Old 11-04-2013, 11:15 PM   #155
Millions
Millions's Avatar
Drives: Ultramarine FR-S
Originally Posted by shiv@vishnu View Post
+1
But I don't think the last released XDF has that diagnostic code defined. But it is defined in the latest XDF that I'll be releasing with the next set of maps that will be available for download tomorrow
That works for me! Thanks! And just for reference, I'm running on stock intake.
Millions is offline   Reply With Quote
Old 11-05-2013, 02:09 AM   #156
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Exclamation v1.33 beta maps are now available for download
Now available for download HERE
Big update, LOTS of changes/improvements:
11/04/13
v1.33beta Changes:
-Revised all XDFs to fix a value limiter in the Rev Limit parameters. Prior to this, editing this value would result a 3000RPM rev limiter.
-Revised all XDFs to correct a previously incorrect conversion equation for Transient Ignition Retard table.
-Revised all maps to account for the previous error in the Transient Ignition Retard conversion equation. This change will result in less transient ignition retard and improved engine response.
-Revised Stock Mapping ZA1JA00D ROM file
-All 6MT maps are now based upon the latest A01C ROM file. Prior to this, 6MTs maps were based upon the A00C with transient ignition mapping values copied from the A01C ROM file. All 6AT maps are still based upon he latest A01D ROM file.
-Added tuned map and XDF support for G series ROMs (EU market). G series XDF is not yet complete and does not define all tables. To view only defined tables, to go the upper right corner of Tuner Pro and select "Show Up To Level 1". Undefined tables are designated Level 2.
** and yes, I added the diagnostic routine toggle for P0171. And it is disabled, by default, in all the Stage 2 ROMs
Enjoy!
Cheers,
Shiv
Shiv@Openflash is offline   Reply With Quote
Old 11-05-2013, 10:26 AM   #157
jvincent
jvincent's Avatar
Saw that this was posted this morning so I flashed to 1.33 before the drive in this AM.
I'm completely stock (other than the tune). I'll report back after my lunchtime spin and drive home.
Old 11-05-2013, 03:38 PM   #158
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Props for staying on top of things, @shiv@vishnu!
When I went to upload the OFT with the new map it auto updated, but came up with an error message. Screenshot below. How should I proceed?
Intent > Content
Old 11-05-2013, 03:41 PM   #159
cnk
Drives: '13 DGM BRZ Limited
Install 1.03 of OFT Manager: http://procedetuning.com/BRZ_FR-S/do...OF_Manager.exe
Old 11-05-2013, 03:49 PM   #160
8686
8686's Avatar
Drives: 86
Have these changes been applied to the K series version I recived from you through email? Because I didnt see the ZA1J700K in the download file,
Thanks again for your kind support
11/04/13
v1.33beta Changes:
Enjoy!
Cheers,
Shiv
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 11-05-2013, 03:55 PM   #161
Shiv@Openflash
Drives: 2013 FRS
I don't have a copy of the newest K series ROM (ZA1JA01K) so I can't apply some of the changes listed in the Read me. Once I get a copy of that newest ROM version, I can create updated maps compatible with your ROM/OFT.
Shiv
Old 11-05-2013, 03:59 PM   #162
ThisGuy919
Had this error as well. Fix was pretty easy.
1 Find location of folders
2 Delete all contents (after uninstall)
3 reinstall
Seemed to have fixed mine. It seems to leave some temporary files after a regular uninstall, so reinstalling without removing ALL of the older files is useless as the temp. files are still there. Hope this helps
ThisGuy919 is offline   Reply With Quote
Old 11-05-2013, 04:01 PM   #163
Shiv@Openflash
Drives: 2013 FRS
3 reinstall
Just update to the newest version of the OpenFlash Manager (v1.03). It is available for download on our website. The older version was not compatible with the newer firmware updates.
Shiv
Old 11-05-2013, 04:23 PM   #164
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Thanks for update!
Sent from my GT-I9500 using Tapatalk
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 11-05-2013, 05:26 PM   #165
jeebus
11/04/13
v1.33beta Changes:
Enjoy!
Cheers,
Shiv
I just want to be sure...it says your maps are based on A01 now....you didn't end up fixing the transient retard conversions for A01 at the expense of messing them up for A00 right?
jeebus is offline   Reply With Quote
Old 11-05-2013, 05:33 PM   #166
Shiv@Openflash
Drives: 2013 FRS
All maps provided are actually A01 roms. We just modify a few bits to make them "look" like 700,900 and A00 roms so that they are acceptable by the oft as being compatible. So regardless of what rom type you have, everyone is running the same tune.
Old 11-05-2013, 05:34 PM   #167
jeebus
I just opened up the new 2.6xdf and the stage 1 A00C rom and sure enough I see x*0.3515625-50 for the conversion in the transient retard table.
Maybe I'm mistaken here, but isn't this going to have the opposite effect here? With the 2.5XDF you used -30, which I thought was correct for A00C roms...but that -30 was technically incorrect for A01C roms, so in truth the ECU was pulling 20 degrees more timing than it should. But with -50 on A00C, won't it do 20 too few?
Old 11-05-2013, 05:37 PM   #168
Shiv@Openflash
Drives: 2013 FRS
Assuming the A00C rom's TIR table was scaled like the A01C TIR table, there was 20 degrees too much transient retard before. If they were scaled differently, the actual TIR is unchanged. This is because all maps were based off the A00C rom.
So now it is as it should be. This table uses standard a01c values. And the roms are based off of the A01C rom. So the values in this table were not modified.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
anyone trying to use the openflash tablet with forced induction? FRSTEVE Software Tuning 69 12-07-2014 04:07 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
