#421 |
Drives: '13 SWP BRZ
I'm glad I found this thread. I originally had my heart set on T2's but may just run the T0's with the 350 spring rate. This should be sufficient for the 2-3 track days, and mountain runs I participate in yearly. This is also my daily driver and don't really need jaw chattering firmness. lol.
@Racecomp Engineering, are the T0's readily available? |
#422 | |
![]() - Andy |
#423 |
Drives: 2013 FRS, 2008 R32
#424 |
Drives: 5th Gen Toyota 4Runner
Am I the only one that has the helper springs fully compressed even when the car is up on jack stands?
#425 |
Senior Addict
Drives: 86 GT
Any update on when we can expect the Bilstein fixed perch option to be released? Or has that option been shelved?
#426 |
#427 |
#428 |
Drives: Sterling Silver BRZ Limited MT
Thanks for all your help Myles! The car drives great.
specs: RCE Tarmac 0 coilovers 350/350 SPC '2nd gen' rear control arms, toe kit Subaru 'Group N' top mounts Subaru conical washers Whiteline front crontrol arm inner bushings stock camber bolts front - 2.5deg/ 0 toe rear - 2deg/ 1/16" toe in height: 25.7"/ 25.9" to top of fender arch
#429 |
another pic:
#431 |
wheels:
WedsSport TC105N 18" gunmetal 8.5 +43, 9.5 +35 Hankook Ventus RS3 235-40, 255-35 custom @kask2_6.0 hub rings/caps Muteki steel open ended lugnuts actual weights: 16.8/18.2lb, complete with tire 42.1/43.7lb (171.6lb/set)
#432 |
Senior Addict
Drives: 86 GT
I've read somewhere that the V1/ST/T0 uses damper cartridges inside the threaded body whereas the V3 uses cartridge-less twin tube design? Is that true?
Is anyone using the T0 experiencing knocks or sounds from their coilovers? I ask because there seems to be a number of other forums where guys using the V1 have complaints about weird sounds apparently due to the cartridges moving inside? Please enlighten me...? |
#433 |
Drives: 13 BRZ Limited WRB
I have about 2000 miles on mine so far with the 350 springs, and no noise at all.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
#434 |
![]() ![]() RCE Tarmac 0's Maxed out the fronts. Matched the rears. 265/35/18 Michelin PSS on 18x9.5 +40 SBC Enkei NT03's |
| Racecomp Tarmac II Clubsport coilover | JoeBoxer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 11-16-2013 11:02 PM |
| Tarmac Zero Coilovers Specs? | tintumz22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 06-13-2013 11:26 PM |
| KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! | NJA | Brakes, Suspension, Chassis | 7 | 03-30-2013 08:26 PM |
| Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-12-2012 12:24 PM |
| Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster | knoxviue | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 35 | 01-20-2012 01:44 AM |
