Old 11-05-2013, 10:43 PM   #183
vgi
Drives: frs
does anyone with A01C v1.33beta tried to rev the engine? for some reason the engine couldn't pass 6k rpm and it was shaking strong.
vgi is offline   Reply With Quote
Old 11-05-2013, 11:01 PM   #184
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
shiv is there any purpose to the vented cover thing near the snorkel that mounts to the bumper beam???
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 11-05-2013, 11:02 PM   #185
cnk
Drives: '13 DGM BRZ Limited
Sounds like launch control kicking in. It's set at 5600rpm unless you change the LC RPM Delta.
Old 11-05-2013, 11:06 PM   #186
fstlane
fstlane's Avatar
Drives: BRZ Limited
I'm running A01C v1.33beta and shifted near 7k rpm a number of times today with no issues.
You may have been engaging the launch control feature if you were wot with the clutch depressed.
EDIT: Oops, I was a little late. Thanks cnk!
fstlane is offline   Reply With Quote
Old 11-05-2013, 11:23 PM   #187
vgi
Drives: frs
@cnk @fstlane thank you guys, didn't think of it.
Old 11-06-2013, 04:09 PM   #188
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
You're good jeebus - Shiv is correct. Other than that one table scaling, there was no discernable difference between A00C and A01C. If you've uploaded one of the OTS maps and it's based off A01C, the scaling will be correct (i.e. the -50 offset). I would assume that Vishnu would have standardised the OTS roms off one CAL id.
If you're using OFT to open up stock roms, not provided by Vishnu (e.g. Ecuflash extracted), and the scaling has been changed to -50 for all the A0*C roms, A00C would be incorrectly displayed - unless a separate XDF file has been created specifically for A00C. I haven't checked out the latest OFT maps, so Shiv would have to answer that one.
Td-d is offline   Reply With Quote
The Following 2 Users Say Thank You to Td-d For This Useful Post:
jeebus (11-06-2013), Shiv@Openflash (11-06-2013)
Old 11-06-2013, 06:25 PM   #189
jeebus
Like I said before, I'd rather be proven wrong
jeebus is offline   Reply With Quote
Old 11-06-2013, 06:43 PM   #190
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
So,.. I flashed the latest beta and drove to and from work. Thus far I can say that I am really not happy and would prefer to flash back to the prior beta. The prior beta pulled like a train, was snappy and the tq dip disappeared sooner as I rev'd the car.
It is a strong possibility that perhaps my car has not had time to read the ecu but I drove about 20 miles total.. to and from work. I tried to open her up a few times just so the car could experience it and learn.
I dont know what is going on between 1k to 2k but it is not a smooth rev and almost bucks slightly.
If the newest beta tune 1.33 is safer than the prior then I will accept that.. did they reduce the timing or something? if its not safer at all and the prior beta is just as safe then I may flash back.
thoughts? ill give it another commute to work.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 11-06-2013, 06:47 PM   #191
jeebus
based on the compare bin tool, the only real changes are to the scaling of the transient ignition retard, so I can't image it would feel much different anywhere else?
Old 11-06-2013, 06:48 PM   #192
jeebus
I do have a question about the Knock Detection RPM range table. Should this go up to 7650 since our redline has been raised?
Old 11-06-2013, 07:14 PM   #193
toysub
Drives: DGM
New to the OFT. Is it better to run v1.31 or v1.33beta for the first go-around (no-headers installed).
toysub is offline   Reply With Quote
Old 11-06-2013, 07:18 PM   #194
BRZ Fanboi
Drives: WRB Limited BRZ
I too feel the same thing... Not sure what was changed but the car accelerated a lot faster with 1.31 than 1.33 beta. Shifts seem smoother though.
BRZ Fanboi is offline   Reply With Quote
Old 11-06-2013, 07:24 PM   #195
clintavo
Every time I reflash, it takes a few drives (50 miles?) to get back to normal.
clintavo is offline   Reply With Quote
Old 11-06-2013, 07:29 PM   #196
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
Give it a few miles. Right after I reflashed to 1.33b the car was sluggish and the vvt didn't come on till what felt like 4.5krpm. After I got to my destination and was going home the car felt like it should.
garfull is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
anyone trying to use the openflash tablet with forced induction? FRSTEVE Software Tuning 69 12-07-2014 04:07 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
