I bought and installed Koni+RCE Yellow combo now.
Was going to just get some RCE Yellow springs with the stock struts, but the Tarmac 0s look like an even better option...
It is.
Old 06-05-2013, 03:39 PM   #16
siXXtoes
Ohh Snap
siXXtoes's Avatar
Drives: Argento FR-S
Great products RCE!
Question about the 0's- what would you recommend getting for the suspension to compliment these in terms of bushings or LCA/UCA?
P&L EL headers and over-pipe, ARK Grip front-pipe and cat-back exhaust, Delicious Tune, Rays Gram Lights 57DR 17x9 +35 wrapped in Bridgestone RE11a's
SoCal SD 86 Club Admin
https://www.facebook.com/groups/socalsd86/
siXXtoes is offline   Reply With Quote
Old 06-05-2013, 03:50 PM   #17
OrbitalEllipses
Drives: Attitude
Originally Posted by siXXtoes View Post
Great products Miles!
Front control arm camber bushings, camber bolts, etc..
Old 06-05-2013, 04:48 PM   #18
Racecomp Engineering
I will say that it depends. Yes you can go to town on bushings and that will make a good improvement (icing on the cake) but depending on your needs you may not need anything.
Rear camber bushings or rear LCAs will be helpful but not 100% required. More so with a bigger drop.
- Andy
Old 06-05-2013, 05:06 PM   #19
Calum
That Guy
Drives: 2013 asphalt FRS MT
Any chance you could dyno a set of Koni yellows and include that in the dyno post? I'm guessing there are a lot of us would love to know how they compare.
About the conical washer, is that required with your yellows and com-c mounts? I'm not completely sure of the purpose of those.
Another amazing looking pair of products guys!
Old 06-05-2013, 05:16 PM   #20
We'll see what we can do on the Koni dyno...
For the conical washer, you need it there IF you are no longer using the OEM upper spring perch (which has it's own washer welded on top). So for RCE Yellow peeps no need for the conical washer.
Have a few more products coming soon as well *.
- andy
*Racecomp Engineering BRZ/FR-S Tarmac lowering springs. (5kg/5kg spring rates, 20mm drop, intended for Konis or possibly an upcoming Bilstein fixed perch option.)
Old 06-05-2013, 07:28 PM   #21
Calum
That Guy
- andy
Will you guys be selling the Bilstein's with your own valving?
Old 06-05-2013, 07:48 PM   #22
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Sorry I'm really new to suspension stuff. Why do I need aftermarket LCA/UCA? for chamber adjustment?
hanabie is offline   Reply With Quote
Old 06-05-2013, 08:48 PM   #23
Calum
That Guy
The car doesn't have any camber adjustment from the factory. With a strut you can move the position of the top mount to gain negative camber, or use bolts between the strut and knuckle that allow movement. In the rear the only way to gain negative camber is to shorten the upper control arm, or lengthen the lower control arm. The top factory arm can effectively be shortened via bushings, but they are a pain in the butt to install and adjust. The lower factory arm has been adjusted with strut bolts, there's a thread about this that you should read first though.
Old 06-05-2013, 09:18 PM   #24
hanabie
hanabie's Avatar
which one would that be? thanks
Do I need to adjust those every time I lower my car? especially I introduce new wheels.
Thanks
Old 06-05-2013, 10:21 PM   #25
GreggoEggo
Drives: Future BRZ DMG
Some "noob" questions for anyone that has the patience to answer... long time lurker, first time poster and I don't own a BRZ....yet.
Was planning on just going with RCE Yellow springs but this Tarmac 0 option looks interesting. If my goal was a high performance dd that could provide the final cure for any porsche envy I may still have, would this offer tangible advantages over a Yellow springs & Koni combination? I know coil overs leave more room for larger wheels/tires, and allow for deeper drops, but if I am focused on the "go" and not concerned with the "show"....does it make sense to just go straight for the Tarmac 0 when the time comes?
Thanks,
Greg
GreggoEggo is offline   Reply With Quote
Old 06-05-2013, 10:26 PM   #26
FR-S Matt
I'm very interested in the Tarmac 0's. I think this will give me the clearance I need on my Enkei RPF1's 18X9.5 +38's up front. Love the color, and the options for what I need are perfect. Seems like a great, high quality product!
PM'ing for pricing.
Old 06-05-2013, 10:36 PM   #27
UncleFester
If I didn't have V3's already I'd be gunning for the club sports. Good stuff.
UncleFester is offline   Reply With Quote
Old 06-05-2013, 10:48 PM   #28
yes its a collaborative effort thru our sister company GTWORX. We already have 08-2013 WRX fitment, 2010 LEGACY GT fitment(due in 2 weeks) and 08-2013 STI fitments. Our sister company GTWORX started working with BILSTEIN USA back in early 2009 to develop a oem fitment option for the 08+ WRX which had ZERO shock options. So this isnt a "new" thing for GTWORX to co-brand with BILSTEIN on the fixed perch style strut/shock option.
So yes we establish the type of valving we want and for what range of spring rates and the drop. We work directly with the engineers at Bilstein west to find the best profile for our needs. This is done over a period of 2 weeks on Socal roads. We then take a sample set back to the east coast and put roughly 2-3000 east coast , horrible road miles on the prototypes. Its then signed off on and approved for production. Prior to that we normally try about 20 different valvings.
Hope that help understand the process.
Keep in mind that option from GTWORX is 6 months out at a minimum.
Myles Williams
RCE founder.
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-16-2013 11:02 PM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-13-2013 11:26 PM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 08:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 12:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 01:44 AM
