Old 11-06-2013, 11:02 AM   #1
Turbo Den
Drives: FRS, IS300, 911sc
Which tune can hold redline?
which tune can hold the redline, instead of bouncing back like stock, or drop off from a cliff like my ecutek now.
I want the tune can hold the redline for two seconds max.
Thanks
Turbo Den is offline   Reply With Quote
Old 11-06-2013, 11:22 AM   #2
canu_50
canu_50's Avatar
Drives: Scion fr-s
With OFT you can adjust the redline bounce to soften it up just like in old days car!
canu_50 is offline   Reply With Quote
Old 11-06-2013, 11:29 AM   #3
empower-auto
Kouki-Monster
empower-auto's Avatar
Swap in a 1JZ
edit: ...
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following 2 Users Say Thank You to empower-auto For This Useful Post:
canu_50 (11-06-2013), SmsAlSuwaidi (11-06-2013)
Old 11-06-2013, 11:32 AM   #4
ducks
Drives: car
moto-mike @ moto-east offers tunes with that feature
ducks is offline   Reply With Quote
The Following User Says Thank You to ducks For This Useful Post:
Xero-Limit (11-10-2013)
Old 11-06-2013, 01:02 PM   #5
xjohnx
Grip>Slip
xjohnx's Avatar
any tuner can do this, but i believe Moto-Mike was the first to offer the softer limiters on this platform.
Old 11-06-2013, 02:00 PM   #6
jamesm
Yeah that's a super easy change. Set rev limiters to x and x-50 where x is your intended redline.
Old 11-07-2013, 06:25 PM   #7
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Thanks
EcuTek can be used to tune the rev limits. Instead of the factory 200rpm and 350rpm bounce, it can be set to a much lower value such as 50 or even 20 rpm hysteresis for a much smoother rev limiter.
Circuit Motorsports is offline   Reply With Quote
Old 11-09-2013, 12:00 PM   #8
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
As others have stated.
Most all if not every tune can be easily ... tuned for this.
An exaple in Open Flash Tablet▼
Originally Posted by Shit Luck View Post
rev limiter- would like the car to stay on it so to speak for sliding.
Originally Posted by shiv@vishnu
Rev Limit: There are two rev limits, A and B.
You can find them by going to the Limit category. Keep both Rev Limit A and B set to the same values.
In each parameter, there are two values.
The bigger (first) value on defines the RPM at which ignition is cut.
The smaller (second) value defines when ignition comes back on.
The default map has a 150RPM difference between the two values.
This softens the rev limit a bit (the stock difference is 250-300rpm IIRC).
You can soften the limit more by raising the lower value close to the value of the upper value.
So using 7600 and 7550 will be pretty soft feeling!
Shiv
I'm not promoting one system over another.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 11-10-2013, 10:26 PM   #9
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Not quite that easy
It is one thing to set a lower hysteresis, yet another to do what we do. The lower hysteresis bounces the cam chain to death and rattles the pistons off the wrist pins, while ours is buttery smooth like a dirt bike rev limit. We use custom mapping to do this via RaceROM, and it is switchable with maps. Won't do that with anything else.
Xero-Limit is offline   Reply With Quote
The Following 4 Users Say Thank You to Xero-Limit For This Useful Post:
Circuit Motorsports (11-14-2013), CSG Mike (11-12-2013), Drift-Office (11-12-2013), Fast_Freddy (11-13-2013)
Old 11-12-2013, 01:27 PM   #10
yuicebox
Drives: Asphalt FRS
Originally Posted by moto-mike View Post
Not quite that easy
so how exactly is yours different? like what about the custom mapping prevents bouncing the cam chain and rattling the pistons? not doubting, just not sure I understand
yuicebox is offline   Reply With Quote
Old 11-12-2013, 02:32 PM   #11
CSG Mike
CSG Mike's Avatar
We have the timing pulled up top, so the output drops so dramatically that the engine physically won't rev any higher.
We do this to protect the blower, cam chain, and any thing else in the engine that doesn't really want to see shock load.
This results in ZERO bouncing. The car sits at redline similar to how the car would sit at 2k rpm, if you stepped on the gas pedal to get to 2k RPM and held your foot at the right position.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Circuit Motorsports (11-14-2013), jeebus (11-12-2013), Shiv@Openflash (11-12-2013)
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
TRD: does TRD hold much significance anymore? Jertronic Scion FR-S / Toyota 86 GT86 General Forum 22 06-15-2013 12:35 PM
Unable to hold idle. CSG Mike Issues | Warranty | Recalls / TSB 22 05-20-2013 06:00 PM
How to get a hold of Subaru of Canada? chenshuo CANADA 10 02-21-2013 01:23 AM
Subaru, Audi, M-B hold value best Axel Other Vehicles & General Automotive Discussions 4 01-14-2010 09:12 PM
