kidgogeta
Old 11-01-2013, 12:36 PM   #1205
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Originally Posted by ChandlerSwyng View Post
I run 235/40/18 and i'm about lower on sportlines which is about 1.4 inch drop, can you explain what the crash bolts do?
Pretty much crash bolts are smaller thickness than stock, which allows for movement in the strut-to-arm joint. This "play" gives the alignment tech room to swivel the wheel outward slightly, thus reducing the negative camber.
Most crash bolts give .5 to 1 deg of adjustability.
mwjcyber is offline   Reply With Quote
Old 11-01-2013, 01:20 PM   #1206
bfrank1972
Drives: 2013 FR-S Argento
"Crash" bolts are simply thinner than the stock bolts, which allows some play in the upper bolt hole where the strut connects to the hub. That means if you loosen those bolts, you can tilt the hub (ergo your rim/wheel) in and out a little bit. The degree your wheel is tilted in or out is called camber. They're called "Crash" bolts because if you crashed your car, they would give a shop some leeway in trying to get things re-aligned.
Check out this thread, good primer:
http://www.ft86club.com/forums/showthread.php?t=25001
So, you've lowered the car with sportline springs, and purchased some XXR rims, 8.75 width, offset +35. With stock front camber, even when lowered, that width and offset may poke just a wee bit. To get them even or slightly tuck under your fender, camber bolts will allow you to push them (negative camber) just enough to get rid of the 'poke'.
The Following User Says Thank You to bfrank1972 For This Useful Post:
mwjcyber (11-01-2013)
Old 11-01-2013, 01:23 PM   #1207
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
What degree of camber would I do? And will the alignment shop do this?
Old 11-01-2013, 01:47 PM   #1208
bfrank1972
Let's back up slightly, I don't want to talk you into anything you may not need:
1) Do you like how your tires are currently or do you think they poke too much?
2) What size/offset rims do you have?
Old 11-01-2013, 02:23 PM   #1209
ChandlerSwyng
I am okay with how they look now, xxr 527 18x8.75 235/40/18 +35
Old 11-01-2013, 03:03 PM   #1210
bfrank1972
Ok then, looks wise you may not need to change camber.
Alignment wise however, it's still not a bad idea to have camber bolts or crash bolts added up front during alignment - these cars are notorious for having very 'loose' specs on factory alignment when it comes to camber. Left and right front camber settings may be significantly different - not a huge deal but a lot of people use camber bolts to get them even when they get their cars aligned. Also the car's cornering ability will improve with a little negative camber on both sides, something between -1 and -1.5 degrees negative camber can improve things noticably. Your call.
Old 11-01-2013, 08:40 PM   #1211
ChandlerSwyng
And 1 degree won't kill the tires correct?
Old 11-01-2013, 09:04 PM   #1212
mwjcyber
mwjcyber's Avatar
You need more than 2 degrees of camber to have significant uneven wear, which doesn't reduce tread life. What kills tires is bad Toe alignment, which is the main reason you need an alignment every time ride height or camber is adjusted; because they change your Toe.
Toe is simply how straight your tires point.
The Following User Says Thank You to mwjcyber For This Useful Post:
Parappa (09-08-2014)
Old 11-02-2013, 01:45 PM   #1213
trigger happy
Bang Bang
trigger happy's Avatar
Drives: 2013 Raven FR-S
Anybody do 18x8.75 +35 on sportlines with 235/40 tire? Just wondering if the camber would need to be adjusted. I'm between the pro kit and sportlines. I know superbee has 245/40 on pro kit just figured with a little less tire it would leave room for a slightly bigger drop.
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers
trigger happy is offline   Reply With Quote
Old 11-02-2013, 10:29 PM   #1214
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Finally got my wheels! 18x8.75 +35 Chromium Black, lowered on H&R Sports, 225/40 tires, no camber bolts.. yet
Old 11-02-2013, 11:03 PM   #1215
trigger happy
Bang Bang
Originally Posted by Wes View Post
Finally got my wheels! 18x8.75 +35 Chromium Black, lowered on H&R Sports, no camber bolts.. yet
Tire size?
Old 11-02-2013, 11:13 PM   #1216
SnakeEyes
Drives: Subaru BRZ 2013
Got it mounted today! Need moar low!
Sent from my Nexus 4 using Tapatalk
SnakeEyes is offline   Reply With Quote
Old 11-02-2013, 11:38 PM   #1217
Wes
Wes's Avatar
Originally Posted by trigger happy View Post
Tire size?
225/40
Old 11-03-2013, 07:35 PM   #1218
Hmongfrs
Drives: Red
joining the xxr family!!!
Hmongfrs is offline   Reply With Quote
The Following 5 Users Say Thank You to Hmongfrs For This Useful Post:
Code:Red (11-03-2013), HATED1 (11-03-2013), Jaylyons1 (11-03-2013), SkAsphalt (11-04-2013), SnakeEyes (11-03-2013)
17 wheels
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 04:55 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 01:24 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
