Old 11-06-2013, 02:47 AM   #1177
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Originally Posted by Brody602 View Post
Found this on tradesolution,
Actually wondering if it would be a perfect fit, if it would be able to run Torque out of the box and what color the leds are
http://tradesolution.hk/e/ptxwebstore_product/1707.html
I don't believe any of them can run Torque out of the box. you would need to root it first.
As the root files have only been tested ths far on the TUN21 or T7019A why not just go with the T7019A since it will fit in the FRS with no changes. Only issue is the LEDs are green though.
If you email them they will tell you what colour the LEDs on the one you are looking at are.
nzer is offline   Reply With Quote
Old 11-06-2013, 06:35 AM   #1178
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Well it's running android 4.0 so I have a feeling it might be able to work Torque out of the box, and if I don't have go through the trouble of rooting it and what not, I think that might be the better option. This one is a Toyota unit as well so I am guessing fitment should be the same. I sent them an email with a few questions, just waiting on a reply.
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 11-06-2013, 08:37 AM   #1179
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Way back in this thread (somewhere) I thought the OP had looked at different android 4 units and found they weren't pure android but running CE. ?? Interested in what you find out from the manufacturer as it looks like a decent unit yet costs less that the other models. Wonder why?
Sent from my SPH-L710 using Tapatalk 2
pixel67 is offline   Reply With Quote
Old 11-06-2013, 09:34 AM   #1180
Brody602
Drift King
Brody602's Avatar
I was curious as to why it was cheaper As well, seems to include all the key features as the other one including capacitive touch. And btw, in the title it specifys that it is infact a PURE android unit
Old 11-06-2013, 12:56 PM   #1181
nzer
nzer's Avatar
The issue out of the box is that the Bluetooth communication is generally locked down to only communicate with phones and will not communicate with an ELM327 or an HKS OB-LINK.
I should have answered the "out of the box" issue a little better in my last post. Pretty much all of theses units (incl TUN21 and T7019A) will run torque or carscope out of the box but won't receive the ELM327 or OB-LINK data.
Keen for you to try it though. Maybe the supplier will agree to send to you and if it won't do what you want then refund your money if you send it back.
Old 11-06-2013, 05:20 PM   #1182
Brody602
Drift King
Brody602's Avatar
Thanks for the additional info! Still waiting on an email from them with more info!
Update:
They Emailed me back with little more info, the unit would aparently also be a perfect fit like the T7019A, and has the same features, the LED's are orange/amber, when asked about the ELM327 he said he doesn't think it will work. The reason why the unit is less expensive is because it is from a different manufacturer.
Does anyone know if there are root files for 4.0 firmware out there that would work?
Old 11-06-2013, 06:40 PM   #1183
nzer
nzer's Avatar
Update:
Orange/Amber LEDs would make it a better option than the T7019A for the FRS/86.
I have no idea about root files though. @GreenPants or @2forme might know. @2forme might have a contact at Xda developers that might know or you could post over there to see. http://forum.xda-developers.com/
The Following User Says Thank You to nzer For This Useful Post:
Brody602 (11-06-2013)
Old 11-06-2013, 07:14 PM   #1184
Brody602
Drift King
Brody602's Avatar
Not to mention better performance specs and a more recent firmware , if there is a root possible for this, i'm definitely buying it!
Old 11-07-2013, 07:24 AM   #1185
2forme
That unit definitely looks interesting. I doubt it will support bluetooth OBD2 out of the box, but Android 4.0 supports USB-OTG natively, so you should be able to use a USB OBD2 dongle.
The Following 2 Users Say Thank You to 2forme For This Useful Post:
Brody602 (11-07-2013), nzer (11-07-2013)
Old 11-07-2013, 07:48 AM   #1186
Brody602
Drift King
Brody602's Avatar
Do you know if it would support a wifi obd2 dongle in that case as well?
Old 11-07-2013, 09:27 PM   #1187
sciallo
Drives: 4 wheels and a steering wheel
Does anyone know of a way to reset EVERYTHING to default? I noticed that reflashing, wiping and or resetting doesn't erase some of the low level firmware settings such as panel button mappings, boot logo, TV Mode, TV Norm, Fan Temp. and such... - any way to reset those?
After updating the rom with hal9k+greenpants rooted rom I lost all audio from built in apps or android apps. I get absolutely no sound out of the speakers other than the key-press beeps if I enable that in the settings. I tried resetting with the Rst pen button, full power off, factory wipes, reflashing all stock and custom roms I could get my hands on and all combinations of the above.
Before rooting I had:
Android version: 2.3.7
MCU version: 2.11.4-1-10-0101
System version: 2.20.21
DVD version: 2.13.11-1200wb
I can't find an update with MCU 2.11.4-1-10-0101 out there and I suspect that's where things might have changed...
I have a request out with the seller for a stock rom hoping that fixes it. Any suggestions in the mean time?
sciallo is offline   Reply With Quote
Old 11-11-2013, 11:30 AM   #1188
2forme
Wifi operates in Ad-Hoc mode, which requires root to access.
Old 11-11-2013, 11:34 AM   #1189
Brody602
Drift King
Brody602's Avatar
Alright, I'll probably order it within a couple weeks, hopefully I can get torque to work with a usb elm327. If not hopefully I can get it rooted
Old 11-11-2013, 12:55 PM   #1190
nzer
nzer's Avatar
Weird. Are you saying you get no sound from the stock music app and navi?
@GreenPants do you have any ideas as I haven't had this happen to me so can't see it being a root file issue given most of us have not had this occur.
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-19-2013 11:51 PM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 10:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 03:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 05:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 10:47 PM
