Old 11-04-2013, 04:51 PM   #15
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Originally Posted by ericmpena View Post
I have Eibach Sportlines and sometimes I feel like it's too low for my taste. I think I should've gone with a Pro-Kit, but I'm not sure.
About half the pics I see with a Pro-Kit look great, while the other half you can barely tell the car is dropped.
Who knows...maybe after seeing my car on a Pro-Kit I'd want the Sportlines back.
I think some of that is that the "just installed" ProKit images are showing springs that haven't settled. Once ProKits settle, they look just low enough to close that gap perfectly, but still high enough to be kind on shocks and look semi-OEM.
Source: my butt.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
The Following User Says Thank You to enwave For This Useful Post:
ericmpena (11-04-2013)
Old 11-04-2013, 05:22 PM   #16
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Source: my butt.
So I guess if I wanted to make the switch I'd have to buy a Pro-Kit, swap it for my Sportlines, then sell the Sportlines.
It sucks because I've already put the money into front camber bolts and rear LCAs, plus the cost of install. I'd have to spend another $200 for a Pro-Kit and about $240 for install, then sell my Sportlines for $150ish. Gonna put me $300 in the hole just to see if my gut feeling about Pro-Kit looking better is correct. Not to mention the cost of installing the LCAs and Sportlines was $450 and that's all pretty much wasted money as well. Damn.
I mean, I don't mind the look of the Sportlines. I just think that a Pro-Kit would've made more sense since this is my DD and I'm on stock struts.
Do y'all have any pics of your Pro-Kit after it's settled??
ericmpena is offline   Reply With Quote
Old 11-04-2013, 05:24 PM   #17
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by rikdrt1 View Post
so, Ive had my Swift springs for about a year. I miss my 'cush' ride and its getting to the point where I want my original suspension back ? ok , maybe its because im 'over-the'hill but still ---- anyone else go thru withdrawals ?
yea, it looks better but im thinking of packing it up and calling it a phase. TI also question the real advantage ? it seemed that with the stock suspension I had a bit more travel and on mtn runs, it seemed to sway a bit more but its more forgiving on the bumps and I don't think im doing my stock shocks a favor either ?
thoughts - suggestions ? im about to pull them out.
There's definitely nothing wrong with the stock suspension, this car gets critical acclaim left right and centre, and the suspension is a large part of it. As long as you can live with going back to the extra wheel gap then by all means. Forums are pretty terrible places for advice, everyone is convinced that what they do is for the best - the budget for engineering, testing and development in an OEM far surpasses anything that the aftermarket will muster.
I wish my coilovers were softer, that's my biggest complaint to be honest - but I like the look so I will deal with it.
djdnz is offline   Reply With Quote
Old 11-04-2013, 05:36 PM   #18
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Unless the springs are complete shit (extreme variation in advertised spring rates, massive spring sag), you are probably expecting too much for just lowering springs with up-rated spring rates.
Intent > Content
Old 11-05-2013, 09:19 AM   #19
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Originally Posted by SliverBrz View Post
get koni yellows.
problem solved
QFT. I recently installed the Konis (already had eibach sportline) and the difference is astounding.
I do regret buying sportlines instead of swift sports though. 1.4" is just a bit too low on this car.
Sellout is offline   Reply With Quote
Old 11-05-2013, 11:52 AM   #20
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The Following User Says Thank You to Sportsguy83 For This Useful Post:
rikdrt1 (11-07-2013)
Old 11-05-2013, 12:01 PM   #21
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Dont even bother posting a sale thread for those sportlines when/if you take them off, you got a (90% sure) buyer right here my friend
Old 11-05-2013, 12:05 PM   #22
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Old 11-05-2013, 02:42 PM   #23
Noob4Life
86 Noob
Drives: Firestorm FR-S
I've been thinking the same thing. I stupidly went with the Koru lip so altogether I'm sitting at a 2.5" drop in the front of the car lol I think it's just too low to have fun in. I was thinking about finding somebody with a pro kit and just trying to do an even swap. I'm sure there's people out there wanting to go lower lol but then again a .5" difference isn't going to do a whole lot with that lip on. I'm torn too haha
Noob4Life is offline   Reply With Quote
Old 11-05-2013, 07:54 PM   #24
Silverpike
popular among the JDM
Silverpike's Avatar
Drives: 2014 BRZ Limited
I'm surprised by this thread actually. I thought the Swifts were very close to the stock spring rate. It's unusual to me that the difference would be enough to cause regret.
Now I need to find someone local with these springs to compare the difference...
Silverpike is offline   Reply With Quote
Old 11-05-2013, 10:23 PM   #25
solidONE
solidONE's Avatar
I have the same springs as OP and I'm happy with them. I like them better than the stock springs. The factory rear springs felt like they had too much compression damping out of the box anyhow.
Intent > Content
Old 11-07-2013, 12:42 AM   #26
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
yea, the swift sports are 1.0 on all 4 - its good don't get me wrong. I love the look and idont know about spring rates and all that technical crap but all I know the wife doesn't even like getting in the car anymore and everyone ocmments on how rough it is - like I said, im not 20 anymore so some of it is that too but its noticeable.
I see a lot of folks buying the konis and improving it but daumm, that's 500dollars or so to try to get it back as it was designed.
the more I think about this the more I want to ignore the looks and just go back to OEM.
WELL, good to hear im not alone.
BTW, I rode in a friends that has the EIcbachs' -- holy crap I would of switched them months ago. way too rough compared to the Swifts..
thanks for the input guys...
MotegiRacing - TRD Racing -OemAudio++- Michellin Pilot SuperSports- Greddy -FiveAxis - SparksScion - BlueBat Overlays -Pioneer -SWIFT Engineering Sports- Evasive Motorsports-
SoCAL
rikdrt1 is offline   Reply With Quote
Old 11-07-2013, 05:52 AM   #27
Noob4Life
86 Noob
If you didn't cut your oem bumpstops that's probably why your ride is so rough. Only the Eibachs and Hotchkis springs come with shorter bumpstops. I can definitely feel the bumps a little more since lowering it but it's not like this care was soft to begin with. The ride is still oemish to me.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 11-07-2013, 11:29 AM   #28
Racecomp Engineering
Racecomp Yellow and our Tarmac springs come with bumpstops. I don't think Hotchkis springs do (could be wrong).
A mild drop with proper spring rates makes a big difference, especially with proper shortened bumpstops.
- Andy
whataboutbob (11-08-2013)
Lowering car with springs... What else do I need? SurfAndSand Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-25-2013 10:39 PM
TRD Lowering Springs? kALMIGHTY Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-29-2013 10:10 AM
RS*R Lowering Springs Soon to be out! tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-16-2013 02:39 PM
Lowering springs HELP FRS_13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-27-2012 10:03 PM
Lowering springs? Jeff Lange Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-10-2012 11:36 PM
