Old 11-04-2013, 10:17 AM   #225
DarkSunrise
DarkSunrise's Avatar
Originally Posted by 7thgear View Post
if you're transfering weight properly (gently, evenly) it is in fact normal
Thanks! It felt almost too stable, such that I was wondering if EBD was stepping in. There was a tight downhill "corkscrew" where I thought for sure the rear end would come around under trail-braking, but it stayed put. Not at all what I was expecting. Felt completely benign. The nose just tucked in and that was that.
2022 BRZ Build
2013 FR-S Build
Old 11-04-2013, 10:38 AM   #226
BRZ NA
Drives: WR blue
Originally Posted by smbstyle View Post
wanna see some sidewall wear? I'll post a pic of my left front from Sebring this past weekend, it looks like a full slick lol
Damn really?I thought -2.5 should be very decent camber for track already?
BRZ NA is offline   Reply With Quote
Old 11-04-2013, 10:41 AM   #227
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
it'll help, no doubt, but i think it also depends on the tire itself (how stiff the sidewall is) along with pressures your running, the type of track, and how hard you are pushing the car.
I'm only running like -1.6 or so, and it is DEFINITELY not enough.
smbstyle is offline   Reply With Quote
Old 11-04-2013, 11:24 AM   #228
CSG Mike
CSG Mike's Avatar
Originally Posted by uncivilised View Post
hey mike,
thanks for the advice
here is a pic of the front left tire (now swapped to the rear) this tire shows the most outside wear.
Can you get me a pic facing the tire directly instead of at an angle? I can't accurately gauge the wear with the angle and flash. Thanks!
Also, can you get me 1 of each tire (and tell me which is which)?
Old 11-04-2013, 11:25 AM   #229
CSG Mike
CSG Mike's Avatar
Originally Posted by DarkSunrise View Post
I had an instructor tell me to start experimenting with trail-braking yesterday. It made a nice difference getting the car to turn-in on some of the slower/medium speed corners. It felt very natural, so my instructor thought I might have already been doing it subconsciously to some extent I don't know.
What I found surprising was how planted the rear end felt. I was almost expecting the rear end to come around under medium trail-braking, but that didn't happen. Is that normal or are some part of the nannies/EBD still active even though VDC/TC is fully off?
Nannies are still on without the pedal dance.
Old 11-04-2013, 11:27 AM   #230
CSG Mike
CSG Mike's Avatar
It depends on the spring rates and how much roll the car is experiencing, as well as the model of the tire, the tire size vs rim size, etc.
However, as a rule of thumb, -3 is a good starting point for the front on a track car. Lower rates will need more camber, and vice versa.
BRZ NA (11-04-2013)
Old 11-04-2013, 12:10 PM   #231
DarkSunrise
Yeah I had a feeling that might be the case. How's the car under moderate trail-braking with the pedal dance?
2022 BRZ Build
2013 FR-S Build
Old 11-04-2013, 12:12 PM   #232
CSG Mike
CSG Mike's Avatar
It'll act like a normal car with the pedal dance. Without, it'll try to straighten itself.
amram (03-28-2014)
Old 11-04-2013, 12:15 PM   #233
BRZ NA
Drives: WR blue
Bone stock showing worn on the edge like the pic,but I m aiming for the rs3 and thinking of the size and camber need.So can't go too hard on the stock tires cause will end up sliding lol
Old 11-04-2013, 12:25 PM   #234
CSG Mike
CSG Mike's Avatar
Preventing sliding to maintain speed is a good skill to develop
I still need to work on that...
Old 11-04-2013, 12:59 PM   #235
Pokeguyjai
Pokeguyjai's Avatar
Drives: 2013 GBS BRZ (AT)
Hubcentric RINGS:
No, but I don't use them, because they might get stuck on the hub, which means you're going to potentially have issues putting on another set of wheels later. Additionally, plastic ones may deform and/or melt onto the hub or rim.
They're nice for "centering" the wheel, and taking the stress off of the lug nuts when you're initially tightening them, but ultimately, the lug nuts are what hold the wheel on, as well as force the wheel to center.
If you want to get super technical, they are added unsprung rotational mass.
Mike,
I got a set of plastic hub rings when I got my TC105Ns. I asked if they would melt and was told that they would be OK.
Should I take them off before I do a HPDE?
Pokeguyjai is offline   Reply With Quote
Old 11-04-2013, 01:02 PM   #236
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
through brake control?
Old 11-04-2013, 01:04 PM   #237
CSG Mike
CSG Mike's Avatar
Originally Posted by Pokeguyjai View Post
Mike,
We don't run hubcentric rings at all. The lugnuts will force the rims to center automatically. If they're metal, they're fine, but I'd avoid plastic ones.
amram (03-28-2014), Pokeguyjai (11-04-2013)
Old 11-04-2013, 01:08 PM   #238
CSG Mike
CSG Mike's Avatar
Precisely
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
