Old 11-03-2013, 10:08 AM   #43
BRZnut
Drives: BRZ DGM Limited
Originally Posted by Muskokan View Post
well i have a jack and blocks i can use? i just want to know if draining at an angle will still get all the crap out.
anyone?
From reading around this forum, people seem to have no issues with removing all the oil with the front of the car higher that the rear on ramps, so I would think you would be ok with the front jacked up some.
http://www.ft86club.com/forums/showthread.php?t=9221
If you do it and get at least 5.5 QT out you should be good
Old 11-04-2013, 12:36 PM   #44
Mikem53
Drives: FR-S 6MT
Just completed my first oil change on this car at 4350 miles.
Used my trusty old rhino ramps I've had for 20+ years.
Car just dove up with no problems or clearance issues.. Oil change was easy.
Hardest part was separating the factory crush washer from the drain bolt.
It was painted black like the bolt and I had to use a razor to separate it from the bolt. Very easy to do on this car.. Especially the filter.. Like my bimmer.. Easy access up top.
Mikem53 is offline   Reply With Quote
Old 11-05-2013, 10:49 AM   #45
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
Originally Posted by M1K3 View Post
Sorry for the Thread Jacking
Yes it's all screwed together:
http://farm8.staticflickr.com/7377/1...0b9a14a4_b.jpg
But you can make it like lego if you want. Here is the site I got the info from to make it: http://www.myturbodiesel.com/1000q/multi/wood-block.htm (My setup and measurements differ slightly from what is on the site)
As for maxing out the jack it's not too bad:
http://farm3.staticflickr.com/2812/1...ac4f0a4b_b.jpg
http://farm4.staticflickr.com/3747/1...ff49e7c8_b.jpg
I can even stack my suv on it, but I got to use blocks on the jack:
http://farm4.staticflickr.com/3783/1...221568c6_b.jpg
Hmm, I will do this next summer! Will be useful when I'm going to install exhaust, but probably end up getting someone else to do it for me.
I usually just drive half way up the rhino ramp (using 2x4s before the slope), then jack my car up since I don't have racing jacks for oil changes.
Myv is offline   Reply With Quote
Old 11-05-2013, 12:31 PM   #46
xxscaxx
Drives: 2013 SWP BRZ
1) pull in garage, air all the way up
2) slide drain pan under car, open up fumoto drain valve
3) unscrew filter and replace while oil is draining
4) close valve, remove drain pan, fill car and start, then check level - add oil if needed
lol
xxscaxx is offline   Reply With Quote
Old 11-05-2013, 06:17 PM   #47
frs10
Drives: tezla
are you guys getting the fumoto 108 or 108S?
how do you tighten this valve on? is it just hand screw?
frs10 is offline   Reply With Quote
Old 11-05-2013, 06:40 PM   #48
reeves
Just jack up the passenger side of the car, near the front, like how you would do if you're changing the front passenger tire. There's plenty of room to slide under there to drain the oil. Even easier with a Fumoto drain valve! The oil drains out towards the driver's side anyway, so jacking from the passenger side helps drain the oil out more thoroughly.
Old 11-05-2013, 06:41 PM   #49
stugray
Drives: 2013 GBS BRZ Limited
Maybe I'm just an old fart but I just drive the car up onto the curb and get under it. And I have rhino ramps jackstands and floor jacks...
Old 11-05-2013, 06:45 PM   #50
reeves
Not sure about the 108S, but this is the exact one I got:
[ame="http://www.amazon.com/gp/product/B003VCCUJI/ref=oh_details_o05_s00_i00?ie=UTF8&psc=1"]Amazon.com: Fumoto F-108 Engine Oil Drain Valve: Automotive[/ame]
You hand tighten it first, then just gotta use a big wrench or adjustable wrench to tighten it some more.
Old 11-05-2013, 08:45 PM   #51
stugray
Asking if you can reach the hole with 2.5 inches doesn't belong in maintenance section, mods please move this to off topic,
Which "section" would "Oil change questions" belong in your world then?
Old 11-06-2013, 01:49 AM   #52
j2digit
j2digit's Avatar
Drives: 2000 Integra LS, 2013 FRS Firestorm
can't go wrong with either one, both are made for the FRS/BRZ, the 108s have a short nipple that allows you to attach a hose to it for convenient draining.......
"Power is nothing without Control"
j2digit is offline   Reply With Quote
The Following User Says Thank You to j2digit For This Useful Post:
Carlitoz3 (01-08-2014)
Old 11-20-2013, 03:25 AM   #53
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
Originally Posted by BRZnut View Post
Correct me if I am wrong guys but my understanding is to never use just a jack stand to get under the car. If it slips, you're toast.
some people just use the jack and trust that alone. i sometimes do, im only under there for a few seconds. if u wanna be safe 2 stands and a jack under the rear you should be more than fine unless your on a hill or on the street or something. just shake the car before you get under it. you'll be ok.
but ramps are safer i guess.
NYCsubaruBRZ is offline   Reply With Quote
Old 11-20-2013, 10:01 AM   #54
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
I use Pittsburgh Automotive's 3-Ton Low Profile Floor Jack and jack stands.
PoorMansRacing is offline   Reply With Quote
Old 12-02-2013, 09:53 AM   #55
Krispeee
I use rhino ramps to get he front of the car up in the air. When performing a tranny/diff flush, i use two jack stands to prop the rear up while using rhino ramps in the front to get the car level.
Krispeee is offline   Reply With Quote
Old 12-02-2013, 07:06 PM   #56
OrbitalEllipses
Drives: Attitude
Just a jack is a dumb idea. Use stands *and* a jack, at the minimum. Many people will take a wheel and put it under the car as well.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
SirBrass (01-08-2014), Suberman (12-02-2013)
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 06:56 PM
Help from the ATL guys? Venom600 Southeast 22 08-16-2013 11:09 PM
what do you guys think? xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 08-16-2012 01:08 AM
What do you guys think?? Arcangel Scion FR-S / Toyota 86 GT86 General Forum 19 10-30-2009 11:06 AM
