Master Installer
Drives: Scion FRS
My Alignment with Bilsteins
Just install the b14 kit today. Here is my alignment with virtually no adjusting except front toe to 0. Installed front with SPC camber bolts.
Front Driver: Front Passenger: Camber: -1 9/16 -1 3/16 Caster: +5 7/16 +5 7/16 Lowered: 1" 1" Toe: 0 Rear Driver: Rear Passenger: Camber: -2 1/4 -2 1/8 Toe: In 1/16" Lowered: 3/4" 1" I really surprise I didn't get more front camber since I already had -1 from the camber bolts. Besides that I am very happy with the coilovers. Ride is really not any stiffer but feels more planted. I will test at a track this next week. Thoughts on these settings? Last edited by Pacific Auto; 10-26-2013 at 02:48 AM. |
| The Following User Says Thank You to Pacific Auto For This Useful Post: | DAEMANO (02-23-2014) |
#2 |
Just a dude
Drives: Scion FR-S 2013
Basically -2 all around are you running super wide wheels or low offsets?, 9.5-10.0" widths..or just wanted really aggressive?
Guys who are tracking tend to go that deep or that are stance abit, seems most doing auto x or DD are more in the -1.5 f/r Either way your springs will settle and you'll need to re do alignment a month or so down road then can change if want different so no biggie really..
#3 |
Master Installer
Drives: Scion FRS
Stock wheels with PSS 17/45/225's.
I go to a local time attack almost once a week. I will play with them as they break in. I just hope the more camber in the rear won't cause understeer. |
#4 |
Drives: Some rust bucket
Front camber looks about right with only camber bolts. They don't really gain much camber under compression unlike the rear suspension. You could always add camber plates to the front if you need additional camber.
#5 | |
Senior Addict
Drives: 86 GT
![]() What does a 1/16" toe equate to in degrees? |
#6 |
Drives: WRB LMTD '13
#7 |
Drives: '23 BRZ
1/16" = .0625"
Tire diameter = 25" 1/16" toe-in = sin-1(.0625"/25") = 0.14 degrees |
| DIY Alignment | FRSFirestorm | DIY (Do-It-Yourself) Guides | 41 | 01-31-2020 07:06 PM |
| Bilsteins, quick help? | Pacific Auto | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 02-20-2014 01:11 PM |
| Just got an alignment.. | Scalzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 30 | 06-01-2013 10:39 PM |
| Big O For Alignment? | djliquidsteele | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 02-19-2013 05:21 PM |
| where to get alignment? | FML | Hawaii | 2 | 08-08-2012 01:36 AM |
